Defender 2.8 BMW.
Results 1 to 10 of 10
    Greyton westerncape
    Thanked: 40
    Question Defender 2.8 BMW.
    I need to fix my fuel gauge and if i am removing the tank i would like to install a fuel pump outside of the tank. Is this possible?
    Thanked: 13548
    Default Re: Defender 2.8 BMW.
    Most defenders had a pump just in front of the right rear wheel on the chassis
    Thanked: 13548
    Thanked: 32
    Quote Originally Posted by mike cullen View Post
    Yes it is, we've done this in my son's 2.8. We just disconnected the power from the pump in the tank and is using that as the pickup for the external pump.
    "A clear conscience is usually the sign of a bad memory"
  5. The Following User Says Thank You to mufie For This Useful Post:
    Greyton westerncape
    Thanked: 40
    Thumbs up Re: Defender 2.8 BMW.
    Mufie thanks what pump did you use?
    Thanked: 32
    Hi Mike, sorry for the late reply, I will check and let you know
    Thanked: 439
    I tried to do a quick fix on my V8.....
    Fuel pump packed up from standing and I wasn’t going to drop the tank so I connected a fitting in place of the drain plug and fitted a inline pump.....
    Got about400 meters down the road and she stalled -no fuel.
    Waited a couple of minutes and she started again. Another 400 meters and she cut out again....
    Crud in the tank kept on blocking the 6mm outlet pipe
    Thanked: 32
    Quote Originally Posted by mufie View Post
    Here goes
  10. The Following User Says Thank You to mufie For This Useful Post:
    Dec 2010
    klerksdorp
    Thanked: 134
    On mine i fitted a bosch universal 6 bar pump.I placed the pump just before the the filter next to the chassis.I put a piece of radiator hose around the pump to protect it from flying stones.
    Thanked: 1162
    Don't drop the tank. Cut an inspection hole in the load bin - the Defender 2.8i sticky has a post with the measurements.
    Tanking the pump out is relatively easy that way.
    Defender 2.8i
