Your Lockdown Projects - Page 12
Page 12 of 28 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 ... LastLast
Results 221 to 240 of 553
  1. #221
    Harties
    Thanked: 532
    Default Re: Your Lockdown Projects
    At present I have selected consumption monitoring of:
    1. Total incoming grid
    2. Total 'Essential' circuits
    3. Both my geysers
    If you make a noise or need music in the bush or on the beach, you’re missing the point.
  2. #222
    Nov 2017
    Clubview Centurion
    Thanked: 35
    I started making a trolley for my loadshedding battery and inverter. I do not weld well. I hate welding pipe cause its difficult but thats all I got.
    My project didnt start well because I used my table to support the pipe in a vertical position but realized I welded my trolley under the table which is bolted to the floor and is very heavy.I had to use a floor jack to get it out
    Attachment 566133
    Found some wheels from a wheelchair i made for my dog. But my dog can now walk (like a drunken sailor) so I can use them.
    Attachment 566139
    Made some axles .
    Attachment 566141
    Worked on getting some decent joins .
    Attachment 566143
    I like to blame my tools for my inadequacies.When I weld this chinese metal behaves like its got something in it. It will weld well and then suddenly spark and make popping noises and fizzle.
    Attachment 566144
    I got to make use of my homemade pipe bender.
    Attachment 566145
    Almost there.
    Attachment 566147
    Hi Plunger
    Please share picks of your pipe bender
  3. #223
    Thanked: 959
    Quote Originally Posted by mvcoller View Post
    This is what I've been doing the last two weeks....
    I made a grid for the back of my Patrol, between the rear shelf of the drawer system and the passenger area.
    I had some "Clear Vu" material left from a previous project, so I used that on a 22 x 22mm sq tube frame, hinged on a 25 x 25mm x 1.6mm angle outer frame. This enables me to open it from the inside. The barrel bolts (From 4X4 Direct) is set up to self lact when I close the grid.
    I manage to get it powder coated last week Monday and fitted it on Tuesday.
    I am moving most of the electrical stuff from the underside of the shelf onto the grid, to make it more visible and accessible. So far I have only moved the DC to DC charger and the USB multi-plug charger. I still have to see what else I want on the outside of the grid. I will also mount some stuff on the inside of the grid, there is a 50mm space between the shelf and the grid.
    But I have hit a snag, with the buggering around I have popped the two 30a (green) bigger blade type fuses on the WRND charger, I only have 25a (yellow) fuses at home. I tried them, and discovered that the warning on the WRND to only use 30A fuses is there for a reason, the 25a fuses pop about 10 seconds after the charger starts charging, after I start the vehicle.
    With the current shutdown, I would imagine it would be impossible to find an open Spares Shop here in Kensington or Malvern East to get some 30a fuses..... I will try the little PnP shop at the BP Filling station on Broadway when I go and buy fresh bread on Monday, they have a few shelves of emergency spares, like fuses, radiator caps brake fluid and the like. That is if they have not cordoned that shelf off like they did at the Bedford PnP. All their hardware, wine, kitchenware and clothing shelves are cordoned off with red and white bunting/emergency type tape.....
    Give me a shout if you still need fuses. I have lots and I'm not far from you. I'll send you a PM.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  4. #224
    Thanked: 959
    As I said above, I think I have what you need Malcom. I couldn't add the photo to the reply. Click image for larger version.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
  5. #225
    May 2012
    Hout Bay
    Thanked: 15
    Folks, looking for advice on converting my old Disco 3 air pump for normal use. I presume I can dispense with the air dryer on the outlet and cut the thin black pipe which I assume goes to a pressure switch.
    Basically I just need to fit a hose connector to the outlet... any ideas or comments welcome.
ID:	566961   Click image for larger version.
ID:	566962   Click image for larger version.
  6. #226
    Langs die rivier, op n berg
    Thanked: 3181
    My yard is skielik vol met helfte van my mercs.
    230E se engine en gearbox is uitgehaal vandag. Kort n goeie skoonmaak.
    250 se engine en gearbox moet ook gebere word.
  7. #227
    Thanked: 3181
    230 se long arm agter radius arms vorder. Voor gaan ons disco 2 gebruik. Voorste disco2 arms baie langer as agter, so toe maak ons maar self die langer agter arms.
    Nou om die brackets op agteras te mount.
    Custum subframe vorder darem ook
  8. The Following User Says Thank You to Reenen For This Useful Post:
  9. #228
    Thanked: 3181
    En toe sommer begin aan lykswa se bedrading ook werk.
  10. #229
    Kan nie meer wag om die merc te sien as hy loop nie!
    1985 Celica Supra
    1996 Land Cruiser 80 series 4.5
    2007 Isuzu KB250 (WORKHORSE)
    2007 Yaris 1.3 T5 (SWAMBO)
    2008 3.0 D4D 4x4 Hilux
  11. #230
    Thanked: 3181
    Nou roer jou gat
  12. #231
    Thanked: 3181
    Ek kan net soveel delegeer
  13. #232
    Thanked: 2260
    Watse nonsens is dit die? jy is nie in lockdown nie jy is 'n plaas boer wat moet sorg dat die res van die land eet nou karring jy met speelgoed soos 'n bottel stoor eienaar?
    Henk
    Follow us on Facebook
  14. The Following User Says Thank You to hbannink For This Useful Post:
  15. #233
    durban
    Thanked: 1178
    Quote Originally Posted by MarioH View Post
    Hi Plunger
    I dont have many pics . I just made it out of scrap and turned some dies. It needs alot of fine tuning.
    I found some other posts of it though.
    https://www.4x4community.co.za/forum...16#post4242416
    https://www.4x4community.co.za/forum...46#post3683446
  16. #234
    Thanked: 3181
    O. Het darem 50 ton vrugte geoes ook vandag. Sal probeer vir 70 ton more...
  17. #235
    Thanked: 3181
    Sal more sommer n hektaar blomkool ook plant spesiaal vir jou.
  18. #236
    Thanked: 3181
  19. #237
    Bathurst
    Had to get rid of this gumtree..overhangs the spot I want to put solar panels.Missed the water tank by a smidgen but all good and no damage.
ID:	566992   Click image for larger version.
ID:	566993   Click image for larger version.
ID:	566994   Click image for larger version.
ID:	566995   Click image for larger version.
  20. The Following User Says Thank You to Galeka For This Useful Post:
  21. #238
    Thanked: 21
ID:	567023Click image for larger version.
    Finally getting around to building my drawers for the trailer !
    Nissan Hardbody 3.3v6
    Wildebeest Kalfie
  22. #239
    Dec 2015
    Thanked: 131
    This project has also been on hold for a long time.
    Time to sort her out.
    Now just to cover the seat and tie up the final loose endClick image for larger version.
ID:	567056Click image for larger version.
ID:	567057Click image for larger version.
ID:	567058Click image for larger version.
    2009 Ford Ranger 3.0TDCI
    Raleigh RM9 (Tank)
    Raleigh Chopper MK2 (Restoration porject)
    Giant TCR2 Elite (Silver Train)
    Trek 810 Single speed (Frank)
  23. The Following 2 Users Say Thank You to Japanese Veghaas For This Useful Post:
  24. #240
    Klipriver
    Thanked: 299
    Quote Originally Posted by Japanese Veghaas View Post
    Really awesome, wife and I both agree that this brings back tons of good and bad memories. Haven't seen one of these in donkey yonks
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
  25. The Following User Says Thank You to Alan Eveleigh For This Useful Post:
