Your Lockdown Projects - Page 10
Page 10 of 28 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 ... LastLast
Results 181 to 200 of 553
  1. #181
    Thanked: 352
    Default Re: Your Lockdown Projects
    I started making a trolley for my loadshedding battery and inverter. I do not weld well. I hate welding pipe cause its difficult but thats all I got.
    My project didnt start well because I used my table to support the pipe in a vertical position but realized I welded my trolley under the table which is bolted to the floor and is very heavy.I had to use a floor jack to get it out
    Attachment 566133
    Found some wheels from a wheelchair i made for my dog. But my dog can now walk (like a drunken sailor) so I can use them.
    Attachment 566139
    Made some axles .
    Attachment 566141
    Worked on getting some decent joins .
    Attachment 566143
    I like to blame my tools for my inadequacies.When I weld this chinese metal behaves like its got something in it. It will weld well and then suddenly spark and make popping noises and fizzle.
    Attachment 566144
    I got to make use of my homemade pipe bender.
    Attachment 566145
    Almost there.
    Attachment 566147
    Good job, for someone that cannot weld!
    Peet Schultz
  2. The Following User Says Thank You to PeetS For This Useful Post:
  3. #182
    Thanked: 14991
    Secondef
    Quote Originally Posted by PeetS View Post
    Jakes Louw
  4. #183
    Thanked: 991
    AMT is where we get ours. The have what they call Woodcast 30. We normally get the 8Kg pack - 5 kg resin and 3 kg hardner. Bought just before lockdown and the price was < R1300.00.
    https://www.amtcomposites.co.za/prod...odcast-30-8kg/
    Do you have a pressure pot? I am a bit of a regular at AMT in kempton as my son is making lures, however it is tricky to get the resins nice a clear without a pressure pot. Do you have one or otherwise how are your curing the resin?
  5. #184
    Thanked: 352
    Quote Originally Posted by stephenplumb View Post
    For the smaller castings, I have pressure pot, but the one in my post was just cured normally. You can use a blowtorch to pop the surface bubbles.
    Peet Schultz
  6. #185
    Jul 2015
    Garsfontein
    Thanked: 162
    So bietjie aan die 105 begin strip en deeglik skoonmaak. Dink dis goed om dele oop te maak, al die versteekte skroefies en moertjies het so half draai nodig om weer mooi vas te wees (na 20 jaar)
ID:	566182   Click image for larger version.
ID:	566183   Click image for larger version.
    Flip le Roux
    2012 Fortuner D4D 4x4 Auto
    2016 Jurgens Exclusive
    2014 BMW R1200RT
    2016 BMW F800GS ADV
    2016 Kia Picanto - Swambo
    2019 2.2 Ranger D/C XLS 4x4 Auto - Work
    GP0015
  7. #186
    Jun 2013
    Uiteindelik my woordklok klaar gemaak Click image for larger version.
  8. The Following 4 Users Say Thank You to c3101 For This Useful Post:
  9. #187
    Apr 2020
    Thanked: 9
    Quote Originally Posted by c3101 View Post
    Baie indrukwekkend!!
  10. The Following User Says Thank You to Herman Fourie 74 For This Useful Post:
  11. #188
    Mar 2012
    Thanked: 3955
    Square tubing, plywood, inverter welder, self dimming helmet, paint and patience.
    Rack for work clothes and shoes at the bottom. Rifle safe takes some of my hanging space.
    Apart from the helmet, I recently invested in a cut-off saw. This also makes a huge difference. Marking 45 degrees is one thing but to then cut it straight on the mark with an angle grinder is another.
    Pieter Kruger le Roux
  12. The Following 5 Users Say Thank You to Redman For This Useful Post:
  13. #189
    Feb 2016
    Knysna
    Thanked: 30
    Hi daar!
    Ek het nog 'n mes gemaak. Dis 'n kleintjie (225mm), gewoonlik maak ek liewers 32cm+. Dis N690 van Bohler. Die hef is ou ivoor.
    Groete
Name:	20200404_084848 (Medium).jpg
ID:	566251   Click image for larger version.
Name:	20200404_084948 (Medium).jpg
ID:	566252   Click image for larger version.
Name:	20200404_093540 (Medium).jpg
ID:	566253   Click image for larger version.
Name:	20200404_094205 (Medium).jpg
ID:	566254   Click image for larger version.
Name:	20200404_104915 (Medium).jpg
ID:	566255   Click image for larger version.
Name:	20200410_175241 (Medium).jpg
  14. The Following 3 Users Say Thank You to johanbaard For This Useful Post:
  15. #190
    Thanked: 959
    Since we had the renovation done on the kitchen I've been wanting to build a new security gate for the back door. The old cheapie that was fitted when I bought the house wasn't worth much. We also needed to make it as difficult as possible for the local pigeons to get in to steal the dogs food. With my design I had to take into account the wooden door frame and door with the glass panels. I used 50x50mm square tube as the 2 side frames that are attached to the wall. The door is 25x25mm square tube wit a 100x25mm cross piece for the lock. I've welded in expanded metal to finish the door off. Tomorrow I'll weld on the hinges and do the fitting of the door before painting it with the hammerrite paint. The last photo below was a test fit before I packed up for the day. Click image for larger version.
ID:	566259Click image for larger version.
ID:	566260Click image for larger version.
ID:	566261Click image for larger version.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  16. The Following 2 Users Say Thank You to Paul#25 For This Useful Post:
  17. #191
    Rangeview Krugersdorp
    Thanked: 1312
    Don't forget a decent shield on frame around the lock area.
    Ford Figo 2016
  18. #192
    Thanked: 959
    Thanks for the reminder Duncan. I planned to have a cover plate and will fit it today.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
  19. #193
    Secunda
    Thanked: 25
    Some mods to mom's play room
    Francois Engelbrecht
    3.0 Hardbody DC 4x4
  20. The Following User Says Thank You to Brombeer36 For This Useful Post:
  21. #194
    Feb 2014
    Thanked: 781
    Quote Originally Posted by ockert View Post
    Hopefully this will help in moving the Xplorer around.
    Nice work. Here’s a tip, I saw a guy at a camp site that had put a starter motor on the crank handle. I could not believe how easy he moved his two wheeler van around. Worked like a charm.
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
  22. #195
    Thanked: 959
    All fitted and final painting done. I'm happy with the way it came out. Click image for larger version.
ID:	566600Click image for larger version.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
  23. The Following 4 Users Say Thank You to Paul#25 For This Useful Post:
  24. #196
    Aug 2018
    Paarl
    Thanked: 93
ID:	566642Click image for larger version.
    Besides normal gardening built myself a suitcase panel box.
  25. The Following 4 Users Say Thank You to fatbike For This Useful Post:
  26. #197
    Pietermaritzburg
    Managed to finish the first version of our camping shower pump.
    I didn’t have all the fittings I actually wanted to use so ended up making do with what I had around the workshop and the local Spar!
    I’ll add some hose clamps to the fittings and the the next step will be the actual shower head fitting. I’m planning on using something that has an adjustable flow valve of some sort in order to turn the water on and off when needed, the Shurflo pump has a pressure valve switch so will turn off automatically.
    Heating the water is my next step, either fairly straight forward with a jerry can next to the fire or a gas powered system.
  27. The Following 5 Users Say Thank You to MSF For This Useful Post:
  28. #198
    Mar 2017
    Okahandja
    Thanked: 739
    Have a few of these roll. SIL decided to build a table. Old worn gum poles as feet and now they have a very good table for the stoep. 3days work. Next week we do one more. Attachment 566664Click image for larger version.
ID:	566665Attachment 566666Click image for larger version.
  29. The Following 2 Users Say Thank You to Erwin Schimper For This Useful Post:
  30. #199
    Tshwanetoria
    Thanked: 854
    Good plan. What is that high tech tow bar, if I may ask?
  31. #200
    Jul 2010
    Garsfontein, Pretoria
    Thanked: 436
    I decided to strip down my cd shuttle in order to get it to work again and tp repair my venture cam docking bracket.
ID:	566685   Click image for larger version.
    Johan De Graaf
    2019 Ford Ranger Wildtrak 2.0 Biturbo 4x2 D/C
    2013 Range Rover e-vogue HSE Dynamic SD4
    2010 Range Rover Vogue TDV8
  32. The Following User Says Thank You to Oldtimer For This Useful Post:
