Your Lockdown Projects - Page 5
Page 5 of 28 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 81 to 100 of 553
  1. #81
    Langs die rivier, op n berg
    Thanked: 3181
    Default Re: Your Lockdown Projects
    Van Mercedes van trailer af laai, tot engine en gearbox op stand hÍ, het on 3 middeljarige ou ballies 70 min gevat. Eintlik nie my, want ek het heelpad op n ou bmw seat met my been in die lig gesit...
  2. #82
    Dec 2016
    Thanked: 17
    Het begin voor die lockdown maar my tafels vorder goed, gaan na my braai plek gemaak uit pallet houtClick image for larger version.
ID:	564827Click image for larger version.
ID:	564828Click image for larger version.
  3. The Following 2 Users Say Thank You to bhwiid For This Useful Post:
  4. #83
    Dec 2016
    Thanked: 17
    Hi wat is the size of the trailer and what is the main frame made off.
    Quote Originally Posted by CvdN View Post
    Well, started slowly before lockdown but the plan obviously changed over the past week or so...
    Original plan was to refurbish this old trailer. It belonged to my Father, and stood neglected and unused for many years.
    Attachment 564122
    But after I stripped it down I found it was badly misused and overloaded at some point in time. Frame was bent, rivets pulled loose, box was bent, everything misaligned etc
    With so many things to fix I thought might as well build a new one, for the same work and a bit more money (or a bit was what I thought at the time lol!). Decided something a little bit bigger and more robust. It's purpose would be to store camping stuff, and hitch it up already packed when needed. Then the kids managed to talk me into fitting a rooftop tent, because they thought it would be cool . Did not take all that much convincing...... And so plan then evolved rather quickly into building a fully fledged camping trailer. Would love a new Mission trailer, but not willing to spend the money. So, with some weight calculations done and a design of some sorts in my head it was off to the steel dealers, and sleepwaparte....
    This was progress at the start of lockdown:
    Attachment 564124
    And then lockdown was announced. Still have to work from home, but I knew I would have some time on hand.... A mad and crazy rush to get more material and all sorts of goodies together ensued, but fortunately I managed to get a handsome number of things together to keep my from going crazy in 21 days
    Got most material, hinges, bolts and nuts, slides, paint, sealant, latches etc....just in time!!
    So, after 4 days:
    Mock-up with axle, wheels & fenders to check dimensions correct - and to check height so that I know which tent to get. Will be Tentco junior 1.45m.
    Attachment 564125
    Welded...
    Attachment 564126
    Attachment 564127
    Etch primer applied:
    Attachment 564131
    And then decided, just in case there were some pinholes or imperfections, to seal all welds with PU sealant:
    Attachment 564132
    And then 2 coats Polyurethane bakkie lining with a stipple roller (because I like the textured finish):
    Attachment 564133
    Hoping to install jockey wheel, leave springs, axle and wheels today - if the paint is cured properly. It was rather cool and wet last night. Then I can start with the box (or is it the body?). Only 16 days left....
    Keep safe everyone!
    Work (Real work ) kept me busy today. Axle, wheels, stabilizer struts and jockey wheel fitted.
    Attachment 564242
  5. #84
    Dec 2018
    springs
    Thanked: 20
    Quote Originally Posted by bhwiid View Post
    All mild steel. Frame is 100x50x2 rect tubing. box frame 38x38x2 sq tube.
    Door frames will be 19x19x2 sq tube and skin will be 1.2mm sheet.
    Box dimensions are 1800Lx1250Wx900H
    Nose box still to come, will be approx 900X600X600
    overall width is 1790mm, overall length is approx 2900mm
  6. #85
    Thanked: 14991
    Molasses and sugar wash for a rum.Click image for larger version.
    Jakes Louw
  7. #86
    Dec 2016
    Thanked: 17
    [QUOTE=Abe53;4358067]
    Quote Originally Posted by MrTolbos View Post
    Started a few days before the lockdown already, but thankfully got 99.9% of the bits and pieces together before all the shops closed. Diy Solar installation at home:
    Hi Tolbos, congratulations on a very neat PV solar installation!
    What batteries do you use? Reason asking, I am building a lithium powerwall.
    Where do you het your Lithium battries from
  8. #87
    Feb 2016
    Thanked: 979
    Default Your Lockdown Projects
    Quote Originally Posted by Abe53 View Post
    Thanks Abe. Unfortunately I had to skip the lithium for now. I was hoping to buy 6x pylontech's when the next shipment arrive again, but Iíll rather wait until the exchange rate comes back to earth.
    For now Iím using 4x Deltec AGM 100Ah batteries, which is way too little, but itís already saving 70% of our daily consumption. At least we will be able to skip through the next bombardment of loadshedding, when ever it starts again.
  9. The Following 2 Users Say Thank You to MrTolbos For This Useful Post:
  10. #88
    Lonehill (JHB)
    Thanked: 26
    Busy making a rocket stove
    2014 Ford Ranger 3.2 XLT 4x4 D/C Auto
    2018 Ford Everest 2.2 XLS 2x4 auto (SWAMBO)
    Echo 4 trailer
  11. The Following 2 Users Say Thank You to ChrisH For This Useful Post:
  12. #89
    Wilderness
    Thanked: 1255
    [QUOTE=hatjohan;4358793]Are you expecting trouble? [/QUOTE
    Only making sure that i have enough when needed. The wife and myself also do IPSC 3 gun. The ammo will not go to waste either way.
    Pieter Kemp.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  13. #90
    Thanked: 3181
  14. The Following User Says Thank You to Reenen For This Useful Post:
  15. #91
    Melkbosstrand
    Thanked: 474
    Lyk of jy lekker supervise...
    Everybody needs to believe in something.... I believe I will have another Beer!
    Travel Blog: https://since1652.wordpress.com/
    https://www.instagram.com/since1652travel/
  16. The Following User Says Thank You to Papsak For This Useful Post:
  17. #92
    durban
    Thanked: 1178
    I love the work shoes.
  18. #93
    Mar 2012
    Thanked: 3955
    Still not getting to my two projects that I've been planning.
    But, on a bit of a mission at the moment. Already made the cupboard for the drill-bits and other goeters. Used some off cuts to make a little wooden box for the wife to organised the laundry soap, stain remover and fabric softener. (don't ask, the women likes to keep it organised)
    Then had the idea to use old PVC pipe next to my little cupboard. Some holes and support and it works great for plastic bags (checkers sakke). Just loop the bottom of the one bag through the ears of the next one and it feeds a new bag when one is pulled out.
    Pieter Kruger le Roux
  19. The Following 5 Users Say Thank You to Redman For This Useful Post:
  20. #94
    Sep 2015
    Thanked: 149
    Default Jimny Load Space
    Wanted to do something like this for a while, and this Corona thing took away my excuses for not starting....
    Plus I had a bunch of old ply from packing cases, that I cut up, joined, and laminated together according to the plan from the "Ore Rak",
    thanks Ore
Name:	01 Start.jpg
    I also glued some 40x10 Pine battens on the bottom for extra strength.
    And chief Quality Control Inspector made an appearance...
Name:	02 Quality Control.jpg
    Started the metal work....
Name:	03 Metal Work.jpg
    Measure twice, cut once.....
Name:	04 Square.jpg
    Nice straight, perpendicular holes...
Name:	05 Straight Holes.jpg
    Measure again....
Name:	06 Assembly.jpg
    Coming together...
Name:	07 Final Fit.jpg
    Bottom view of Pine slats after painting....
Name:	08 Bottom View Paint.jpg
    Top View...
Name:	09 Top View.jpg
    Padding for armrests....
Name:	10 Padding for the Armrests.jpg
    Load Test
Name:	11 Lots of Space.jpg
    I still want to stick thin dark grey carpet tiles on the top surface, and maybe get the metal work powder coated black.
    Also, the seats are still in, and I need a way to stop the load deck from moving during extreme manoeuvres ...
    And maybe some support from underneath to help spread the load away from the arm rests.
    I have run out of wine, therefore also ideas on what do once I thake the seats out
    Jimny, the most underestimated 4x4xfar
  21. The Following 3 Users Say Thank You to Gustav Jimny For This Useful Post:
  22. #95
    Dec 2014
    Warmbad
    Thanked: 14
    Catching up on some home improvement and maintenance but also working on spreading the word about misinformation leading to world-wide panic and more. For example, see attachment and: https://www.youtube.com/watch?v=fC0C...ature=youtu.be
  23. #96
    Mar 2020
    Project no 2. turn some pallets into refurbished deck furniture
    2001 Defender 90 TD5
  24. The Following 3 Users Say Thank You to phhenning For This Useful Post:
  25. #97
    Mar 2020
    Project No 1, Sliders for the Defender
  26. The Following User Says Thank You to phhenning For This Useful Post:
  27. #98
    Feb 2014
    Thanked: 781
    Quote Originally Posted by Gustav Jimny View Post
    thanks Ore
    Very nice. Well done!
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
  28. #99
    Feb 2014
    Thanked: 781
    Quote Originally Posted by Langjan View Post
    Catching up on some home improvement and maintenance but also..........
    [/U]
    Not the thread for this please. There are way more than enough threads and forums for you to do just that. On this thread we are focusing on what we can do despite the horrendous circumstances.
    Please consider removing your post
    Zapiture,
  29. The Following 5 Users Say Thank You to Zapiture For This Useful Post:
  30. #100
    Sedgefield
    Thanked: 79
    Cleaned up the workshop and finally built swambo her makeup cabinetClick image for larger version.
ID:	565266Click image for larger version.
ID:	565267Click image for larger version.
ID:	565268Click image for larger version.
ID:	565269Click image for larger version.
    Toyota
    2019 Toyota 2.8 GD-6 4x4 Raider DC Auto
  31. The Following 2 Users Say Thank You to Iggi For This Useful Post:
