Minimum energy requirements for engel
Results 1 to 6 of 6
    Jan 2020
    Default Minimum energy requirements for engel
    Hi all,
    Question:
    Can I run an 80L engel fridge off of a 14ah battery/inverter system and a 50W solar panel for multiple stationary days in a Campsite?
    My gut feel is no... But maybe I am wrong, it happens often!
    Stay safe
    Ben
    Thanked: 123
    Default Re: Minimum energy requirements for engel
    Hi Ben,
    Short answer is no. You will need at least a 100Ah battery and 120W plus solar power with a matching solar controller. To cater for overcast days etc and no charging while driving, you will need even more solar capacity.
    You mention an inverter. If it is a 12V fridge, run it from the battery and not via the 220v on the inverter.
    ORRA Callsign: X130
    Jan 2020
    Quote Originally Posted by Subok View Post
    Hi Ben,
    Thank you Subok, I suspected that was the case. Always good to check with the experts though
    Okahandja, Windhoek
    Thanked: 788
    I could run in Desember in the Koakoveld a 80l engel of a 90Ah battery and 150 watt panels. Engel set at -5 deg.
    Johan Kriel
    LCs, Hilux and Echo Chobe
    Lonehill (JHB)
    Thanked: 20
    What made/model panels do you have?
    2014 Ford Ranger 3.2 XLT 4x4 D/C Auto
    2018 Ford Everest 2.2 XLS 2x4 auto (SWAMBO)
    Echo 4 trailer
    Okahandja, Windhoek
    Thanked: 788
    Quote Originally Posted by ChrisH View Post
    It was 3 x 50 panels hinges together. Extra panels that I had from borehole installation. Those days you needed a bank loan to buy the panels. Sold it with the vehicle. The controller was a ctek 250 . So sorry no dont have the make.
    Johan Kriel
  7. The Following User Says Thank You to JLK For This Useful Post:
