Your Lockdown Projects - Page 13
Page 13 of 28 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... LastLast
Results 241 to 260 of 553
  1. #241
    Thanked: 754
    Default Re: Your Lockdown Projects
    Built a drop down bracket to fit a table in the roof of the canopy but now short of 2 screws to finalize the project. Damn is it irritating!
  2. #242
    durban
    Thanked: 1178
    Got to finish my loadshedding transportable trolley.Frustrating because i even had to make some 5 mm nuts.
    I was worried that the frame could easily short circuit the battery if i dropped something on the terminals. I dont know what would happen to a lithium battery on a dead short.I made this plastic cover on the positive so I think it will protect the battery from any mishap.
    I want to take this to site so needed to make a box to protect the inverter and charger. But I had no wood to make a box.
    I had this stuff called aluminium composite but dont have the right tools to cut it. This was difficult for me because I had to bend a box to fit in a box. Wood would be much easier.I used a router to try cut it first .but working with it I think needs a learnt technique which i obviously dont have.
  3. The Following 2 Users Say Thank You to plunger For This Useful Post:
  4. #243
    Rangeview Krugersdorp
    Thanked: 1315
    Quote Originally Posted by Japanese Veghaas View Post
    This project has also been on hold for a long time.
    Time to sort her out.
    Now just to cover the seat and tie up the final loose endAttachment 567056Attachment 567057Attachment 567058Attachment 567059
    Takes me back to my youth....my first bicycle came in an old box...name started with an H ?
    Ford Figo 2016
  5. #244
    Oct 2017
    Vereeniging
    Thanked: 105
    M green chopper was bought in Klerksdorp on Tuesday 25 January 1972 in Klerksdorp for R85. It was replaced on Saturday 30 October 1976 with a red Peugeot 10-speed racer for R112 in Vereeniging.
  6. #245
    Thanked: 1089
    Give me a shout if you still need fuses. I have lots and I'm not far from you. I'll send you a PM.
    Thanx Paul!
    Enjoy the rest of your day.... I will keep you in the loop.
    Malcolm van Coller - retired 2013 but remained in Johannesburg (maybe will look at moving south, Robertson or Wellington type of town, once the wife retires)
    Ex 2011 Conqueror Supra II
    Ex 1995 Sani 3.0 V6 Exec
  7. The Following User Says Thank You to mvcoller For This Useful Post:
  8. #246
    Klerksdorp
    Thanked: 477
    Quote Originally Posted by EtienneB View Post
    From Happys? They're still trading
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  9. #247
    Thanked: 49
    Humber, perhaps?
    Jack Birkenbach
    Land Rover Discovery 2 TD5
    Echo 4 Off-Road Trailer
    Gemini 505 S/Rigid
    Ford Ranger T6 S/C 4x2
  10. #248
    durban
    Thanked: 1178
    This is how I made the box.
    The finished product Click image for larger version.
    The back .
    The inside.
  11. The Following User Says Thank You to plunger For This Useful Post:
  12. #249
    Feb 2014
    Thanked: 781
    Quote Originally Posted by MSF View Post
    Managed to finish the first version of our camping shower pump.
    I didnít have all the fittings I actually wanted to use so ended up making do with what I had around the workshop and the local Spar!
    Iíll add some hose clamps to the fittings and the the next step will be the actual shower head fitting. Iím planning on using something that has an adjustable flow valve of some sort in order to turn the water on and off when needed, the Shurflo pump has a pressure valve switch so will turn off automatically.
    Heating the water is my next step, either fairly straight forward with a jerry can next to the fire or a gas powered system.
    Cool idea. Like
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
  13. #250
    Klerksdorp
    Thanked: 477
    Quote Originally Posted by Jack B View Post
    Humber, perhaps?
    or maybe Hercules?
    -F_D
    White Fang:
  14. #251
    Oct 2017
    Paarl
    Thanked: 30
    Spesseryrakke vir die vrou gemaak, my oupa van Bredasdorp se Imbuia gebruik, so skaars soos hoendertande.
  15. #252
    Langs die rivier, op n berg
    Thanked: 3181
    Het vandag agtergekom my 230e se autobox gaan nie pas op my 380.
    Op oog af lyk dit na selfde box, maar bolt pattern verskil.
    380 se box is totaal en al kapoet.
    230e se engine en box word vervang met infiniti.
    Het gehoop ek kon box net skuif. Toe nie
  16. #253
    Jan 2016
    Thanked: 175
    Painting the roof seems so underwhelming after reading this thread... quite a lot of awesome projects on here!
    2009 Ford Ranger 3.0TDCi D/C 4x4
    1986 BMW E30 323i
    2011 BMW E88 125i
    2013 BMW F30 330d
  17. The Following User Says Thank You to Ntando For This Useful Post:
  18. #254
    Aug 2019
    Thanked: 135
    Nice Plunger, good electrical work for a plumber. How many lathes do you have, I counted at least 3 in the background
  19. #255
    Feb 2014
    Thanked: 781
    Quote Originally Posted by Ben Coetzee View Post
    Stunning
    Zapiture,
  20. #256
    Thanked: 2263
    Love the nostalgia and memories associated with a chopper but it is your stand that drew my attention. You are a serious biker with that stand, work like a meneer on it
    Just shows you how people see different things in a simple photo
    Henk
    Follow us on Facebook
  21. The Following User Says Thank You to hbannink For This Useful Post:
  22. #257
    Thanked: 1315
    Quote Originally Posted by Family_Dog View Post
    or maybe Hercules?
    -F_D
    You have it there FD
    Ford Figo 2016
  23. #258
    Oct 2017
    Paarl
    Thanked: 30
    I changed profession from wood to glass about 5 years ago. Lockdown forced us to switch off our hot glass furnace screwing us over dubbel en dwars.
    Had some time to get my woodshop at home up and running again.
    Got some nice Imbuia to keep me busy for a while!
  24. The Following User Says Thank You to Ben Coetzee For This Useful Post:
  25. #259
    Oct 2017
    Paarl
    Thanked: 30
    Better quality photo.
  26. The Following User Says Thank You to Ben Coetzee For This Useful Post:
  27. #260
    Phalaborwa
    Thanked: 7
    Wanted to fix fault on head lights, but the more I trace faults the more problems I find
