Adventure Extreme bend axle and coupler replacement
Results 1 to 11 of 11
    Sep 2010
    Thanked: 21
    Default Adventure Extreme bend axle and coupler replacement
    I need to replace my axle and coupler on my Adventure Extreme caravan. Any suggestions for a replacement axle. the caravan is fitted with a Burquip axle I want to replace the axle with another make. Thanks
    Thanked: 267
    Default Re: Adventure Extreme bend axle and coupler replacement
    Alko is reasonably easy to source .
    CATS
    2003 Safari Xplorer
  3. The Following User Says Thank You to Cats For This Useful Post:
    Thanked: 601
    Agree with Alko, and from Alberton their SA factory is in Vereeninging, relatively close by.
    '89 LR 110 V8
  5. The Following User Says Thank You to Mike N For This Useful Post:
    Oct 2007
    Krugersdorp
    Thanked: 104
    Quote Originally Posted by Henke View Post
    Eine Henke
    What is the axle rating currently and under what conditions did it bend.
    KUBU 4X4 TRAILER RENTAL
    083 631 6995
    [email protected]
    www.kubu4x4.co.za
    Click here for the latest updates in the Commercial Section
    Jannie Engelbrecht a.k.a. Granlor
    Thanked: 953
    Quote Originally Posted by Jannie Kubu4x4 View Post
    Eine Henke
    Agree, you may just need an uprated axle? Also are you overloading or going on very fierce terrain? Often it is good to go with a higher rated axle eg, if you anticipate 1.5 tonnes, go with a 2.5 tonne axle.
  8. The Following User Says Thank You to stephenplumb For This Useful Post:
  9. #6
    Sep 2010
    Thanked: 21
    Eine Henke
    The current rating is 1.6T the GVM is1.5 for the caravan. Yes the conditions was bad I was towing from Mabua to Nossob and hit some holes in one of the dunes where someone got stuck
  10. #7
    Wartburg.
    Thanked: 613
    There is nothing wrong with Burquip axles, they are very reliable and spares is easily available.
    Just fit the the correct axle for the job.
    I think that it is a bit unfair putting this one on Burquip.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  11. #8
    Nigel
    Thanked: 2293
    Yes. Nothing wrong with either Alko or Birquip. Just take a higher rated axle than what was in there.
    Maybe the coupler as well.
    Uniglide
    +27 zero eight 2 four 95 9252
  12. #9
    Thanked: 723
    Something builders sometimes overlook (and please I don't like commenting on other brands negatively, just pointing something out), is the length of axle outside of the leafspring point. The further out the wheels are, the easier the axle will bend.
    The second point is that you get two types of bends
    1. A slow bend over the length of the entire axle - this is caused by harmonics on a corrugated road and with each downward bounce, the resonance adds to the load. You'll note both wheels are equally cambered inwards at the top.
    2. A sharper bend, mostly on one side only and you've no doubt hit a huge pothole.
  13. The Following 4 Users Say Thank You to Heinz Modricky For This Useful Post:
  14. #10
    Sep 2010
    Thanked: 21
    Quote Originally Posted by Chris8d View Post
    No there is nothing wrong with the product it was the after sale service that got me red under the collar.
  15. #11
    Sep 2010
    Thanked: 21
    Quote Originally Posted by Heinz Modricky View Post
    Heinz I think it was a little of both it is corrugation and two deep holes in the sand where someone got stuck in a dune, deflection are the same on both sides about 6-8mm. I am thinking of replacing the axle with 1.8 or 2.5T
