2006 F250 questions
Results 1 to 6 of 6
    Thanked: 175
    Default 2006 F250 questions
    Hi guys, I'm looking at possibly a F250 for loading/ work applications replacing a std size bakkie with trailer.
    Some questions
    Are the maintenance parts readily available? filters, etc
    Are these bakkies hobby vehicles or are they reliable?
    What sort of issues does these bakkies generally have and what to look for when viewing, specific to the F250.
    Whats the typical fuel consumption like around 7km per liter?
    Thanks in advance
    Hilux 2700i s/c 4X4 with a few extras ...............
    Thanked: 13577
    Default Re: 2006 F250 questions
    That engine isn't known for its reliability.
    Helderkruin
    Thanked: 410
    ismail ek ry n F250 2006 model en is baie tevrede met hom het wel my engine vervang 2019 met n V8 maar daar was niks fout met my 4.2 td engine nie.
    Ek gebruik my F om mee te toer was al in n paar buurlande met hom en vir my is hy betroubaar en by gese eninge voertuig kan ontlkaar raak.
    Het so 7 k/l gekry met 4.2 engine in en ken ook n paar manne wat al baie goeie kilos op hulle F het.
    Groot dink is moet net nie aan die engine peter nie los hom sandard of kan SAC Nelspruit toe gaan om diesel pomp testel.
    En jy kan service parte hier in SA koop en parte wat jy nie kry nie laat in kom van USA af teen redelike goeie pryse.
    Die probleem op die F250,s is dat hulle warm word en dan het jy moeilikheid.
    Quote Originally Posted by ismail View Post
    Some questions
    Thanks in advance
    Thanked: 176
    BS - we've got a 2006, bought in 2009. No engine issues what so ever
    Thanked: 175
    Thanks Leon and Spook
    Noted, if looked after the F250 should not be much of an issue engine wise.
    Need to watch out for signs of over heating, thanks
    I see its quite a low revving engine 500 Nm @ 2000 rpm (I think) so i assume its very truck like in the way it pulls and drives in general.
    There's 2 I'm going to view after the lockdown.
    Anyone know where I can get a workshop manual for them?
    PS, these Brazillian F250's are they the Perkins 4.2td?
    Kathu
    Thanked: 2838
    The engine is the MWM 4.2 Sprint engine
  7. The Following User Says Thank You to grips For This Useful Post:
