Your Lockdown Projects - Page 11
Page 11 of 28 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... LastLast
Results 201 to 220 of 553
  1. #201
    Aug 2014
    Oudtshoorn
    Thanked: 11
    Default Re: Your Lockdown Projects
    I started making a trolley for my loadshedding battery and inverter. I do not weld well. I hate welding pipe cause its difficult but thats all I got.
    My project didnt start well because I used my table to support the pipe in a vertical position but realized I welded my trolley under the table which is bolted to the floor and is very heavy.I had to use a floor jack to get it out
    Attachment 566133
    Found some wheels from a wheelchair i made for my dog. But my dog can now walk (like a drunken sailor) so I can use them.
    Attachment 566139
    Made some axles .
    Attachment 566141
    Worked on getting some decent joins .
    Attachment 566143
    I like to blame my tools for my inadequacies.When I weld this chinese metal behaves like its got something in it. It will weld well and then suddenly spark and make popping noises and fizzle.
    Attachment 566144
    I got to make use of my homemade pipe bender.
    Attachment 566145
    Almost there.
    Attachment 566147
    Very nice pipe bender you made.
  2. #202
    Aug 2014
    Oudtshoorn
    Thanked: 11
    Quote Originally Posted by Zapiture View Post
    Nice work. Hereís a tip, I saw a guy at a camp site that had put a starter motor on the crank handle. I could not believe how easy he moved his two wheeler van around. Worked like a charm.
    Was that with a hand held winch whilst standing.
  3. #203
    May 2019
    Talking Re: Looking vey nice how did you polish your blade?
    Quote Originally Posted by Pietsweis View Post
    Attachment 565465Attachment 565466My first knife almost doneJust etching my name and sharpen and all done. Lockdown allowed me to accelerate the little project
  4. The Following 3 Users Say Thank You to The Landy Boss For This Useful Post:
  5. #204
    Thanked: 352
    Salad Bowl - 300 mm diameter. I am under correction but I think this is from a very old piece of Yellow Wood, but I must admit, I have never seen Yellow Wood with so much life in it!
    Peet Schultz
  6. The Following 2 Users Say Thank You to PeetS For This Useful Post:
  7. #205
    Nov 2019
    Thanked: 35
    I am fortunate/unfortunate to be working from home so I had short periods in the evenings to work little by little on the following.
    Started off with making a table for the braai area to hold my bonsais so that i could get rid of the stack of pallets taking up all the floor space.
    I then made my myself a dedicated welding table so my workbench can be a bench again... I followed up by the book shelf for my sister.
ID:	566738   Click image for larger version.
ID:	566739   Click image for larger version.
ID:	566740   Click image for larger version.
  8. The Following 3 Users Say Thank You to Garthox For This Useful Post:
  9. #206
    Lonehill, JHB
    Thanked: 1032
    I washed the Pajero. Itís not as easy as it used to be
    2014 Pajero 3.2DiD SWB
  10. The Following 3 Users Say Thank You to KurtG For This Useful Post:
  11. #207
    Sep 2015
    Thanked: 149
    I started painting my workshop floor, found some old stoep paint....
    Jimny, the most underestimated 4x4xfar
  12. The Following User Says Thank You to Gustav Jimny For This Useful Post:
  13. #208
    Thanked: 1090
    Quote Originally Posted by PeetS View Post
    Pragtig!
  14. The Following User Says Thank You to Peter Connan For This Useful Post:
  15. #209
    Mar 2018
    Randfontein
    Thanked: 144
    `sooooo
    apparently we had a few more projects to be done
    Kids bedroom, painted!
    Our bedroom, painted!
    more lights needed replacing
    mounting the tv on a new swivel stand in the room
    hide laptop and power in a cupboard
    side note, i could purchase a swivel mount for my tv, but couldnt purchase a box of rat poison or a hosepipe
  16. #210
    Langs die rivier, op n berg
    Thanked: 3181
    Long arm radius arms
    Adjustable pinion brackets
  17. The Following 2 Users Say Thank You to Reenen For This Useful Post:
  18. #211
    Harrismith
    I thought it would be a great idea to respray the entire Bakkie.....
    Just before lockdown I got a new Bonnet and bumper kit with the new grill and ran to the closest auto paint supplier and got what we needed according to the salesman as I had and probably still don't have a clue, however we started stripping, and stripping and stripping and then the sanding started, I really learned the hard way about body filler, this stuff is hard to remove, but that said I tried to identify each little dent and chip (Didn't get them all but we tried) and sanded and filled and sanded and filled and sanded and filled and sanded and sanded again, my lovely other halve even had to learn that nails can grow back, and she jumped right in and did her part.. which also entails making coffee and so on. I must be the luckiest man alive
    Well now it is primed and ready for colour but again a wet sand is required and then the true test comes.
    I hope I get the mixtures correct as I know the 2k is a 1:2 mixing ratio, but I don't have a clue how much 2k thinners to ad to the 1st and 2nd cote. But I will continue my research and somewhere on this Wonderfull internet I will find some answers,
    Well I can say one thing, Thanks to Youtube...
    My plan is to wet sand the primer today or tomorrow, and the it is colour
    A few tips I adopted:
    If you strip something mark it and tape the bolts, nuts and clips to it
    Dont put more filler than you need, You turn it into dust you only have to clean yourself
    Get enough and proper sanding equipment.
    Please send me your feelings and comments all welcome even the negative ones
    All the best
ID:	566837   Click image for larger version.
ID:	566838   Click image for larger version.
ID:	566840   Click image for larger version.
ID:	566841   Click image for larger version.
  19. The Following User Says Thank You to ACS For This Useful Post:
  20. #212
    Jan 2020
    Newcastle
    Quote Originally Posted by mvcoller View Post
    This is what I've been doing the last two weeks....
    I made a grid for the back of my Patrol, between the rear shelf of the drawer system and the passenger area.
    I had some "Clear Vu" material left from a previous project, so I used that on a 22 x 22mm sq tube frame, hinged on a 25 x 25mm x 1.6mm angle outer frame. This enables me to open it from the inside. The barrel bolts (From 4X4 Direct) is set up to self lact when I close the grid.
    I manage to get it powder coated last week Monday and fitted it on Tuesday.
    I am moving most of the electrical stuff from the underside of the shelf onto the grid, to make it more visible and accessible. So far I have only moved the DC to DC charger and the USB multi-plug charger. I still have to see what else I want on the outside of the grid. I will also mount some stuff on the inside of the grid, there is a 50mm space between the shelf and the grid.
    But I have hit a snag, with the buggering around I have popped the two 30a (green) bigger blade type fuses on the WRND charger, I only have 25a (yellow) fuses at home. I tried them, and discovered that the warning on the WRND to only use 30A fuses is there for a reason, the 25a fuses pop about 10 seconds after the charger starts charging, after I start the vehicle.
    With the current shutdown, I would imagine it would be impossible to find an open Spares Shop here in Kensington or Malvern East to get some 30a fuses..... I will try the little PnP shop at the BP Filling station on Broadway when I go and buy fresh bread on Monday, they have a few shelves of emergency spares, like fuses, radiator caps brake fluid and the like. That is if they have not cordoned that shelf off like they did at the Bedford PnP. All their hardware, wine, kitchenware and clothing shelves are cordoned off with red and white bunting/emergency type tape.....
    Hi, haven't tried this myself, but just an idea, if you get any old 30A fuse from an old stove, UPS, Computer box, you name it, just take that fuse wire and solder it onto your 30A (or the broken 25A one), broken blade type fuse?
  21. #213
    Jan 2014
    Krugersdorp
    Thanked: 36
    SO over the weekend I decided to rebuild my camping power pack, found a toolbox that my son was using for his lego, and that he did not need anymore, so I just reused all the components I have from a previous build, My requirements was that it all must fit into one box, accessories included, and I even added a charging port. It can take 3 batteries (2 are in use and 1 on standby) and I used each side for all the swtches and plugs, just need to add the fuses, still, as I am between using blade vs the glass tube fuses.
ID:	566849   Click image for larger version.
ID:	566850   Click image for larger version.
ID:	566851   Click image for larger version.
ID:	566852   Click image for larger version.
ID:	566853   Click image for larger version.
Name:	With Lights.jpg
  22. The Following User Says Thank You to reniervs02 For This Useful Post:
  23. #214
    Klipriver
    Thanked: 299
    Quote Originally Posted by ACS View Post
    All the best
    Looking good, pity you are so far as I have a few mixing rulers, you can have one, makes mixing so much easier
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
  24. The Following User Says Thank You to Alan Eveleigh For This Useful Post:
  25. #215
    Ngodwana
    DagsÍ, besig om my XL600R aanmekaar te sit.
    As iemand iets van XLs soek daar is 'n Website: www.hxl.it, gaan kyk gerus.
    Groete
    Henk
ID:	566864   Click image for larger version.
ID:	566865   Click image for larger version.
ID:	566866   Click image for larger version.
ID:	566867   Click image for larger version.
  26. The Following User Says Thank You to heoosthuizen For This Useful Post:
  27. #216
    Thanked: 1089
    Quote Originally Posted by Thysticles View Post
    I though of that but have no fuse wire, I chucked that out about 20 years ago as I no longer had use for that, and with the lockdown........ need I say more?
    Malcolm van Coller - retired 2013 but remained in Johannesburg (maybe will look at moving south, Robertson or Wellington type of town, once the wife retires)
    Ex 2011 Conqueror Supra II
    Ex 1995 Sani 3.0 V6 Exec
  28. #217
    Harties
    Thanked: 532
    Default Home UPS
    I've just completed my home UPS system.
    1. Installed:
    - Victron MultiPlus-ll GX 3kVA 48V inverter/charger
    - Shoto 48V 100Ah 4.8kWh LFP battery
    2. Rewired and split my DB box into 'Normal' and 'Essential' circuits, each with their own neutral bar and earth leakage unit.
    'Essential' circuits - All lights, computers, network including Wifi, TV and entertainment centre, fridge/freezer;
    'Normal' circuits - all the others
    3. Installed a 'UPS' DB with change-over switches that allows me to select between the following the power sources for my 'Essential' circuits:
    - Grid
    - Inverter
    - Generator
    4. I've kept the Efergy monitoring system to monitor my geyser consumption.
    About 40% of my electricity consumption is for water heating.
    I may install PV water heating for interest sake.
    This system will give me around 10 hours of inverter power during periods of load shedding/power failure, and as long as I like if I switch to Generator after that.
ID:	566886   Click image for larger version.
ID:	566887   Click image for larger version.
ID:	566888   Click image for larger version.
    If you make a noise or need music in the bush or on the beach, youíre missing the point.
  29. The Following User Says Thank You to PRA For This Useful Post:
  30. #218
    Lonehill (JHB)
    Thanked: 26
    Default Re: Home UPS
    Quote Originally Posted by PRA View Post
    Do you have 3phase power?
    2014 Ford Ranger 3.2 XLT 4x4 D/C Auto
    2018 Ford Everest 2.2 XLS 2x4 auto (SWAMBO)
    Echo 4 trailer
  31. The Following User Says Thank You to ChrisH For This Useful Post:
  32. #219
    Harties
    Thanked: 532
    No, this system is single phase.
    You can easily do the same for a three phase system by adding another two MultiPlus units.
    Easier though (and a lot cheaper) on a three phase system is to group all 'Essential' circuits onto one phase and back-up that phase.
    I have done that for my son's installation.
  33. #220
    Lonehill (JHB)
    Thanked: 26
    Ah OK, I saw 3 energy monitor probes thought it was 3 phase, good advice on on grouping essentials as I have 3 phase
    Echo 4 trailer
