Shattered Oven Glass - Bad Timing
Results 1 to 13 of 13
    Thanked: 631
    Default Shattered Oven Glass - Bad Timing
    After using the oven last night the oven glass shattered into a thousand pieces overnight. Itís quite a fancy Whirlpool oven that has three layers of glass, the one that shattered is the middle one. Can I clear out the pieces and still use the oven? I assume itís primarily there for additional insulation to stop the outside pane getting really hot. Bad timing as sourcing that middle pane now will well be a pain.
    2010 Bombardier Electrostar 746 kw - Gautrain (Daily Commute)
    Friemersheim, Southern Cape
    Thanked: 2992
    Default Re: Shattered Oven Glass - Bad Timing
    I would have a good look to heat escape to the sides.
    You have high gloss wrap doors. They do not like heat. Basically a plastic wrap.
  3. The Following User Says Thank You to Prof For This Useful Post:
    Thanked: 878
    Maybe this https://www.4x4community.co.za/forum...6-Tandoor-Oven or this https://www.4x4community.co.za/forum...en-cement-oven
    There is no end to Riaan's knowledge and advice.
    "The problem with internet quotes is that they are very often unverified."
    -Abraham Lincoln
  5. The Following User Says Thank You to MarcR For This Useful Post:
    Feb 2013
    Thanked: 234
    Rather just braai till you can replace it after the lock down.
    I don't drink water, unless it's been through a brewery first.
    "The darkest places in hell are reserved for those who maintain neutrality in times of moral crisis." - Dante Alighieri
  7. The Following 2 Users Say Thank You to bigboy529 For This Useful Post:
  8. #5
    Thanked: 1041
    Personally, I would make do without an oven till I can get it replaced: From what I can see it is an "eye level" unit. If the other two panes cannot take the heat, I would not want to have myself and/or wife and kids standing in front of- or walking past that oven if or when they do shatter.
    1959 SII 88"
    197? RRC
    2002 Defender Td5 D/C
  9. The Following User Says Thank You to EttiennedK For This Useful Post:
  10. #6
    Thanked: 631
    New oven
  11. The Following User Says Thank You to Kortgat For This Useful Post:
  12. #7
    Thanked: 478
    From my experience trying to find Whirlpool spares, good luck.
  13. The Following User Says Thank You to faniedup For This Useful Post:
  14. #8
    Thanked: 486
    Lategans & Van Biljoen Pretoria do stock quite a big range of Whirlpool spares.
  15. The Following User Says Thank You to ekkekan For This Useful Post:
  16. #9
    Sep 2016
    Thanked: 3265
    Does it have a grill option? I would think the glass is not that necessary.
  17. #10
    Thanked: 631
    Quote Originally Posted by Roberto Betta View Post
    Yes it does. I think Iíll just braai most days...
  18. #11
    Thanked: 478
    Last time I visited them they had to order almost every thing Whirlpool, no stock and often Whirlpool had no stock either.
    I'm sitting with a microwave and an oven for which electronic boards are unobtanium. Found spares at a UK online shop, but they refuse to shop to SA
  19. #12
    Thanked: 631
    If needs be Iíll just get a heat tempered glass made to size.
  20. #13
    Thanked: 2992
    The wood fired stove guys have sheets and can cut to size.
    Just don't know who in Gauteng
  21. The Following User Says Thank You to Prof For This Useful Post:
