Diff issue.
Results 1 to 20 of 33
Thread: Diff issue.
    Wartburg.
    Thanked: 611
    Default Diff issue.
    Good day.
    What will cause the front diff to crack like this?
    Land Cruiser 79 SC
    4.2 D
    2012 model
ID:	562640   Click image for larger version.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    Thanked: 13606
    Default Re: Diff issue.
    Weight and stress. Repeated impacts that fatigue the metal.
    Not unusual on many heavily used axle housings.
    Wartburg.
    Thanked: 611
    Ek moes so twee maande terug die agter diff op my 3.0 D4D ook laat swys.
    Nie in die center soos daai nie, dit was so half pad tussen die center en die einde van die shaft.
    Kathu
    Thanked: 2839
    There were a problem with welding on some diff housings. Think there were a Recall
    Nov 2011
    Langebaanweg
    Thanked: 1131
    Do they heat treat the casing after welding?
    The heat affected zone is where most cracking will occur.
    Dec 2006
    Thanked: 132
    Quote Originally Posted by Chris8d View Post
    Good day.
    Land Cruiser 79 SC
    4.2 D
    2012 model
    Eina, hoe hard het daai bakkie gewerk
  7. The Following User Says Thank You to Sebastiaan For This Useful Post:
    Langs die rivier, op n berg
    Thanked: 2980
    Is maar n algemene verskynsel op cruiser vooraste. Hulle doen maar dit.
  9. The Following 2 Users Say Thank You to Reenen For This Useful Post:
    Kathu
    Thanked: 2839
    Ek het al gekraakte diffs op alle fabrikate gesien. Ja daar was `n probleem op diff casings van Cruisers.
    Reenen erken jy hierdie diff
    Sorry OT
    Thanked: 2980
    Default Diff issue.
    Oom, as ek so na die onderskrif kyk, reken ek n ou patrol as.
    Ek stem saam enige as kan kraak.
    My comment was nie bedoel as brand bashing, bloot algemene kennis. Cruiser voor diffs (veral na 2007) is maar lief vir kraak.Click image for larger version.
  12. The Following 2 Users Say Thank You to Reenen For This Useful Post:
  13. #10
    Wartburg.
    Thanked: 611
    Quote Originally Posted by Sebastiaan View Post
    By werk hard Sebastiaan, dit border op abuse.
  14. #11
    Wartburg.
    Thanked: 611
    Enige rede agter dit Reenen?
  15. #12
    Postmasburg
    Thanked: 255
    Het ook al n hele paar Cruisers gesien wat dit doen.
    Nogal n duur episode ook om reg te maak.
    My pa het een van syne by Weidemans in Bloem laat weld.
    Baie goedkoper en hom so gery totdat hy hom verkoop het.
  16. #13
    Dec 2006
    Thanked: 132
    Dankie, dit is hoekom ek vra. My Cruiser moet nog lank hou, sal haat om so iets oor te kom veral nou dat verpligte aftreede vinnig nader kom. Het iets soortgelyk gesien so 3 jaar terug by 'n vriend in Namibia op hul jagkar, maar ja, daai Cruiser ry enige plek en drywer is nie eienaar nie.
  17. #14
    Kathu
    Thanked: 2839
    As I said earlier there were a batch of diff`s with problematic welding on the casings that lead to cracking.
    The cases I know of and that is only two persons from which I can supply names, phone numbers if needed.
    Both these Cruisers were used on farms and travelled bad corrugated roads.
    Have seen photo`s of one or two on the net.
    I do not think it is such a common problem as I know of many Cruisers driving the same roads with no ill effects. Some of them on the other side 500k km.
    As I understood there were a recall on certain Cruisers regarding front diff housings. Not sure about this maybe someone with firsthand knowledge should answer.
    Same thing happened to the the old F250 Dana 60 used in these conditions. The guys used to strap them. I know of a Patrol rear housing that cracked and read about the one I posted the photo of.
    I am not referring to other brands to make the Cruiser look better but it is a common problem for vehicles that work hard and carry serious loads travelling bad corrugated roads.
    Replacing the diff housing is an expensive exercise. If welded by a pro welding shop like Mapog mentioned I cannot see why it should not last as long as a new one. It is important to stress relief during the welding process. One also need to make 100% sure all traces of oil have been removed.
  18. #15
    Kathu
    Thanked: 2839
    I wonder if tyre pressure also have something to do with cracks on housings
  19. #16
    Thanked: 13606
    Kyk na axle gussets
    6mm staal plaat, sweis vas weerskante van die pumpkin
  20. The Following User Says Thank You to jelo For This Useful Post:
  21. #17
    Kathu
    Thanked: 2839
    Chris in the area I have encircled is a bracket. Has that perhaps been welded at one stage? I see welding spatter around the bracket.
    If welded that is where the problem started.
  22. #18
    Feb 2013
    Strand
    Thanked: 81
    I've read somewhere on the interwebs that it was mostly the portugese built cruisers that had the diff cracking issue. Check the VIN. TW-T1 Portugal
  23. The Following User Says Thank You to kenskind For This Useful Post:
  24. #19
    Wartburg.
    Thanked: 611
    Spot on oom Christo, hy was al daar geswys, as ook op die shock mountings.
    I did not specifically ask about the Cruiser as such, just what causes this diff cracking in general.
    This Cruiser works hard, very hard and it is amazing that it has lasted as long as it has, overloaded daily and on very bad roads. You can not drop your tyre pressure to help because as soon as you load up again you need to up the pressures, can't do that 4-5 times a day.
    On a D4D Hilux doing the same work, the one the rear diff was welded on, I had to replace the entire upper part that holds the front spring in place, broke off from the chassis. There where you would normally fit spacers, if that makes sense.
  25. The Following User Says Thank You to Chris8d For This Useful Post:
  26. #20
    Thanked: 13606
    Why overload a vehicle like that?
