W115 240D - Covid project - Page 4
Results 61 to 80 of 82
  1. #61
    Thanked: 345
    Default Re: W115 240D - Covid project
    I need some advice - cooling related.
    If I remember correctly the coolant temperature always hovered around 80 degC (see the picture below). I went to the local filling station over the weekend which is about a 5km round trip.
    On my way back the temperature started kreeping up to 100, by the time I got home It was at 100 and slowly increasing. The top hoses on the engine were hot but the bottom hose of the radiator was still cold.
    Now, as mentioned in a previous post , I drained the coolant via the bottom hose of the radiator. I topped up with engine coolant directly into the radiator and it still is on its mark. No water leaks as far as I could determine.
    So do I have an air lock, sticky thermostat or is that "tjierie-tjierie" sound from the water pump area the root of my problem?
  2. #62
    Thanked: 345
    Image attached.Click image for larger version.
  3. #63
    Thanked: 15007
    Water pump is stuffed
  4. #64
    Thanked: 345
    The $hit has hit the fan. Ordered a new water pump and proceeded to fit it today. Due to the design of the pump and its aluminium base the bolts tend to seize and snap. Took my time and got 4 of the 5 bolts out but the last one snapped off (Murphy's law).
    To get the bolt out the radiator needs to come out. When I removed the bottom radiator hose a small amount of jelly like substance came out with the coolant. On further inspection I found that the connection to the thermostat was completely blocked (see pic) with this solidified coolant.
    Anybody else experienced this before and how do I flush the system to ensure I get most of it out?
    The water pump was perfect but I am replacing it in any case. At least I found the real problem in the process.
  5. #65
    Langs die rivier, op n berg
    Thanked: 3181
    Coke
  6. #66
    Thanked: 600
    Yep, run it without the thermostat and fill up with some coke, also, you will need to get that radiator rodded or re cored. With that level of corrosion and crap in the system, I hope the sleeves have not taken a pounding and caused rust on the cold side of the sleeve.
    You could unsolder the top and bottom of the radiator and DIY, use the dipstick to open the cores. The muck is oily, so will need something to soften/loosen that, diesel also works.
    It's a messy time consuming job, but at this stage if you do not do it properly, you are going to sit with a cracked head down the line.
    Rand for Rand gets 33Km/L
  7. #67
    Thanked: 3181
    En daai heads hou van kraak
  8. #68
    Thanked: 600
    Try and run the engine without the radiator when you flush it, try and make something, a 20L bucket with the lower radiator hose connected to the bottom of the bucket, fit a fitting on, use a steel bucket or some plumbing fittings, and the top hose emptying into the bucket, but through a couple of layers of mutton cloth to try and catch the crud coming out of the engine. Otherwise you will be circulating the crud through your new radiator.
    Then do the radiator.
  9. #69
    Thanked: 600
    Yep, presies wat met die 5 gat watse body daar by jou le gebeur het ....
  10. #70
    Thanked: 345
    Thanks ZuluCowboy and Reenen. Will give the coke remedy a go.
    How much Coke in the system and for how long do I idle it?
    I checked some of the other hoses but they all appear to be clean. I will inspect the radiator once it's out.
    Luckily it is not all doom and gloom - got the cigarette lighter in the ashtray to work again, not that I smoke, but if it is there it needs to be in working order. Glove compartment has a working light and one of the door locks was sticky. The door mechanism is easy to remove, clean and lube. I must say I love the robust simplicity of these old Mercs.
  11. #71
    Thanked: 15007
    Just Coke. All of it.
  12. #72
    Thanked: 600
    There should also be a bolt on the exhaust side of the block, below about No3, 19mm if I remember correctly to help flush the motor.
    You can run it for a while, provided there is always obviously water in the engine. 3x2L should help, I have even run drain cleaner in there to try and get crud out.
    Just don't run it through the radiator, will block it in no time.
  13. #73
    Thanked: 3181
    Maar coke maak die aanpaksels in radiator los. En maak partykeer dat n heel radiator skielik lek
  14. #74
    Thanked: 345
    Thanks for the advice. Will continue tomorrow.
  15. #75
    Thanked: 345
    Radiator and cooling all sorted, thanks for the advice once again.
    Anybody know where I can source new engine and gearbox mounts for this W115 or W114?
  16. #76
    Thanked: 600
    I'm almost 100% certain the W123 engine mounts are the same as 114/115.
  17. #77
    Thanked: 3181
    Al sou hulle effens anders lyk, nog steeds interchangeable
  18. #78
    Thanked: 345
    Thanks, yes they do look slightly different and good to know they are interchangeable.
    I used Pelican Parts to compare the parts - great site dedicated to older Mercedes cars. Sadly they are in the US.
    https://www.pelicanparts.com/Mercedes-Benz/index-SC.htm
  19. #79
    Modjadjiskloof
    Thanked: 147
    Does Imcomex still exist? I used to buy good quality aftermarket parts for my W115 there. In or near Midrand.
  20. #80
    Thanked: 600
    Howdy Ant, long time no hear!!
