2014 30CRD - CAT/DPF Where ?
Results 1 to 2 of 2
    Ellisras
    Thanked: 515
    Default 2014 30CRD - CAT/DPF Where ?
    Many parts diagrams and lists of the South African Model 2014 CRD Nissan Patrol refer to the vertical exhaust pipe portion pipe just after the Turbo as the Three Way Catalytic Converter
    I see no sensor before/after
    1 - What is really inside that dump pipe ?
    2 - Where is the DPF located ?
    Part number : B08A0VS60A .....
    Note that the front section of the Exhaust is listed as part " 200B0VV30A TUBE-EXHAUST,FRONT WITHOUT CAT CONVERTER"
    There is nothing further on the exhaust that resembles a DPF ?
    Thanked: 12783
    Default Re: 2014 30CRD - CAT/DPF Where ?
    My initial response is that no DPF has been fitted. ZA doesn't require one.
    I see you've already posted the question on the Patrol forum.
