Your Lockdown Projects - Page 26
Page 26 of 28 FirstFirst ... 16 17 18 19 20 21 22 23 24 25 26 27 28 LastLast
Results 501 to 520 of 551
  1. #501
    Thanked: 948
    Default Re: Your Lockdown Projects
    Ek het myne met 2 krywa wiele gemaak. Met bottel plat onder trollie. Moet te veel buite stoor skuif op die gravel op, so klein wiele steek vas. Bottel plat, want as regop, is ek bang dit neuk om.
    The full size Teral gas cylinder for the MIG is on a separate trolley and connected with a 10 meter hose so I don't have to move it around much in the garage. The Argon cylinder the is going on this cart is a half length cylinder so it's not going to be top heavy.
    I've always been told not to use any compressed gas cylinder in a horizontal position. All the welding gas literature I've seen doesn't recommend using the cylinder lying down. If it works for you great but I'd rather not tempt fate.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  2. The Following User Says Thank You to Paul#25 For This Useful Post:
  3. #502
    May 2018
    Paarl
    Thanked: 84
    Built a small compressor for leather air brushing work.
    I can also use it any place where I have a 12v battery - usefull for pneumatic nail- and staple gun applications.
Name:	Mini Kompressor.jpg
ID:	574197   Click image for larger version.
ID:	574198   Click image for larger version.
ID:	574199   Click image for larger version.
  4. The Following 4 Users Say Thank You to Dirkba For This Useful Post:
  5. #503
    Sep 2014
    Thanked: 130
    A pic please
    Wolverine : 93' Range Rover Classic 3.9L EFI
  6. #504
    Langs die rivier, op n berg
    Thanked: 3037
    Quote Originally Posted by whosthejman View Post
    A pic please
  7. The Following User Says Thank You to Reenen For This Useful Post:
  8. #505
    Thanked: 948
    I was asked to assemble a smaller than normal roof-rack for a client. The frame that I put together will fit onto the Thule rails he has on the roof of his HiLux double cab. He has a rooftop tent on the canopy so needs the shorter frame just on the forward part of the cab.
    The frame is made from 16mm square tube with 1.6mm wall thickness and weights in a 11kg. The bottom bars will be covered with Meranti tongue and groove panels. Click image for larger version.
ID:	574655Click image for larger version.
ID:	574656Click image for larger version.
ID:	574657Click image for larger version.
ID:	574658Click image for larger version.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
  9. #506
    Thanked: 948
    After the wood has been fitted. Click image for larger version.
ID:	574679Click image for larger version.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
  10. The Following 2 Users Say Thank You to Paul#25 For This Useful Post:
  11. #507
    Sep 2016
    Thanked: 4065
    We started a two thousand piece puzzle
  12. The Following 2 Users Say Thank You to Roberto Betta For This Useful Post:
  13. #508
    Klipriver
    Thanked: 291
    Quote Originally Posted by Roberto Betta View Post
    Very nice, bit small though
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
  14. #509
    Oct 2017
    Paarl
    Thanked: 30
    Well done, like the retro look!
  15. The Following User Says Thank You to Ben Coetzee For This Useful Post:
  16. #510
    Nov 2019
    Thanked: 17
    That looks really good
    1999 Pajero 3500 v6 LWB (Poncho) - Overland/camping project (Build log)
    2006 Ford Ranger XLT Double Cab - Daily
  17. #511
    Thanked: 948
    Here the final product is fitted to the HiLux. The ladder is the same one that is used to access the rooftop tent. Click image for larger version.
ID:	574834Click image for larger version.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
  18. #512
    Thanked: 542
    Quote Originally Posted by Mr.G View Post
    Stripped my harley.Bought new bags,tank wheel etc last year.Sent in for a new spray job which i got back last week so im rebuilding through this time.
    It sucks that when you need something basic you cant just go out and buy now,so i cant really finish 100% until after lockdown
    Here is the nearly completed project
  19. The Following 8 Users Say Thank You to Mr.G For This Useful Post:
  20. #513
    Feb 2012
    Mindalore
    Thanked: 112
    Made a drawer system for a friend
    One Wife - Livid
  21. The Following 2 Users Say Thank You to overambitious For This Useful Post:
  22. #514
    Thanked: 268
    Scary wall on the left.
    If the rolls were in plastic, the could be stent whatevers
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
  23. #515
    Thanked: 268
    And the drawer system looks very well done.
    Robbie
    Fortuner D4D
  24. #516
    Struisbaai
    Thanked: 875
    Very nice drawer system there.
    Where did you get the carpet to cover it please.Im busy with the same project now for the Prado.And what glue did you use.
    2015 Land Cruiser 79 D/C V8 Diesel Turbo
    2000 Prado 90 KZTE SWB.
    Bush Lapa Boskriek No 607 - Die Kriek
  25. #517
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 1396
    Quote Originally Posted by Robbief View Post
    Poacher snares.
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    BMW R1200GS & GSA
  26. #518
    Feb 2012
    Mindalore
    Thanked: 112
    No, I'm definitely not to be trusted with anything medical related. Those are casings for automotive cables, like accelerator cables etc
    One Wife - Livid
  27. #519
    Feb 2012
    Mindalore
    Thanked: 112
    Quote Originally Posted by LC Man View Post
    I'm using acoustic carpet, it's available from any of the upholstery suppliers and it's not very expensive. About R25 a metre.
    For glue contact adhesive works best. I prefer to buy the spray can version as it's just easier to work with.
    One Wife - Livid
  28. The Following 2 Users Say Thank You to overambitious For This Useful Post:
  29. #520
    May 2018
    Paarl
    Thanked: 84
    Hi LC Man,
    Waltex Carpets CC
    121 Rissik St, Beaconvale, Parow, Cape Town, 7500
    I used
    Alcolin Hi Tack Carpet and Vinyl Adhesive to stick my carpet material down, but any contact should do. However if carpet material is too thin you might have a problem if the contact saturated the material. It becomes hard and show signs of cracking with use.
  30. The Following User Says Thank You to Dirkba For This Useful Post:
