What wire for temporarily solar
Results 1 to 17 of 17
    Aug 2018
    Paarl
    Thanked: 50
    Default What wire for temporarily solar
    Hi what wire can I use for running my solar panels. My panels is currently standing in my garden and I would like to move it.
    But because of lockdown where will I get decent wire and what wire must I use.
    Friemersheim, Southern Cape
    Thanked: 2965
    Default Re: What wire for temporarily solar
    To be able to answer more info is needed.
    ie as much as possible
    Size of panels?
    Distance?
    How many?
    Configuration?
    etc
    Aug 2018
    Paarl
    Thanked: 50
    Size of panels?
    Distance?
    How many?
    Configuration?
    etc
    X2 panels 80w
    About 12m of cable
    Connected to x2 105ah batteries and 12v inverter.
    Hillcrest, Malaysia
    Thanked: 6455
    In the absence of further info.
    The answer is any wire, there is nothing special about proper solar cable electrically, its all about environmental protection.
    So any wire, the thicker the better. If you cant get thick, then parallel thin cables.
    You can buy the proper stuff later.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Thanked: 2965
    Absolute min 2.5mm sq, rather 4mm sq.
    As Fluffy said, thicker better. Sort later
    Thanked: 474
    Even 1.5mm would do for now. 2.5mm perhaps ideal for later.
    I take it the solar contoller would be at the batteries and not at the solar panels.
    Thanked: 172
    Quote Originally Posted by fatbike View Post
    X2 panels 80w
    About 12m of cable
    You can use normal 4mm^2 for this.
    2018 Ranger DC 2.2 XLS Auto 4x4
    Canon 5DMkIV with L-goodies.
    Aug 2018
    Paarl
    Thanked: 50
    Jip controller @ batteries
    Thanked: 2965
    If you can't get wire right now, an extension lead of 2.5mm sq will do the job
  10. The Following User Says Thank You to Prof For This Useful Post:
    Mar 2017
    Okahandja
    Thanked: 712
    What have you got available and how many meter of it
    Aug 2018
    Paarl
    Thanked: 50
    Quote Originally Posted by Erwin Schimper View Post
    I am looking for a place to get wire
    Aug 2017
    Durban or Centurion
    Thanked: 1235
    Easiest option is probably to try and get an extension cord from a large supermarket type place
  14. The Following User Says Thank You to SAND For This Useful Post:
  15. #13
    Thanked: 474
    May be you can get some speaker wire from a supermarket while buying some food. Just use 2x twin flex leads for each polarity or get a 20m extension with 1.5mm thick wire.
  16. #14
    Aug 2018
    Paarl
    Thanked: 50
    Will normal 3 core lead wire work
  17. #15
    Aug 2017
    Durban or Centurion
    Thanked: 1235
    Yes. You can either use two of the cores, or combine all into a positive lead, and then do the same for a negative lead
  18. #16
    Mar 2017
    Okahandja
    Thanked: 712
    As he said. 3cores for pos and 3cores for neg. If you get 1.5mm it will be 4.5mm for each which is fine. Even 1mm will give you 3mm. Still ok
  19. #17
    Thanked: 1150
    Voltex is open.....
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
