2F gearbox on a 4.5 EFI
Results 1 to 6 of 6
    Jul 2014
    Bela Bela
    Default 2F gearbox on a 4.5 EFI
    Hi Gents
    I want to know if a 2F gearbox/bellhousing will fit on either a 3F or a 4.5 EFI motor without a adaptorplate?
    Dirk
    Henties
    Thanked: 747
    Default Re: 2F gearbox on a 4.5 EFI
    It should fit the 3F, since the 3F's 5 speed gearbox fits onto the 2F.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
  3. The Following User Says Thank You to HugoNotte For This Useful Post:
    Thanked: 2744
    The 2F had the H42 4 speed box. The H55 were a 5 speed version of the H42. Correct me if I am wrong but the 4.5EFI only came with the H150.
  5. The Following User Says Thank You to grips For This Useful Post:
  6. #4
    Henties
    Thanked: 747
    I'm sure you are right. It might fit though, since there is a lot of backward compatibility with the older cruisers.
    I'm not sure it would make sense however, since the H42 gearbox might not be able to deal with the torque of the more powerful 4.5 engine.
    2012 FJ Cruiser
    Thanked: 2744
    The H42 is a truck gearbox on the lines of the famous American NP435. The guys run v8 through them. Only problem in high torque conditions is the aluminium transfer case working it lose from the cast iron gearbox.
  8. The Following User Says Thank You to grips For This Useful Post:
  9. #6
    Jul 2014
    Bela Bela
    Perfect. Thanks a lot
