Conqueror comfort Tent Too 'small'
Results 1 to 8 of 8
    Nov 2019
    Thanked: 9
    Default Conqueror comfort Tent Too 'small'
    Hallo, I bought a second hand conqueror comfort 2010 model. I've noticed the inside side wall on the trailer is to 'small' i.e. not wide enough. See the photo below.
    Anybody else having the same issue?
    Does anyone know who can assist to fix this? Click image for larger version.
ID:	563813Click image for larger version.
    Sep 2012
    Canberra
    Thanked: 27
    Default Re: Conqueror comfort Tent Too 'small'
    Haven't seen that before.
    Does it allow you to zip up the inner flap?
    My initial thought was that it's just the flap hanging down pulling the sides in. And that if you zip it up it will be fine.
    We normally pitch the tent with the flap zipped up Tomales sure it all alligns.
    The inner flap is just to get access to the side and should not be used as a door.
  3. The Following User Says Thank You to pfgrobler For This Useful Post:
    Sep 2012
    Canberra
    Thanked: 27
    Inside zipped up
    Oct 2017
    Rustenburg
    Thanked: 2168
    If the OP takes the ladder off the flap, and zipps it up it will straighten
    Dum vivimus, vivamus!
    Nov 2019
    Thanked: 9
    Yes, it does allow me to zip up the inner flap - however not the full length/height see orange circle top right.
    My concern is the fact that the tent is not wide enough (green line) to allow me to open both side doors.Click image for larger version.
    Oct 2017
    Rustenburg
    Thanked: 2168
    Quote Originally Posted by Rolf91 View Post
    I dont understand
    The tent side doors?
    All my trailer doors can open inside the tent
    Nov 2019
    Thanked: 9
    Yes, both of my doors can open as well - but not completely. If I align the tent with the left hand side of the trailer and open both doors then the right hand side door doesn't open completely. It seems as though the tent are 100mm to 'short' in both vertical and horizontal direction. (standard suspension and tyre size). Click image for larger version.
ID:	565221Click image for larger version.
    Nov 2019
    Thanked: 9
    Yours look fine, what year model?
    Quote Originally Posted by pfgrobler View Post
    Inside zipped up
