Results 1 to 7 of 7
    Jul 2014
    Default Moremi, Savuti and Linyanti in a 2019 Jimny (May/ June 2020)
    Good evening everyone
    Due to all fears and uncertainties in the world of travel my UK companions for a northern Botswana trip have understandably cancelled. We have cancelled our 4x4 rental booking but as a few of you have found that DWNP is not refunding camp site fees.
    IF my wingman and I are allowed into Botswana (yes I know its impossible to predict now), I have a stock standard 2020 Jimny that is keen on taking on Moremi, Savuti and Linyanti. If I pop on some fresh BFG A/T's, and 40liters of Petrol on the roofrack do you think I'll make it?
    My last trip in the area was in a Hi-Lux thus I'm dealing with a completely different kind of fish.
    Just some additional points- I'll be packing super light as in hiking gear and not bush camping kit and according to literature the Jimny has 210mm of ground clearance.
    Will I make it in your opinion?
    Thanked: 2034
    Default Re: Moremi, Savuti and Linyanti in a 2019 Jimny (May/ June 2020)
    Yes, anytime. If it's safe and travel is open again, then go. The Jimny will be fine.
    Pack light, take a jerry can. Have fun!
    Stephan G
    4x4: 2018 Isuzu KB250 D-Teq 4x4 DC
    Platkar: 2019 Suzuki Baleno GLX
    "All of us get lost in the darkness. Dreamers learn to steer by the stars"
  3. The Following User Says Thank You to Groenman For This Useful Post:
    Apr 2011
    Ghanzi, Botswana
    Thanked: 1439
    As you cautiously said, if you are allowed to travel, thatís when you will. We really discourage people from traveling across borders because of this uncertainty of this pandemic and also it seems once one case is confirmed, itís a slippery slope. Just today our President is starting a 14 days quarantine himself after he went to Namibia for the inauguration of the president. Namibia has few cases but he is trying by all means possible.
    About the Jimmy, I guess the real issue will be the ground clearance. If it has that clearance and working with right Tyre pressure you can be good. Savuti Route is a high way, you could always get some help.
    _______________________________
    2011
    VW Amarok BIturbo TDI 4Motion (SOLD Dec 2020)
    2019 Land Cruiser 79 4.2 S/C
    Apr 2018
    RSA
    Thanked: 1933
    Quote Originally Posted by africanwanderer View Post
    Where do you plan on sleeping? The entire area has Elephant, Hippo, Lion and Hyena that visit your campsite at night. The weight of the supplies you'll be carrying depends on the duration of the trip. The vehicle is not the problem as the Jimny is very capable, It's carrying capacity is.
  6. The Following User Says Thank You to Olyfboer For This Useful Post:
    Aug 2010
    Bellville
    Thanked: 80
    I had a chat to a couple in a Jimmy in Moremi a few years back.
    ground clearance was a bit of problem. It was mostly fine when empty, but once loaded they struggled a lot. They also said they just couldn't pack enough stuff....wood as an example was a problem.....they had it on their roof rack, but the weight made it difficult.
    Mar 2007
    Harties Boet
    Thanked: 1747
    Search for jimnyafrica on instagram. That couple has just returned from a trip like that (and more), with the sole purpose of wanting to see if it was possible with a jimny. Nice people, they'd be happy to discuss it all with you.
    Graham Robertson
    Nissan Patrol 4.8
  9. The Following User Says Thank You to Graham For This Useful Post:
  10. #7
    Feb 2019
    Thanked: 387
    The Jimny is definitely up to the task if you put a good set of A/T tyres on and keep the weight down. I think you will need more than 40L of fuel though. That tank in the Jimny is small, it uses a lot of fuel in the sand and there is a lot of driving to be done in the moremi, savuti, linyanti. Maybe take a set of maxtraxs.
    Just stay well clear of the water crossings in the 3rd bridge and khwai area as that's where clearance will get you and it's not nice to be stuck in water without a second vehicle to recover. The crossings are particularly deep at the moment from reports.
    Check out @roamoverlanding on youtube he has recently done some of Bots in a very modified Jimny.
    Hopefully the situation improves and you can go safely.
  11. The Following User Says Thank You to ChasingSunsets For This Useful Post:
