Your Lockdown Projects - Page 17
Page 17 of 28 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... LastLast
Results 321 to 340 of 553
  1. #321
    Langs die rivier, op n berg
    Thanked: 3188
    Default Re: Your Lockdown Projects
    Veelvuldige projekte op blad vandag
  2. #322
    Nov 2012
    Gordons Bay
    Thanked: 19
    Other parts are CNC milled Masonite coated in Dark Copper Rustoleum Paint.
    Hi Fluffy
    What CNC router do you have? I am after one, happy to build one myself...The retail versions I have looked at that were decent were very expensive. I want to mill wood & plastic.
  3. #323
    Phalaborwa
    Thanked: 7
    That looks scary.
    Got it sorted all working 100 % now. What a nightmare just happy it is done
  4. The Following User Says Thank You to J&J For This Useful Post:
  5. #324
    Feb 2014
    Thanked: 782
    Quote Originally Posted by Zapiture View Post
    Using lockdown to remodel SWAMBO’s consulting room so we need to install cupboard with wash basin. Have the material on hand, so here we go:
    Install ornamental trimming:
    Prepare the room for installation of the two uprights
    Check uprights in place and mark positions for fixtures:
    To be continued.......
    Progressing nicely:
    Bulkhead:
    Check door dimensions:
    Install counter top. To be covered with marble:
    Starting to look like something:
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
  6. The Following 4 Users Say Thank You to Zapiture For This Useful Post:
  7. #325
    Sedgefield
    Thanked: 83
    Made a peanut bowl and tried my hand at making a end grain chopping board, quite happy with the resultsClick image for larger version.
    Toyota
    2019 Toyota 2.8 GD-6 4x4 Raider DC Auto
  8. The Following 4 Users Say Thank You to Iggi For This Useful Post:
  9. #326
    Mar 2015
    Thanked: 354
    Very nice Iggi.
    Quote Originally Posted by Iggi View Post
  10. The Following User Says Thank You to Tom13 For This Useful Post:
  11. #327
    Thanked: 122
    I had some work requiring compressed air but this also entailed moving the compressor from its usual hiding place. I noticed some oil down the side and realised I had not checked the oil level for some time, not that my compressor is an everyday use item.
    Anyway, cleaned up the mess and noticed the head bolts were loose. Tightened these to the required torque (draai tot hy strip en dan 'n kwart terug....!) - not quite, but just nice and tight.
    Since I still have some LD time to sort out the garage, I could not locate the bottle of comressor oil which I know I have somewhere. Topped up with some 5w30 from the Ranger's stash. I will need to change the oil at some stage in the not too distant future. What oil other than dedicated "compressor oil" do you use?
    Also, there's the viewing glass which can seemingly be removed with a spanner. Is this where you drain the oil?
  12. #328
    Thanked: 3188
    Vat bietjie af oor lang naweek.
  13. The Following 8 Users Say Thank You to Reenen For This Useful Post:
  14. #329
    Helderkruin
    Thanked: 442
    Reenen die fotos is baie mooi jo
  15. The Following 2 Users Say Thank You to Leon Venter For This Useful Post:
  16. #330
    Wilderness
    Thanked: 1258
    Jou gelukkige blik...skottel. Ek bly 300m van die see af en al wat ek kan doen is kyk.
    Pieter Kemp.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  17. #331
    Nov 2006
    Perth, Australia
    Thanked: 362
    Default Your Lockdown Projects
    We did not really have a full lock down like you guys, but we are not allowed to venture out of our postcode areas. So no camping or weekend drives.
    Bought an old Fronius Tig welder on Gumtree for $80.
    Turns out the guy selling it is an ex Saffer and he got it from a mate in Zim before he came over to Kangarooville.
    Always wanted to weld aluminium.
    Set it up at home in the garage and actually managed to melt some of the coupons together. Tricky stuff that alu....
    Also got a bow a while back. Never got time to practice. Now I have time....
    No more Jeeps for me for a while.
    2009 Ford Ranger PK 3.0
  18. The Following User Says Thank You to jdjoubert For This Useful Post:
  19. #332
    Phalaborwa
    Remember to check your towball weight after you loaded that nosecone.
    Ja, Johan! Dit is BAIE goeie raad! Ek het my waentjie te swaar gelaai voor, en die hele voorste A frame het losgebreek in Botswana! Dit was 'n duur les! Laai reg!!!
  20. #333
    Jan 2014
    Thanked: 9
    Work in progress
    Making this couch which can turn into a sleeper couch by hand from sleeper wood and origin pine
Name:	sleeper couch.jpg
ID:	569139   Click image for larger version.
Name:	sleeper couch open.jpg
  21. The Following 2 Users Say Thank You to danie1957 For This Useful Post:
  22. #334
    Phalaborwa
    Relax you're not, old vintage design been aroung as long as I can remember. Had one lying around for many years, old stuff was made with cotton webbing, did not like the battery acid. Replaced it with a section of fan belt and voila never got eaten after that.
    Attachment 565948
    Hoe werk die ding?
    1. Sit jy dit op jou battery pole om hom te dra?
    2. Breek hulle nie af nie?
    3. En hoe werk hy met 'n deep cycle battery wat die dun skroefdraad pole het?
    Ek is maar dom!! Help my asb!!
  23. #335
    durban
    Thanked: 1178
    my grand daughter has colic. Any recommendations on how to deal with colic? She battles to fall asleep and we cant put her in the car for a drive and I get tired and bored pushing a pram so I made a simple proof of concept. Now I just need to fine tune.
    https://www.youtube.com/watch?v=ArzUlYtfG3Q
    Now we can leave her in the workshop
  24. #336
    Thanked: 15097
    Boereraad mengsel. Buy it at the chemist.
    Jakes Louw
  25. #337
    Nov 2011
    Langebaanweg
    Thanked: 1221
    Put baby in carry cot, put carry cot on tumble dryer and dry some clothes.
    Might cost some ESKOM randellas.
    Worked every time with our daughter.
  26. #338
    Nov 2011
    Thanked: 1021
    Love your practical approach!
    - Charles Bukowski
  27. #339
    Dec 2013
    Reebok, Mossel Bay
    Thanked: 89
    Plunger,
    Rooibos tea and/or Lennons Cramp Drops (?) (Kramp Druppels).
    Hope it helps ??
    Herman Meyer.
    AG0017 ORRA AG38
    2014 Amarok DC 4Motion Auto ,
    2015-02-03: Bush Lapa Miskewer 394.
  28. The Following User Says Thank You to hermanm10 For This Useful Post:
  29. #340
    Thanked: 15097
    That's the stuff , Lennons
    Quote Originally Posted by hermanm10 View Post
    Plunger,
    Hope it helps ??
    Jakes Louw
