Your Lockdown Projects - Page 8
Page 8 of 28 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... LastLast
Results 141 to 160 of 553
  1. #141
    Nov 2011
    Langebaanweg
    Thanked: 1213
    Default Re: Your Lockdown Projects
    Quote Originally Posted by jeev View Post
    I am finishing diy door post rebuild with my limited ability to weld on my series 3 Landy. While vehicle stood during fitting nissan RD 28 series2 engine door posts rusted . Decided to diy door post but needed adjustment to align doors better. Test drive with rd engine saw clutch pressure plate failing to disengage fully . Removed engine modified pivot pin length. Now Working well. Keeping 2.25 series petrol engine just in case. I did complete engine conversion from 2.25 petrol to diesel rd28 myself . PS.I am an electronics tech
    Not sure what's going on with the firewall but it looks bad.
    I would suggest you remove it,strip it and try to repair it....
    Or replace it.
    Secondly that screw ontop of the fender top.
    Something doesn't look right there.
  2. #142
    Wartburg.
    Thanked: 635
    Quote Originally Posted by wildhunter View Post
    Another knife and sheath complete.....I could get used to this lockdown thing
    That is a very, very nice knife!
    I have one very similar in shape and size, a working knife of cause, and between all the knifes it's always the go to knife when skinning and even cutting up meat.
    Very nice, well done!!
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  3. The Following User Says Thank You to Chris8d For This Useful Post:
  4. #143
    Wartburg.
    Thanked: 635
    Here it is.
ID:	565744   Click image for larger version.
  5. The Following 2 Users Say Thank You to Chris8d For This Useful Post:
  6. #144
    Langs die rivier, op n berg
    Thanked: 3181
    Het die 250 uitgekry.
    Die 230 se sump is deurgeskuur gewees. Dit is opgeweld, en 230 is in kar in. Het vergeet om foto te neem.
    Het keuse gehad tussen 230 en 230e engine om in te sit, maar het teen 230e besluit (al is dit seker een van beste w123 engines), want beide die 250 en 230 is carb karre, en het nie die pype en hoe druk pompe en alles wat nodig is vir brandstof inspuiting.
    230 het n 200 se stromberg side draft carb op, wat die plunger bo op carb kort. Wonder waar ek dit gaan kan kry.
  7. #145
    Apr 2008
    Thanked: 32
    That looks proper.Well done.
  8. The Following User Says Thank You to schoemie For This Useful Post:
  9. #146
    Apr 2008
    Thanked: 32
    Also got gatvol of the small bedside tables with barely any space on it and started making some shelves also of pine.
    I don't know why the frekkin pics rotates when uploading and I'm too stupid to fix it.
    Next job would be to hide and reroute the electrical and lan cables behind the wooden wall.
    Looks good.(both the wall and bedside tables )
  10. The Following User Says Thank You to schoemie For This Useful Post:
  11. #147
    Apr 2008
    Thanked: 32
    [QUOTE=Pietsweis;4363820]Attachment 565465Attachment 565466
    My first knife almost done
    Just etching my name and sharpen and all done.
    Lockdown allowed me to accelerate the little project[/QUOTE
    That is good looking and great for a first effort.
  12. The Following 3 Users Say Thank You to schoemie For This Useful Post:
  13. #148
    Nov 2012
    Kuruman
    Thanked: 19
    So for todays Lockdown DIY I made a nifty carry handle for car batteries. Makes its so much easier. Can't believe I'm the first to think of this
  14. #149
    Aug 2015
    germiston
    Smile Garage door seal
    Quote Originally Posted by jice View Post
    I replaced the floor rubber for my garage door yesterday.
    Today I fixed two gas braais, cleaned and some of the holes was rusted closed on the second one so I drilled it open.
    First braai was a salvage, friend of mine wanted to chuck it away due to the pipes being blocked and the knobs was stripped so luckily I bought the parts a few months ago, in for about R500 and I have a new braai. Attachment 563863Attachment 563864Attachment 563865
    Where did you buy garage door seal,please send me a shop name as i am also staying around Alberton area.Smega
  15. #150
    Wilderness
    Thanked: 1255
    You are in for a heated discussion, on an explosive topic!
    Pieter Kemp.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  16. #151
    Nov 2011
    Langebaanweg
    Thanked: 1213
    Yes, you're right. I missed that.
    Hand warmer. Unless it's insulated.
  17. #152
    Mar 2007
    Harties Boet
    Thanked: 889
    Whenever Iím finding a gap between work and a toddler, Iím fiddling on the lotus 7. Fixing, tweaking, cleaning.
    cleaned and polished the carbs:
    Graham Robertson
    Nissan Patrol 4.8
    Nissan Patrol 4.2td
  18. The Following 2 Users Say Thank You to Graham For This Useful Post:
  19. #153
    Thanked: 3181
    Propshafts was nogal n issue.
    Die 230 is baie korter as die 250 engine, maar hulle gebruik selfde auto box.
    So die 230 en gearbox is sowat 200mm vorentoe geskuif in body.
    230 het dun propshaft, met 3 dele en 2 centre bearings.
    250 het obviously korter propshaft. Baie dikker. Net 2 dele en 1 centre bearing.
    Gedig ek kon net die 230 se hele propshaft op 250 body met 230 engine gebruik, maar 250 body het nie mounting punte vir 2de centre bearing nie.
    Gelukkig pas n 300d manual se voorste deel van prop op 250 se agterste deel, maar is presies regte lengte vir die 230 se engine. En ek het een op my scrap hoop.
  20. The Following User Says Thank You to Reenen For This Useful Post:
  21. #154
    Thanked: 374
    AWNING - Some thoughts
    Currently I am very happy with my Alucab 270 Shadow AWN. This suits my camping style (move every day) and I need something that I can pack up on my own. (Bad experience with 2 previous awnings). Only problem with my latest vehicle (L/C S/C with Bushlapa camper) the stove section is exposed to the rain.
    I have an industrial sewing machine and I do all my own sewing. I bought some canvas (from marine supplier Texwise) and am looking to add a piece that will cover the stove area. There is already velcro down the inside of the existing awning. I will then add a piece (attached by velcro - can change if this not strong enough) and then add an extra pole. So basically adding a triangle with a self standing pole. The one side I can attach to the roof rack (tie down), the other side will attach to the existing awning (velcro) and then a pole on the third corner.
    This can be attached only when needed and there is more than enough space for storage.
    Would a free standing pole work??
    Finally got rid of that annoying sound in the 4x4, opened the door and pushed him out
  22. #155
    Gaborone
    Thanked: 25
    Eers die trekkers reg kry, dan een van die v8ís uit kry om met Mercedes aan te gaan
    Attachment 564093
    I'd like to hear the story behind the Hurse...
    Hennie
    Ford Ranger Wildtrak 4x4
    Disclaimer: The views expressed by me in the above thread and replies are based on my personal experience and perceptions, which may be subjected to change from time to time.
    ORRA Call Sign B165
  23. #156
    Friemersheim, Southern Cape
    Thanked: 3380
    https://www.4x4community.co.za/forum...ild?highlight=
    Quote Originally Posted by Smiles View Post
    Robert van den Berg
  24. #157
    Thanked: 2260
    Relax you're not, old vintage design been aroung as long as I can remember. Had one lying around for many years, old stuff was made with cotton webbing, did not like the battery acid. Replaced it with a section of fan belt and voila never got eaten after that.
    Henk
    Follow us on Facebook
  25. The Following User Says Thank You to hbannink For This Useful Post:
  26. #158
    Oct 2017
    Thanked: 43
    Down lighters turned into up lighters
  27. #159
    Sep 2017
    Thanked: 189
    Quote Originally Posted by Recovery View Post
    That's very cool. Can build up a thirst staring at that.
  28. #160
    Thanked: 352
    I am working from home, but inbetween I get to work on these:
    Silky Oak Salad Bowl 260 mm diameter
    African Wattle (Huilboom) and Resin - 450 mm and this one requires a lot of sanding - ! am about halfway done with it. It came apart halfway through the turning process and my wife patched it with resin.
    Peet Schultz
  29. The Following User Says Thank You to PeetS For This Useful Post:
