Your Lockdown Projects - Page 21
Page 21 of 28 FirstFirst ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 LastLast
Results 401 to 420 of 551
  1. #401
    Dec 2013
    Here
    Default Re: Your Lockdown Projects
    Kept myself busy with finishing off my overlander.
    Completed the Dual AGM, DCDC Changer, Water, Electrics in RTT, Silver cover, Roof Rack and Snorkel.
ID:	571280   Click image for larger version.
ID:	571281   Click image for larger version.
ID:	571282   Click image for larger version.
ID:	571288   Click image for larger version.
ID:	571289   Click image for larger version.
ID:	571290   Click image for larger version.
  2. The Following 3 Users Say Thank You to Soutie T6 For This Useful Post:
  3. #402
    Thanked: 791
    Holy #### that is sexy.
  4. The Following User Says Thank You to Toxxyc For This Useful Post:
  5. #403
    Feb 2014
    Thanked: 755
    Quote Originally Posted by Soutie T6 View Post
    Hi Soutie,
    See you installed the NL DCDC charger. Please give some feedback what you think. Itís on my bucket list.
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
  6. #404
    Durban or Centurion
    Thanked: 1268
    Quote Originally Posted by WillysCJ View Post
    Thanks for the positive comment.
    SAND you get these TV stands from Takealot. Works quite nice if you only want something that is not big or complex. That TV is never used, but we use the music part from Youtube and Spotify everyday so needed something to run this nicely.
    The come up on OnedayOnly freqeuntly for alot cheaper.
    https://www.takealot.com/one-for-all...2/PLID55072430
    Thank you for the feedback
  7. #405
    Jan 2020
    Paarl
    Thanked: 61
    Quote Originally Posted by Zapiture View Post
    Hi Soutie,
    Plus 1.
  8. #406
    May 2014
    Tshwanetoria
    Thanked: 800
    That NL DCDC is a joy to install - and use.
  9. #407
    Jan 2016
    Golf Park
    Thanked: 206
    Finished up the first gullwing storage box, just need to sort out the window seal.
    With the recent addition of a 3rd passenger we couldn't remove all the rear seats anymore so played around with ideas.
    We wanted to keep the interior trim panels and the rear seatbelts in place so it took a lot of fine trimming and re-fitting back and forth to get everything to fit nicely. Passenger side should go a lot quicker now.
    Once all said and done we would have opened up a full drawer in the rear storage drawer system we have and our little guy will have his own seat still in place without having mountains of cargo packed around him.
ID:	571327   Click image for larger version.
ID:	571328   Click image for larger version.
ID:	571329   Click image for larger version.
ID:	571330   Click image for larger version.
  10. The Following 3 Users Say Thank You to Jay_B For This Useful Post:
  11. #408
    Dec 2013
    Here
    Hi Soutie,
    It seems to work rather well, was a breeze to install.
    basically install it and forget about ur 12v issues.
    Due to the lockdown I haven't been able to test out like I want to though. I think I should have taken the 40amp but it wasn't available at my Outdoor wearhouse the day before lockdown. I'm running 2 x 105amp Discovery Batteries over kill I think but will have my coffee machine and electric blanket running nicely. Ive charged them up on the ctek and then kept myself busy with essential purchasing and everything ran like a dream (I did load the fridge with water bottles and put it on -7) with no charging after that trip I got 97 hours on the with fridge running until I reached 12,1v. I'm happy with that. The solar is now also just plug n play. no Mppt unit required all in-house. I'm using the double unit from high5solar(great unit) think its 200w. Kept batteries in the green with bakkie outside overnight and following day. This was my initial charge after running the batteries to 12,1.
    2018 wildtrak
    2019 GD6 DC 2.8
    2017 Range Rover Sport (sold)
    2016 Wildtrak (sold)
    2013 XLT (sold)
    2012 Tourneo (sold)
  12. The Following User Says Thank You to Soutie T6 For This Useful Post:
  13. #409
    Dec 2013
    Here
    Thumbs up Re: Your Lockdown Projects
    Quote Originally Posted by Jay_B View Post
    looks neat
    well done
    2018 wildtrak
    2019 GD6 DC 2.8
    2013 XLT (sold)
    2012 Tourneo (sold)
  14. #410
    Jan 2020
    Thanked: 25
    I see everyone has been keeping busy, stops you from going around the bend with Kockdown.
    I ran around like crazy getting all i could before Lock down.
    I started with my drive way where roots had lifted paving. Replace piping for electric fence and gate swing motor.
    Rebuilt a Robin EH295 engine for EZgo golf cart. Total rebuild, with rings and seals. Some left off cooling plates had to fabricate. SWtill need main crank seal.
    Rebuilt swimming pool pump for a friend still have to install when Lockdown allows.
    Made and installed timer for my 2 geysers, had to work out a relay as both geysers have 3kw elements and timer only rated at 6 amps.
    Waterproofed parapet wall as leakied into bedroom and put streaks down the wall that would not wash off, repainted wall.
    Stripped 3 WV 1600 aircooled beetle engines, rebuilt one only to find plug thread stripped, needs helicoil. Other one has broken crank, third one needs rings and bearings. Will get when Lockdown allows.
    Stripped and rebuilt Robin Eh25 engine. Was swamped with water in everywhere. Honed cylinder, made gaskets running again, just needs some work on carb as wont idle.
    Cleaned dead leaves and date branches off our palm trees, need to extend ladder to do taller trees.
    Havent had time to get bored.
  15. The Following 4 Users Say Thank You to Wylie E For This Useful Post:
  16. #411
    May 2018
    Thanked: 92
    Quote Originally Posted by Wylie E View Post
    Pictures... Or it never happened :fencelook:
  17. #412
    Oct 2015
    Thanked: 105
    Ek het vandag n ding onthou wat ek al lankal gese het ek moet doen. Mens kom dit net agter as jy jou tent wil opslaan en die tentpenne is krom gebuig. So toe buig ek bietjie tentpenne reguit.
    ONE LIFE!
  18. #413
    Feb 2014
    Thanked: 755
    Thanks, Iím now convinced. What is the price on the 40W. The controller is R1500 right?
    Zapiture,
  19. #414
    Oct 2019
    Thanked: 36
    Hi all... I finally gor around to fitting my roof rack and rtt. My rtt ladder still needs to be modified because it was cut shorter to fit on my Rangers bull bar.
    Still need to fit my front runner drawer system and duel battery
    Had a Ford Tanger 3.0l nudge bar lying around so I fitted it to the Prado... just need to make a plan and cover the Ranger inprint lol
    Fitted two commet 500 spots... just need to fit my LED light bar.
    Here are some pics...
  20. The Following User Says Thank You to Bushbuk For This Useful Post:
  21. #415
    Oct 2019
    Thanked: 36
    My pics will not download🤬
    How does add pics?
  22. #416
    Jan 2020
    Thanked: 25
    Quote Originally Posted by RoddieJ View Post
    Hi RoddieJ where do you stay? I'm in Edenglen you want to pop round and see evidence of my work around here.
    There's even more I've done that I've forgotten to add.
  23. The Following User Says Thank You to Wylie E For This Useful Post:
  24. #417
    Oct 2019
    Thanked: 36
  25. #418
    Oct 2019
    Thanked: 36
    Aah finally figured out how to upload pics.
ID:	571431Click image for larger version.
  26. #419
    √‾‾‾‾Ѵ
    Thanked: 54
    Quote Originally Posted by TJWM View Post
    Then moved outdoors. Decided the day before lockdown, I need to remove the small gate and wall on the right of my house and fit a full width gate there instead.
    Went to buy some cement and steel on last day.
    1. Lifted the paving and dig a bit of a foundation for pole.
    2. Made steel pole which gate will hang on.
    3. Fitted pole to boundary wall and pinned pole foot in concrete foundation.
    4. Cut existing paving to lower and level it for new bigger entrance.
    Lowered the paving to create even surface at new entrance. (still need to remove the nutec dust covering the paving)
    Added some cement pavers on inside.
    Made and fitted the gate.
    My trailer have a new parking spot.
    -Tobie-
    '18 Ford Everest 3.2 Limited 4x4 Auto
    '17 Ford Kuga 1.5T Trend Auto
    '18 Jurgens XT65B
  27. The Following 3 Users Say Thank You to TJWM For This Useful Post:
  28. #420
    Apr 2018
    Umhlanga
    Thanked: 659
    Great job. Well done.
    Perhaps it would be thoughtful to either build a small brick step in front of the water meter & tap, or perhaps a metal bracket or cage around the water meter and tap, just as a precaution to protect them from accidentally being hit by the trailer wheel when reversing the trailer into the parking area or out again.
    I met some crazy people.... They made me their leader.
    2014 Mazda BT-50 - Recently bought. March 2018
    2013 Nissan NP300 - Daily workhorse
    1993 Ford Courier 2.2... Odometer stopped working just over 530'000 km's. Sold 2013
    69' Series 2 Landi - Old, slow, thirsty. Go anywhere. Stolen in 2010
