Sanding garage doors
Results 1 to 8 of 8
    Gaborone
    Thanked: 812
    Default Sanding garage doors
    So with corona making things quiet I am getting some things done around the house.
    Questions
    1.) how are you meant to sand in the grooves/outlines on a garage door? I want to just leave them.
    2.) should I fill the cracks prior to putting the oil? Or will the just keep breaking/forming?
    ThanksClick image for larger version.
ID:	562663Click image for larger version.
    1997 Discovery 1 300tdi - Pussy Galore
    1996 Discovery 1 V8 - Mr Creosote
    Thanked: 973
    Default Re: Sanding garage doors
    If the doors were only oiled previously you need to sand by hand. Good old hard labor. If previously varnished, you can apply paint stripper and remove with a putty knife.
    12 Conqueror courage
    Dawie van der Merwe
    If you fail to plan, you plan to fail.
    A goal without a plan is just a dream.
  3. The Following User Says Thank You to LandyLove For This Useful Post:
    Johannesburg/Prague
    Thanked: 52
    I would just oil them every 6 months unless you are concerned with the look
    Pajero 3.2 DID Gen 4 Standard for now
    Platcar Alfa Giulietta 1.4 MA
    Swambo Volvo S40 T5
  5. The Following User Says Thank You to 12richardk For This Useful Post:
    Thanked: 57
    If you have used an oil based “dressing” before like I have, I have told that I can just use fine or mid size “steel wool” or lint free cloth and mineral turps to rub off the previous applications.
    I still need to prep and redress our wooden doors. A can of Rubbol is patiently standing and waiting for its boss
    Gaborone
    Thanked: 812
    Just sprayed them off.
    This is a proper job
    Carry on tomorrow Click image for larger version.
    Thanked: 57
    Losts of elbow grease
    Gaborone
    Thanked: 812
    Before and after...
    Its only 50% turps and 60% Dulux timbaseal first coat.
    I know its not a masterpiece but I'm happy so far! Click image for larger version.
    The doors were rather poked in the first place.
    Feb 2017
    Thanked: 29
    Quote Originally Posted by MickeyBlue42 View Post
    Using a high pressure cleaner? I have the exact same doors - also in need of lipstick
