What size spanner?
Results 1 to 17 of 17
    May 2015
    Kleinbosch
    Thanked: 29
    Default What size spanner?
    Hi, I'm trying to drain the gearbox oil from my Discovery 200Tdi. Its the earlier LT-77 box. I clearly don't have the right size spanners for the draining plugs. So I'll go and buy tomorrow. Can anyone perhaps tell me the size/s I need for: main gearbox drainage plug; secondary drainage plug. And what is the size of the engine oil sump's drainage plug, while I'm at it? Many thanks, Danie.
    Caledon, Tesselaarsdal
    Thanked: 48
    Default Re: What size spanner?
    Use a Vrystaat Micrometer....a shifting spanner.
    One must wait till evening to see how splendid the day has been
  3. The Following 2 Users Say Thank You to Jembo For This Useful Post:
    Cape Town, Plumstead/The Sea/Franskraal
    Thanked: 554
    Probably imperial sizes, locate your closest pawn broker and have a look, you're sure to find a set there.
    Have now covered 270 000Km on veg oil.
    Oh, and an Isuzu 280DT, 40 000Km on Bio Diesel
    Rand for Rand gets 33Km/L
    May 2015
    Kleinbosch
    Thanked: 29
    Thanks - my shifting spanner seems to struggle. I don't think the plugs have been off in a loooong while. Probably need a higher quality shifting...
    Cheers, Danie.
    Friemersheim, Southern Cape
    Thanked: 3105
    Use vernier to measure nuts and work out appropriate imperial spanner size
  7. The Following 2 Users Say Thank You to Prof For This Useful Post:
    Thanked: 13618
    Isn't a shifting spanner a Boksburg vernier?
    Thanked: 246
    Take the nuts with to the pawn shop. Try for size
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Rangeview Krugersdorp
    Thanked: 1246
    Quote Originally Posted by Robbief View Post
    Oops, the spelling threw me there
    Ford Figo 2016
    Kathu
    Thanked: 2839
    Buy a metri socket set. They can take metric and imperial bolts with the same socket. No socket grips like them
  12. The Following User Says Thank You to grips For This Useful Post:
  13. #10
    May 2015
    Kleinbosch
    Thanked: 29
    I think I must do that! Will be good to have it in my garage! As I said, I'm a novice, but I'm learning fast and look forward to doing more of these things on my own. PS - being a novice/rookie I did manage to spill a lot of pitch black dirty oil all over my virgin garage floor last night when I took the oil filter off......... Eish!!!
  14. #11
    May 2015
    Kleinbosch
    Thanked: 29
    Just to close the loop: I managed to replace the engine oil (and filter), the gearbox oil (and small internal filter) as well as the transfer case oil. I managed to find an imperial spanner #32 at a pawn shop. It did the trick. Couldn't fit a socket into the space. So all good! I'll post a picture of the metal shavings on the magnetic pin of the gearbox drain plug. Interesting - and luckily quite normal. Regards, Danie.
  15. #12
    Thanked: 73
    And then grind the beveled part of the socket away down to where it grips and it will not round your nut.
  16. #13
    Sep 2010
    London/Cape Town
    Thanked: 15
    Is that the proper name for the sockets you recommended? Google is no help, as it just thinks it's a misspelling of "metric". Silverline Metri doesn't provide anything I can see but the usual metric sockets. Would you be able to provide a link? Many thanks
  17. #14
    Thanked: 439
    Metrinch?
  18. The Following 2 Users Say Thank You to GaryFrank For This Useful Post:
  19. #15
    Nov 2017
    Thanked: 210
    You can also try the gedore c19 type sockets. Similar to metrinch, also useful for stripped bolt heads.
  20. The Following 2 Users Say Thank You to HobieDave For This Useful Post:
  21. #16
    Cape Town/Where ever oil is found
    Thanked: 21
    Hi Hobidave As far as I recall the sump plug is a 17 mm the imperial size is between a 5/8"(16) 11/16" (18) Don't quote me on this.From 19mm (3/4) on both the metric and imperial (SAE) sizes fit Metrinch, Gedore, Stahwille and Snapon make interchangeable sockets and spanners The are also good for removing damaged and rounded nuts and bolts as these sockets and spanners are designed to take on the flats of nuts and bolts.Your local tool and spares shop will have these in stock and if not can get these for you. Please do not use a shifter or allsizes, freestate mictometer on the plugs as the chances are good you will damage the hexagon heads Hope you have success Klaus
    Land Rover 300 Tdi Sadly sold
    Bush lapa Vlooi B263 This is the best investment I ever made,next to SWAMBO asking to marry me
    76 Series LAND CRUISER 4.2 Donkey It' now history
    The black TOUAREG V6 is history Will get one again one that works
    Now TYDSAAM is a PAJERO DiD GLS The Bush Lapa is NO HURRY
    And SWAMBO a TOYOTA YARIS
    The CORSA bakkie for the little tasks
  22. The Following 2 Users Say Thank You to Klaus-Dieter For This Useful Post:
  23. #17
    Uitenhage
    Quote Originally Posted by HobieDave View Post
    You can also use an impact socket as it fits completely on the nut and not at the edges as a normal socket will do. Do not use an impact wrench with the socket. I used this when the landys sump plug was damaged (rounded edges) and it worked perfectly. The c19 socket is also effective.
    2003 Disco 2 Facelift
    Ford Ranger 2.2Auto
  24. The Following User Says Thank You to dougN For This Useful Post:
