KB 280 injector pump
Results 1 to 13 of 13
    Thanked: 554
    Default KB 280 injector pump
    Howdy. Have noticed my injector pump drips diesel, this is not good, because diesel is expensive. I want to remove the little door that is leaking and replace the gasket, but was just wondering, if anyone knows, what secrets lay behind the door, once off, will i be attacked by springs and washers?
    Rand for Rand gets 33Km/L
    Thanked: 13553
    Default Re: KB 280 injector pump
    Pump plunger cover?
    http://www.dieselcatalog.online/en/b...460610197.html
    There is a spring behind the plunger........
  3. The Following User Says Thank You to jelo For This Useful Post:
    Thanked: 554
    Shot, looks like an O ring is leaking
    Thanked: 13553
    Yep. I'd back off those two machine screws VERY slowly and see if anything wants to jump out.
    Wilderness
    Thanked: 1170
    That's where you check timing marks. You will not harm anything by removing that cover. Nothing will fall out. You will have to bleed the pump after repair. Do not use silicon on there. The diesel will disolve it. Try tightening the 2 bolts first. Sometimes they are a bit loose.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Thanked: 13553
    Yes, that's what I would try first as well.
    Thanked: 554
    Ja, had to have a good laugh about it though.
    Thanked: 554
    Yep, did try and tighten, they are tiny little bolts so don't want to try too much, just in case I turn them off.
    Thanked: 13553
    The question is where are you gonna get an O-ring during lock-down? Do you have gasket paper?
    Thanked: 554
    Ja, was thinking about that. Will have to leave it it as it is till O Ring shop is open.
  12. #11
    Nigel
    Thanked: 2284
    You can temp patch with a light coating of Victor Reinz. But use those green o-rings. Lot more stable
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
  13. The Following User Says Thank You to Henris For This Useful Post:
  14. #12
    Wilderness
    Thanked: 1170
    Maak hom oop, en post 'n pic van wat uitgeval het!
  15. #13
    Thanked: 554
    So, took the plunge, bought a few O rings and took the plate off, no bits came flying out. Took the old one, which was flat and used a bigger O ring and cut it to size, glued it and put back. Tightened up, test drive and leak is missing like a president. Bought 3 O rings at 30 cents each.... for practice. But got it right first time.
  16. The Following User Says Thank You to ZuluCowboy For This Useful Post:
