Tandoor Oven - Page 2
Results 21 to 40 of 42
Thread: Tandoor Oven
    Richardsbay, KZN
    Thanked: 13038
    Default Re: Tandoor Oven
    Half a bag of charcoal and some briquettes busy burning. One can see which side the breather vents are.
    Walker Evans, Photographer
  2. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  3. #22
    Richardsbay, KZN
    Thanked: 13038
    I cut some flashing to seal the top, it seems to burn well even with this lid on. This will also force heat into the bricks, which is what I want.
  4. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  5. #23
    May 2013
    Sabie
    Thanked: 177
    Tandoor. Click image for larger version.
    Don't feed the monkeys!
  6. #24
    Thanked: 13545
    Riaan, time for another concrete coated monstrosity? I reckon that thing will work like a mega rocket stove?
  7. #25
    Richardsbay, KZN
    Thanked: 13038
    If fired with wood yes, a ninja rocket stove. The vent at the bottom will have to be bigger though, I think.
  8. #26
    Thanked: 13545
    I know you'll figure it all out.
    You've inspired me to look around the farm for some bricks. Maybe search for the masonry cutter for the angle grinder. Bevel the bricks like when you build a pizza oven roof.
    Or maybe just be lazy and pile them in a square.
  9. The Following User Says Thank You to jelo For This Useful Post:
  10. #27
    Richardsbay, KZN
    Thanked: 13038
    That works, I will pack one in the next day or two, it helps if the bottom entrance is a bit further away from the fire chamber. I'll show how as I have an idea.
  11. #28
    Thanked: 13545
    An extended tunnel?
  12. #29
    Richardsbay, KZN
    Thanked: 13038
    Jelo, I added just three pieces of wood to the oven and it works, the rocket effect is audible.
  13. The Following 2 Users Say Thank You to Riaan van Wyk For This Useful Post:
  14. #30
    Aug 2010
    Bellville
    Thanked: 69
    I like this.......think its worth a try........ have the time now......
  15. #31
    Richardsbay, KZN
    Thanked: 13038
    Twenty minutes in and the oven is revving.
  16. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  17. #32
    Richardsbay, KZN
    Thanked: 13038
    The lid idea seems to work well, the fire does not smother and the heat stays inside to be absorbed by the pavers.
  18. #33
    Richardsbay, KZN
    Thanked: 13038
    So having used the Tandoor a few times now I reckon it is a worthwhile implement. It uses surprisingly little charcoal and cooks perfectly.
    Some of the things I've cooked:
ID:	565260   Click image for larger version.
ID:	565261   Click image for larger version.
  19. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  20. #34
    Richardsbay, KZN
    Thanked: 13038
    Rolled topside and veggies. The veggies are awewome from this by the way, cooled whole with skin on.
  21. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  22. #35
    Richardsbay, KZN
    Thanked: 13038
    Hung a pot to cook in, dound this needs more heat if one wants to cook faster. Something to do would be to drop the pot down onto the coals till one gets internal temps up and then hang.
  23. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  24. #36
    Richardsbay, KZN
    Thanked: 13038
    And smoked some rashers.
  25. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  26. #37
    Thanked: 13545
    hmmm you'd need a ratchet winch or simple block & tackle, I'm not sure I'd like to lift a boiling full dutch oven using a threaded rod..........
  27. #38
    Richardsbay, KZN
    Thanked: 13038
    Nope, a long welding glove will work fine.
  28. #39
    Richardsbay, KZN
    Thanked: 13038
    Why this works so well.
  29. The Following 6 Users Say Thank You to Riaan van Wyk For This Useful Post:
  30. #40
    Richardsbay, KZN
    Thanked: 13038
    How to serve onions once ready.
  31. The Following 2 Users Say Thank You to Riaan van Wyk For This Useful Post:
