ARB Compressor - HOSE COUPLING
Results 1 to 6 of 6
    Mar 2007
    Thanked: 22
    Default ARB Compressor - HOSE COUPLING
    Hi Guys,
    Inside the quick link hose coupling on the compressor is a small o-ring that prevents leaking when you insert the hose. Mine has "disappeared". Anyone have any idea what the size is? "They" want R 394 for a new coupling; I only need the 50 Cent o-ring....
    Best Regards
    JeanV
    LC76
    May 2013
    Knysna
    Thanked: 11
    Default Re: ARB Compressor - HOSE COUPLING
    Quote Originally Posted by Jeanv View Post
    Hi Guys,
    I had a look at my compressor. I can see what looks like a black rubber O-ring deep inside the coupling. But there is no way I can get it out to measure it. Sorry. But I think even if you had one, it would be very difficult to fit it.
    I wonder how your one could have came out..unless it disintegrated.
    2008 Subaru Forester XT
    2015 Land Cruiser 79 Double Cab 4.2l Diesel
    May 2017
    Thanked: 39
    I experienced the same problem with my hose o-ring than you.
    Went to Adendorffs and buy a small case of o-rings with different sizes for R 55-00.
    One of the o-rings fits.
  4. The Following 2 Users Say Thank You to Laevelder For This Useful Post:
    Dec 2010
    Thanked: 123
    Yes that's the nice thing about the ARB couplings, they are not as obscure to find parts for when compared to the Chinese compressors.
    2019 Ford Everest 3.2 AWD
    2013 Suzuki GV 2.4 sold
    2010 Suzuki Jimny sold
    Wilderness
    Thanked: 1109
    Check the OD of the male coupling, then you have the ID of the O ring.It should not be thicker than 2mm
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Feb 2020
    Las Vegas and Minneapolis
    Thanked: 100
    Is it the 1/4 tubing X 1/8 NPT fitting like this?
    David -
    20 Toyota Tacoma TRD Off Road Decal Edition 3.5L
    If your only tools are a cutting torch and hammer, all of your problems are locomotives...
