Advice needed from the diesel gurus
Results 1 to 20 of 37
    Feb 2012
    Mindalore
    Thanked: 112
    Default Advice needed from the diesel gurus
    A while ago my pajero engine died on me, it basically lost power and refused to start again. Due to work commitments, I didn't get a chance to have a look at it previously but with lockdown I now have all the time in the world.
    I pulled the motor out and noticed quite a few things, that don't make sense to me, and am hoping someone can point me in the right direction.
    The first thing is that I seem to have very low compression.I could turn the motor over by hand, using the flywheel. My gut is telling me that it's the rings, as the intercooler and turbo were full of oil (about 500ml came out the intercooler alone), and there was evidence that oil had been blowing out the pressure valve at the back of the intake manifold.
    The second thing I saw was that the freeze plug at the back of the head is missing, which explains why only about 1.5l of antifreeze came out the cooling system when I drained it. I would have thought that this indicates the head gasket is gone, or the head even being cracked, but I saw no signs of this.
    Another thing that's really confusing is that the intake & exhaust manifold bolts, as well as the head bolts at the rear of the engine were all loose. Most of them were barely more than finger tight. These were all the ones around cylinders 3 & 4. Could this be heat related?
    Looking at the head itself, you can see a colour difference on the exhaust valves on the back 2 cylinders, which seems to indicate that they weren't buring the same as the front cylinders. The diesel pump and injectors were done recently so I don't think they can be causing a difference in fueling?
    I pulled the pistons out, and couldn't find any signs of water in the bores, but they are really smooth. I also noted that the back 2 pistons came out easier than the front 2 pistons.
    Would I need to do a full rebuild with a new head, or could I get away with honing the bores, and fitting new gaskets and rings?
ID:	564772   Click image for larger version.
ID:	564774   Click image for larger version.
ID:	564775   Click image for larger version.
ID:	564776   Click image for larger version.
ID:	564777   Click image for larger version.
ID:	564778   Click image for larger version.
ID:	564779   Click image for larger version.
    One Wife - Livid
    Nigel
    Thanked: 2289
    Default Re: Advice needed from the diesel gurus
    Get a proper spec sheet and measure all. Else get the engineering works to do it for you.
    If you can't measure it, you can't manage it.
    Uniglide
    +27 zero eight 2 four 95 9252
    Thanked: 2444
    As much as i like a rwbuild, id get an import motor and call it a day
    Then again, the last import motor i dropped in was a pig and cost me an extra few hours to sort out various issues.
    Hard to say.
    All I can say is, dont cheap out. Do it right, do it proper, the first time!
  4. The Following User Says Thank You to MariusFourie For This Useful Post:
    Nigel
    Thanked: 2289
    The import motors are a serious gamble. Just put 1 into ssanyong Stavic and I have a buggered injector.
    To get the head off, i need to pull the motor. To get the injector out, I need to pull the head.
    If you are looking at an import motor, double your time budget and add half the price of an overhaul.
    Uniglide
    Feb 2012
    Mindalore
    Thanked: 112
    Measuring is out at the moment, I only have a Vernier at home, the micrometer is at work.
    I'm just trying to figure out why it failed like it did, because from visual inspection everything looks ok
    One Wife - Livid
    Thanked: 229
    Surely looks like someone worked on the engine before you and did not tighten the bolts correctly. You have a failed head gasket if I look at things and from what I can see the head will have to be replaced.
    You do not state how many km's on the engine. If more than 300k then I would simply buy a 80k import engine and drop it in place. Cheapest route by a long shot.
    Feb 2020
    Las Vegas and Minneapolis
    Thanked: 372
    Iíve seen worse...
    Send the cylinder head out for mag particle inspection and maybe overhaul, re-use the bearings, use a ball hone on the cylinders, get rings, gaskets, and welch plugs then put it back together...
    ...or get a serviceable used engine
    David -
    Ď20 Toyota Tacoma TRD Off Road Decal Edition 3.5L
    If your only tools are a cutting torch and hammer, all of your problems are locomotives...
    Jul 2016
    Thanked: 501
    Show us the pistons. You will need to get head checked. Pressure test. Skim. Maybe reseat valves. There is a compression issue there. Replace the missing welsh plug. Check that the bores are still in spec then hone
    New gaskets. New rings. Good luck
    Langs die rivier, op n berg
    Thanked: 2982
    Ek nie baie clued ip met enhine rebuilds nie, maar as ek n leuke raai moet gee:
    Welch plug verloor.
    Water verloor
    Engine overheated, wat veroorsaak het dat hitte rek en krimp die manifold boute laat los kom het.
    Hitte het jou ringe laat lÍ, nou os kompressie gone.
    Dalk tesame met n geblaaste head gasket tussen combustion en combustion . Kan dalk tussen combustion en water ook wees. Jy sÍ jy sien geen tekens van water in silinders, maar jy sÍ ook welch plug was uit, met geen water in engine..., so daar was nie water om in silinders te lÍ nie.
    Agterste 2 silinders lyk na laer kompressie as voorste 2.
    Hoeveel km op?
    Ek sou sÍ: resleeve. Nuwe pistons en ringe. Laat meet crank op. Polish of sny crank. Nuwe big ends en mains. Oliepomp. Gasket kit.
    Laat toets head.
    Sonder om head of crank te vervang. Seker in vir R9000. (Hang af watter engine, wat is dit?)
    Groot probleem bly maar beskikbaarheid van parte op pajero. Sommige engine parte is net onbekombaar...
    Kaar ja, my leuke opinie uit wat ek hoor en op 2 fotos sien.
  11. The Following 3 Users Say Thank You to Reenen For This Useful Post:
    Thanked: 2982
    Neem asb fotos van piston skirts ook asb.
    Kyk vir my hoe los sit ringe in pistons
    En dan natuurlik moet boor gemeet word.
    Jy mag lucky wees om net met n ring job verby te kom.
    Crank en bearingslyk of jy kan weg kom met n polish van crank en net selfde nuwe bearing shells.
    So dit kan jou dalk, as head reg is, onder R4000 kos. Ek sou def eers kyk na rebuild.
  13. #11
    joburg
    Thanked: 446
    Weigh up what a set of pistons, rings and bearings cost and see what your total cost will be, may just be worth doing it?
    You probably going to be keeping the car?
  14. #12
    joburg
    Thanked: 446
    But a full recon may cost more than the car?
    Timing chain,tensioner and guides, water and oil pumps, turbo and recon diesel pump with injectors, thermostat, viscous fan......costs snowball, but I'd personally do the new bearings and new pistons heat does funny things to pistons.
  15. #13
    Thanked: 189
    Which engine? 2.8 or 3.2?
    Would it be a possibility that the guys doing the pump and injectors created some more work for thenselves?
    Si vis pacem, para bellum
  16. #14
    Kathu
    Thanked: 2842
    I agree with Reenen lost Welsh plug caused the problem. See there is score marks in the sleeve which means an overheated engine.
    Pic`s of the pistons as many said in the thread will give the final clues.
  17. #15
    Feb 2019
    Thanked: 61
    I have no idea what is going on here, but isn't that the 2.8tdi which has a tendency to get hot if the cooling is not 100%. Those cooling ports look pretty choked up which may indicate the use of too much water and not enough anti-freeze over the years. Depending where you live the welsh plug may have been pushed out if the water inside froze (is that not its role) or if the ports are too blocked.
    But that all speculation so please correct me, I'm still learning
  18. #16
    Feb 2012
    Mindalore
    Thanked: 112
    Thanks for all the replies, I appreciate the help.
    Sorry I left some of the detail out when i previously posted.
    The car is a 96 Pajero with the 2.8 engine with just under 400k km on it. I've had the car about 6 years now, and in that time its just needed mainly routine maintenance eg services, starter motor, radiator, cv joints & ball joints. The last major item done to it was the diesel pump and injectors, and its possible that the guys stuffed up, but I doubt that they would have loosened the cylinder head or manifolds.
    The plan was to keep the car, as with the current economic climate a new car is not on the cards. Also it will be worth stuffall with a blown engine.
    Today I managed to clean a lot of the parts up to give a better idea of what's going on. What I found was rather sad:
    - The pistons have some scoring on them, with the worst being piston 3 which I took a photo of
    - Piston 2 has melted, you can see the difference between it and another undamaged piston
    - You can see on the same cylinder that the top of the block and the precombustion chamber were also damaged/melted.
    - Then lastly the really weird one, is what looks like aluminium dust in the thermostat and water pump housings. I have no clue where that came from, or could have caused a blockage somewhere.
ID:	564963   Click image for larger version.
ID:	564964   Click image for larger version.
ID:	564965   Click image for larger version.
ID:	564966   Click image for larger version.
    One Wife - Livid
  19. #17
    Kathu
    Thanked: 2842
    All the signs of overheating. Typical of an engine that heat seized due to the lost of coolant.
  20. The Following User Says Thank You to grips For This Useful Post:
  21. #18
    Petoorstown
    Thanked: 54
    +1 with grips.
    My opinion knowing a bit of the mitsu motors and alu heads just look for another motor.
    Clean that intercooler out aswell as all your pipes.
    2018 VW Amarok V6 TDi
    2017 Toyota Prado 3.0 D4D VX
  22. #19
    Feb 2020
    Thanked: 372
    I see new pistons in your future...
    Like I said, Iíve seen worse and those might last a number of years in service if you dress those up and re-use them, but Iíd weigh the cost of new pistons and other parts vs serviceable used engine...
    David -
  23. #20
    Zululand
    Thanked: 82
    Can you get a second hand colt engine? May be better option?
