Series 3 timing chain
Results 1 to 11 of 11
    Thanked: 518
    Default Series 3 timing chain
    So i have this tappet clatter for a long time now.
    Set tappets about 6 times.
    Still i hear the clatter. I have a complete timing chain set with tensioner, chain and adjusting thing.
    I have opened the timing chain cover and have no idea what is rubbing or clattering.
    It looks ok. I notice only the adjuster thing against the chain. This should have a .10 gap or something like that ?
    WHAT MUST I LOOK FOR THAT IS CAUSING THE MARBLES SOUND
    Defender Kalahari
    Series 3 SWB
    Series 2 SWB (Near Future)
    Series 1 Station Wagon 88''
    Thanked: 13545
    Default Re: Series 3 timing chain
    Looks fine to me, no abnormal wear on the sprockets.
    Thanked: 518
    Jelo, look at bottom of that guide thing.
    It has a kink i am sure that is not correct.
    It sounds like a bag of marbles, they all say its timing chain, maybe its stretched.
    May as well replace it all as i have those parts in Stock Nogal
    Defender Kalahari
    Series 3 SWB
    Thanked: 518
    The right side should have a slight gap from the vibration damper. (thats what its called)
    Defender Kalahari
    Series 3 SWB
    Thanked: 518
    After replacing ALL the timing chain parts I still have a bit of a rattle.
    Reset all the tappets but at .009 and not .010
    Still a bit of a rattle on idle.
    Slight rev and it goes away ?
    What could it be, head was done about a year ago, all new.
    Any idea, or leave it, i have had it doing this for years.
    Defender Kalahari
    Series 3 SWB
    Thanked: 13545
    Wear on the rockers and shaft?
    Greyton westerncape
    Thanked: 40
    Question Re: Series 3 timing chain
    oil pressure?
    Thanked: 202
    Oil too thin - wrong viscosity?
    Oppierotse
    Thanked: 262
    Check the "face" of the rocker that pushes down on the valve stem. Over time they wear out and the flat surface become hollow. A feeler gauge measure the flat surface only and cant pick up the hollow section.
    98 Hilux 2.8D D/C 4x4
    Thanked: 14
    What's your oil pressure at idle?
    Dale
    F150 4x4 5.4 Triton V8
    Series 3 Land Rover 109 SW
    GU Patrol 3.0Di GL
    Metalian Maxi in RED
    Thanked: 439
    Recheck your valves.....either gap is questionable or a bent valve sticking
