Discovery 2 maintenance
Results 1 to 18 of 18
    May 2012
    Nieu Bethesda
    Default Discovery 2 maintenance
    Just bought a Disco 2 2004 GS. What maintenance work should I do immediately to ensure the basics are in order to prevent any major breakdowns going forward?
    Gaborone
    Default Re: Discovery 2 maintenance
    is it TD5 or V8?
    Discovery 2 V8 HSE (2004)
    Discovery 4 V8 HSE (2011), sold now regretting
    RR Sport 5L V8 Supercharged (2015)
    BMW 523i. (2012)
    Conqueror Comfort
    Dec 2014
    Thanked: 1836
    How long is a piece of string?
    What is it's history like?
    Was it looked after well or don't you know details?
    I'd say as a minimum,
    FULL service, all oils, brake fluid, water & anti freeze, fuel and oil filters.
    Balance tyres and rotate if required.
    Wheel alignment, with a GOOD look at ball joints and steering knuckles for boot condition and play/wear.
    Check out the driveshaft UJs for play.
    If it has sunroofs, check the drains are clear.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 913
    If it's got an auto gearbox, have it properly serviced by someone you trust to do it correctly. You can do it yourself but will need an assistant to bleed it correctly when refilling it.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
    Dec 2014
    Thanked: 1836
    Absolutely, yes!
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 1197
    "Balance tyres and rotate if required.".... LRs are perm 4 wheel drive, tyres wear evenly..?
    Forest Hills, KZN
    Thanked: 798
    Not necessarily. Balancing is different for each wheel. However, if uneven wear on the tyres, could point to other issues.
    If Td5, check injector harness for oil and replace. Others as suggested above.
    Also check suspension, coils, shocks, etc. There is a thread recently about a Disco 2 death wobble which turned out to be the coils.
    2003 LR Discovery 2 Td5 ES - mods list to be updated [Husky]
    May 2012
    Nieu Bethesda
    Quote Originally Posted by duncanp View Post
    is it TD5 or V8?
    Td5 Full service history. Last serviced December.
    May 2012
    Nieu Bethesda
    Thanks John. Has a full service history but going to do a service on it as soon as I get it. Are synthetic oils best to use?
    Thanked: 13547
    Quote Originally Posted by Sneeuberg View Post
    Then find a DEKRA / Roadworthy station and let them check for the roadworthy basics. That will close the gaps.
    Thanked: 1112
    Small practical tip: If you do dirt roads NEVER lubricate the 5th door mechanism with penetrating oil, or any other oil - it will turn into a ball of dust/dirt and stop working and it is a biaaaatch getting that mechanism out of a closed door. Been there, done that, got the additions to my vocabulary... Use a graphite-based product.
    I used to go to our place in NB quite often - The Bat Barn. Unfortunately got someone living (squatting) there semi-permanently now.
    1959 SII 88"
    197? RRC
    2002 Defender Td5 D/C
    May 2012
    Nieu Bethesda
    Howzit Etienne. Live next door to the squatter. Beer on me when you're next in town.Come give me some more tips with the Disco.
    Thanked: 1112
    LMFAO - small world on here as well! Will be with you in about 2 weeks.... better stock up on the frothy antidote!!!
    1959 SII 88"
    197? RRC
    Dec 2014
    Thanked: 1836
    Use what is in the RAVE manual, but get the best version you can afford.
    I use Magnatec Synth in my Disco only because I can't find the Bardahl that I used to use any more.
    I have also used Helix and other types over the services. I do my changes at 10k, so a top-line full synth is a bit ott in my mind.
    I had my sump off recently to change the rear main seal and the engine is very clean inside, so I must be doing something right.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 13547
    Is there still a brewery in NB? Can you still buy Buchu?
    B-gowrie Randburg
    Thanked: 293
    2002 Defender 130 DC HCPU. : Own the road...Any road
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8... The Greatest Rover.
    ‘1975 Series3 88 PUP... Simply Classic...
    ‘2017 Metalian Mini ... A Home from Home
    Thanked: 1112
    Jelo, Sneeuberg is the owner of the brewery
    1959 SII 88"
    197? RRC
    Thanked: 1112
    Andre, it is obviously now going to be some time before I get to you. For your information, one of the best Land Rover mechanics that I know of is in Graaff Reinet: Fanie Prinsloo 082 4547306 give him a call when you need help you.
    1959 SII 88"
    197? RRC
