How to waterproof a cracked conduit pipe
Results 1 to 17 of 17
Hybrid View
    Feb 2017
    Thanked: 27
    Default How to waterproof a cracked conduit pipe
    So Iím running a 220v cable inside an existing conduit and found a few places it is cut open - it runs through the veggie patch and isnít very deep so it is to be expected.
    Currently thereíre cables for the alarm and intercom system running through the conduit.
    Iíd appreciate ideas from forumites on how to best protect the cables at the points where it is cracked already.
    Going forward I can reorganise the layout of the veggie patch so that there wonít be digging above the pipe.
    Johannesburg/Prague
    Thanked: 50
    Default Re: How to waterproof a cracked conduit pipe
    Depends what type of cable you are using inside the conduit , remember that a conduit under ground is not water tight its more for protecting the cable, as the joints in the conduit will eventually allow some water in
    Pajero 3.2 DID Gen 4 Standard for now
    Platcar Alfa Giulietta 1.4 MA
    Swambo Volvo S40 T5
  3. The Following 2 Users Say Thank You to 12richardk For This Useful Post:
    Thanked: 2223
    I am not sure whether the 220 cable is in there already or just the intercom and alarm.
    Running 220 and low voltage in the same conduit is not legal and it will cause interference etc. The 220 cable should be waterproof as long as it is a legal cable something like twin + earth , norsk or armored cable. Not cabtyre or ripcord.
    Pvc conduit responds very well to PVC Weld and in theory you should be able to glue the cracks. If you have pieces missing a coupler cut in half will do the trick.
    Henk
    Follow us on Facebook
  5. The Following 4 Users Say Thank You to hbannink For This Useful Post:
  6. #4
    Thanked: 3588
    Never run alarm and 220 cable in one conduit. Do not run gate phone and alarm either. For some reason gate phone is more suspect to lightning.
    Only way to prevent damage is to dig deep or cover with concrete or similar.
    As said conduit is not there to keep cables dry. There are cables that get damaged by water - cheap Chinese (experience). Also even armored 220 cable can be damaged if not deep.
    If you have to make a joint on 220 V cable you have to use epoxy filled connection boxes. I assume they work also for alarm/gate phone wires.
    Jouko
    2003 Grand Cherokee 4.7l
    2012 Smart
    Never drive a normal car 8)
  7. The Following User Says Thank You to Jouko For This Useful Post:
  8. #5
    Feb 2017
    Thanked: 27
    🤨 It took me the better part of a day just to get the 220 through the conduit to the desired spot. Just finished tonight
    Back to the drawing board then.
    Thanks yíall
  9. #6
    Thanked: 2223
    Next time run the cable before glueiing the coduits together or pop round I will lend you my fish tape makes life sooooo much easier
    Henk
  10. #7
    Feb 2017
    Thanked: 27
    To my shame I had to Google fish tape I used a pilot / guide string (piece of electrical fence wire) and something like this would've helped a lot but I'm going to yank it all out now anyway.
    I'm not very handy - I get myself into trouble too often, like with this 220v too close to the low voltage wire Sometimes I think stuff like this ought to be taught in schools but I doubt I would've paid attention
  11. #8
    Thanked: 2223
    Quote Originally Posted by CabousBeer View Post
    Easy one is to bend the tip of the electric fence wire back on itself. Not knowing a fish tape is no crime, it was my trade for many years, there are a lot of simple tricks you pick up in the lines like putting Mazina in to the conduits to lubricate the wires and Never using soap as it dries and then is as good as glue.
    @ Marc, 15 -20 years ago the regulations were much higher than now, then we had to put 2 + e in a "mechanical" protection, the black pipe is about 10X the strength of the flimsy conduit that was deemed to satisfy.
    In those years conduit had to have the SABS stamp otherwise the inspectors would fail the job and cost you a lot of money to sort out. Pretty soon non SABS "white pipe" became available and was used for primarily protection for intercom cables but also for chasing in to walls where inspectors could not see, saved a packet. Nowdays the wire must be protected even if it is just under 100mm soil it is fine no more 500mm at least and then conduit unless it is armoured cable. I used to keep my trenches open for the inspectors to see otherwise they would make you open every so often so that they can see
    The reason for the separate conduits for low and high voltage besides interference is the transformer effect. A normal transformer uses a long wire wound around a metal core and a second wire also wound the metal core. Magnetic induction happens and a new current is induced in the secondary winding. A high voltage in close proximity of another line especially a 2 +e is as good as a transformer. Magnetic flux can do nasty things ie. a fluoressent tube glows when brought close enough to HT lines and other strange things like that.
    Henk
  12. The Following 2 Users Say Thank You to hbannink For This Useful Post:
  13. #9
    Apr 2009
    Thanked: 86
    Cut a piece of spare conduit, longer than where the crack is, cut the piece length wise to split, slide over damaged conduit, first ensure to glue with proper PVC cement,
    PVC weld is rubbish, proba ly the reason you mention the joints will start leaking
    Rather use PVC cement made for pressure applications such as Oatey or Tangit
    Alternatively take some shavings from the conduit and mix with PVC Cement and plug the hole
  14. The Following User Says Thank You to Vuurmaker For This Useful Post:
  15. #10
    King Williams Town
    Thanked: 1116
    Best advice I can give is reroute conduit away from veggie garden if not, repair pipe as mentioned then drop conduit down to 500mm into a trench. Do the same with the 220v supply in a separate conduit.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  16. The Following 2 Users Say Thank You to hunter26 For This Useful Post:
  17. #11
    Thanked: 538
    If you ever have to lay a cable/conduit shallow just put a single layer of bricks sideways over the conduit in the trench. This way one will soon find out there is something in the way before a fork/spade damages it.
  18. #12
    Thanked: 940
    In order to prevent me opening myself up to some possible criticism here... let me just say this is for a friend...
    A guy ran an electrical cable 2.5 mm2 twin and earth from the house to the outbuildings. The cable was pulled through a high quality (recommended by a plumber) thick black high pressure water pipe.
    That was maybe 15 years ago, and then about 6 years ago he pulled CAT 5 cable in the same black pipe. No problems to date.
    A qualified electrician told me that was a bad thing to do, even before the data cable was pulled in, but he could not give any reasonable explanation.
    My thinking was that I have the electrical properties sorted in the twin and earth, and the water pipe is providing better mechanical protection than I would get from electrical PVC conduit.
    I have a similar requirement again, and if I don't get a bad report here, I will do that again. Would that be a good option for the OP?
    -Abraham Lincoln
  19. #13
    Aug 2019
    Thanked: 122
    MarcR`s suggestion of replacing the PVC pipe with a HDPE pipe is not a bad idea, thick walled HDPE can take a lot more abuse and offers great protection. In industrial setting we use Nextube conduit that is manufactured out of HDPE.
    Running an UTP cable in parallel with a AC power cable wont present any real world issue with the network cable. UTP cable is unshielded TWISTED PAIR. These twists between pairs reduces the crosstalk between conductors, the one difference between CAT 5 and CAT 6 UPT cable is that CAT 6 has a higher number of twist per meter, allowing higher frequencies and hence higher data transfer rates . A shielded cable will work even better to eliminate electromagnetic interference from the 50 Hz power cable. But its not in line with our local regulations as UTP cable insulation is not rated for 220V . In the case where CabousBeer spits trough the power cable and network cable with his spit fork the 220V AC can flow trough the network cable and fry all his IT gear, set his house on fire, and electrocute the poor sod working on the 386 DX.
    Best practice is to make sure the cable is buried deeper than what anyone would ever spit. Make sure the cable has mechanical protection. In cases where this is not possible the cable must be protected by an Earth Leakage device. Never run power cables and signal cables in the same wireways. If they need to cross, make sure they cross at a 90deg angle. Alarm cable is not twisted pairs its usually super cheap 0.00005mm2 copper if you are lucky but the signal is either on or off, so EMI not really an issue here.
    For interest in industrial settings this is taken really seriously:
    0.08.00 INSTRUMENTATION CABLE INSTALLATION AND ROUTING
    10.01.00 All cables assigned to a particular duct/conduit shall be grouped and pulled in simultaneously using cable grips and suitable lubricants. Cables removed from one duct/conduit shall not be reused without approval of Employer.
    10.02.00 Cables shall be segregated as per IEEE Std.-422 and IEEE 524 (1992) In vertically stacked
    trays, the higher voltage cable shall be in higher position and instrumentation cable shall be in bottom tier of the tray stack. The distance between instrumentation cables and those of other system shall be as follows:
    From 11 kV/6.6 kV/3.3 kV tray system - 914 mm
    From 415V tray system - 610 mm
    From control cable tray system - 305 mm
  20. The Following 2 Users Say Thank You to Tiaan Pot For This Useful Post:
  21. #14
    Feb 2017
    Thanked: 27
    So I undid most of my dayís work in about 15 minutes today - yanking the cable back out.
    HDPE is a very good idea.
    Thanks for the info re. UTP
