Your Lockdown Projects - Page 9
Page 9 of 24 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... LastLast
Results 161 to 180 of 478
  1. #161
    Nov 2012
    Thanked: 976
    Default Re: Your Lockdown Projects
    Just finished a lectern for the school
    Choose life
  2. The Following 8 Users Say Thank You to Coenoes For This Useful Post:
  3. #162
    Thanked: 276
    Quote Originally Posted by Coenoes View Post
    Beautiful! What wood is that?
    Cruiser 76 V8
    Disco 4 XS
  4. #163
    Oppierotse
    Thanked: 260
    So for todays Lockdown DIY I made a nifty carry handle for car batteries. Makes its so much easier. Can't believe I'm the first to think of this
    The battery will last longer if you use these ones. They clamp on the sides of the battery.
    https://www.mechanictoolset.reviews/...ttery-carrier/
    98 Hilux 2.8D D/C 4x4
  5. The Following User Says Thank You to wiel For This Useful Post:
  6. #164
    Feb 2014
    Thanked: 699
    Quote Originally Posted by PeetS View Post
    I am working from home, but inbetween I get to work on these:
    Attachment 565964
    Silky Oak Salad Bowl 260 mm diameter
    Attachment 565965
    African Wattle (Huilboom) and Resin - 450 mm and this one requires a lot of sanding - ! am about halfway done with it. It came apart halfway through the turning process and my wife patched it with resin.
    Love the resin insert. Hi 5 to your wife. Do you mind telling me where you get your resin and what’s the price?
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
  7. The Following User Says Thank You to Zapiture For This Useful Post:
  8. #165
    Mar 2012
    Pierre van Ryneveld
    Thanked: 3916
    Since the school's closed down I've been doing a few of these projects. Too many to count.
    Lego Woody and Lego RC, has been keeping me company at the table since lockdown started.
    I thought we had too much Lego's a while ago, but since COVID-19 lockdown, came to the realization again that one cannot have too many Lego's
  9. #166
    Mar 2012
    Pierre van Ryneveld
    Thanked: 3916
    Quote Originally Posted by Zapiture View Post
    Not sure where he gets his. I've shopped around and got the best variety at decent prices from AMT Composites https://www.amtcomposites.co.za/
    They are on my way to work, and have only been very keen to assist when you visit them.
  10. The Following User Says Thank You to Redman For This Useful Post:
  11. #167
    Nov 2012
    Thanked: 976
    Quote Originally Posted by wildhunter View Post
    Kiaat
    Here is the before photos
    Choose life
  12. The Following User Says Thank You to Coenoes For This Useful Post:
  13. #168
    May 2015
    Krugersdorp
    Thanked: 9
    I am not as handy as the rest on here, but not to bad for my first try. I am 100% off grid with water now as I have installed the tank and booster pump with the borehole. I have made the decorative wood/ hat hanger for the entrance and I have made the privacy screen next to the swimming pool.
ID:	565991   Click image for larger version.
ID:	565992   Click image for larger version.
ID:	565993   Click image for larger version.
ID:	565994   Click image for larger version.
ID:	565995   Click image for larger version.
ID:	565996   Click image for larger version.
ID:	565997   Click image for larger version.
  14. The Following 3 Users Say Thank You to Bibendum For This Useful Post:
  15. #169
    Thanked: 341
    Quote Originally Posted by Redman View Post
    AMT is where we get ours. The have what they call Woodcast 30. We normally get the 8Kg pack - 5 kg resin and 3 kg hardner. Bought just before lockdown and the price was < R1300.00.
    https://www.amtcomposites.co.za/prod...odcast-30-8kg/
    Peet Schultz
  16. The Following User Says Thank You to PeetS For This Useful Post:
  17. #170
    Jul 2016
    Thanked: 493
    Finally got round to fitting the bracket about a year after i bought it
  18. The Following 2 Users Say Thank You to MikeBob For This Useful Post:
  19. #171
    Krugersdorp
    Thanked: 35
    wat se voorstelle het julle vir 2 stukke alu channeling en redelike size plywood, ek het baie gawe buurman
ID:	566004   Click image for larger version.
Name:	ALu channel.jpg
  20. #172
    Langs die rivier, op n berg
    Thanked: 2867
    Propshafts was nogal n issue.
    Die 230 is baie korter as die 250 engine, maar hulle gebruik selfde auto box.
    So die 230 en gearbox is sowat 200mm vorentoe geskuif in body.
    230 het dun propshaft, met 3 dele en 2 centre bearings.
    250 het obviously korter propshaft. Baie dikker. Net 2 dele en 1 centre bearing.
    Gedig ek kon net die 230 se hele propshaft op 250 body met 230 engine gebruik, maar 250 body het nie mounting punte vir 2de centre bearing nie.
    Gelukkig pas n 300d manual se voorste deel van prop op 250 se agterste deel, maar is presies regte lengte vir die 230 se engine. En ek het een op my scrap hoop.
    Attachment 565807
    Ek was te optimusties.
    Die propshaft lengtes werk nie.
    Maar na gesukkel het ons darem kar gestart. Engine se timing nog uit. Met geen olie, het hidroliese timing chain tensioner gaan le, en distrubuter drive het tande gespring. Nou moet ek net gou timing weer perfek in kry.
    En dan die 230e se propshaft bekyk. Hy kry n v8 in, so hele drivetrain kom uit. Hopenlik is daar iets wat ek kan gebruik van sy propshafts op die 230/250 hybrid.
  21. #173
    Thanked: 2867
    Maar nou gou eers die 380se uit trek, en kyk if ek nie sy auto box aan loop kan kry.
    Het steek vas soos n hardkoppige merrie, en pomp geen atf ook nie.
    Hopenlik sal n filter change iets verander.
  22. #174
    Thanked: 2867
  23. #175
    Oct 2007
    Thanked: 15
    Hopefully this will help in moving the Xplorer around.
ID:	566068   Click image for larger version.
  24. #176
    Feb 2014
    Thanked: 699
    Thanks, will give them a try. I tried resin a couple of years back but really battled to turn it. I’m keen to try again.
    Zapiture,
  25. #177
    Feb 2014
    Thanked: 699
    Using lockdown to remodel SWAMBO’s consulting room so we need to install cupboard with wash basin. Have the material on hand, so here we go:
    Install ornamental trimming:
    Prepare the room for installation of the two uprights
    Check uprights in place and mark positions for fixtures:
    To be continued.......
    Zapiture,
  26. The Following User Says Thank You to Zapiture For This Useful Post:
  27. #178
    George
    Thanked: 82
    Attachment 565964
    Attachment 565965
    Hi daar Peet, het jy baie silky oak hout? Ek het klomp jare terug planke van silky oak laat saag, ek het paar sny planke al gemaak, baie splinters tot jy hom begin skuur. Het laasweek melkhout planke af geskuur
ID:	566079   Click image for larger version.
  28. #179
    durban
    Thanked: 1013
    I started making a trolley for my loadshedding battery and inverter. I do not weld well. I hate welding pipe cause its difficult but thats all I got.
    My project didnt start well because I used my table to support the pipe in a vertical position but realized I welded my trolley under the table which is bolted to the floor and is very heavy.I had to use a floor jack to get it out
    Found some wheels from a wheelchair i made for my dog. But my dog can now walk (like a drunken sailor) so I can use them.
    Made some axles .
    Worked on getting some decent joins .
    I like to blame my tools for my inadequacies.When I weld this chinese metal behaves like its got something in it. It will weld well and then suddenly spark and make popping noises and fizzle.
    I got to make use of my homemade pipe bender.
    Almost there.
  29. The Following 2 Users Say Thank You to plunger For This Useful Post:
  30. #180
    Thanked: 341
    Quote Originally Posted by emileheyns View Post
    Hi Emile, nee, het so paar stukke gekry saam met die eerste draaibank wat ek gekoop het. Jy is bevoorreg om melkhout te he, draai ook lekker!
    Peet Schultz
