Solar panel and camping fridge
Results 1 to 20 of 20
    Thanked: 104
    Default Solar panel and camping fridge
    Question out of curiosity - say you are in the bush and find that your caravan's deep cycle battery stops working.
    I think one would say - it does not keep charge anymore from your solar panel.
    Can you run a fridge/freezer directly off the solar panel?
    Thanked: 658
    Default Re: Solar panel and camping fridge
    Depends on the size of the panel and the soft startup current the fridge requires.
    But if your panel is able to produce 7-8 amps it should work. But the panel will need to be aligned with the sun constantly.
    Overcast days, not a chance.
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
    Ellisras
    Thanked: 477
    Experts to comment, but herewith my take:
    If you connect your panel directly to the fridge one of 2 things will happen
    - Low voltage panels (18-22V) - the fridge will be confused if it is a 12V or 24V supply and in all likelihood switch to 24V and then shut down due to sensing low voltage.
    - Higher voltage panles - depending on how well the fridge control panel is designed to deal with over voltage, serious damage may occur
    It is unlikely that you will suddenly experience a dead short battery while camping, just dwindling capacity (""ability to hold charge"")
    Therefore - keep the battery connected to the Solar controller and the fridge to either the battery or the load connection on the controller...
    When you do not have sun you wont have power to the fridge
    Last edited by Dungbeetle; 2020/03/17 at 04:30 PM. Reason: tihc fnigners tiny keybrod
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 847 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar"
  4. The Following 7 Users Say Thank You to Dungbeetle For This Useful Post:
    Okahandja, Windhoek
    Thanked: 789
    Just checked NL website! 'All National Luna Portable refrigerators can accept a DC voltage ranging from 9.6V to 31.5V, as well as an AC voltage range from 85V to 265V'
    Johan Kriel
    LCs, Hilux and Echo Chobe
  6. The Following 3 Users Say Thank You to JLK For This Useful Post:
    Ellisras
    Thanked: 477
    Correct - meaning a DC source (Panel) with higher voltage than 32V could let the smoke escape from the NL circuit boards
    Thanked: 658
    A solar panel of 130 Watt produces about 7-8 amps under optimal conditions.
    If you have a panel of say 200 Watts and still utilize a solar charge controller in the mix I believe this could work given the NL figures quoted above.
    But the two solar charge controllers I have explicitly state to connect the battery to the controller first, for fear of shorts or high voltages that could damage the load circuitry.
    So yes, I think it best to rather also keep the battery in the mix.
    Nico Swart
    ZS6NJS
  9. The Following 2 Users Say Thank You to Die SwartKat For This Useful Post:
  10. #7
    Thanked: 104
    Thanks for the replies.
    We too thought that it would be best to keep the batteries in the scenario, whether they charge or not.
    Was just not sure if there is another way of getting around "dead" batteries, therefore the question.
  11. #8
    Feb 2017
    Boksburg
    Thanked: 36
    While on similar topic, and welcome to refer me to other posts. I bought a small RV with a voltage sensitive relay module installed. RV also had 2 old small solar panels on roof but scrapped. What is this and does the solar panels connect directly to this or what is needed. I see 125 amp on unit. What size solar panels can be used if any?
    Anybody in East Rand JHB that can help with advice?
    ThanksClick image for larger version.
  12. #9
    Feb 2017
    Boksburg
    Thanked: 36
    Zoomed photo Click image for larger version.
ID:	562279Click image for larger version.
  13. #10
    Thanked: 415
    Based on the pictures it is a relay that would charge a 2nd battery only while driving - ignition protected. The cut in is when the alternator is actually charging to charge the 2nd battery and cut out is when the engine is switched off. This more or less like how the NL solenoid is working.
  14. #11
    Feb 2017
    Boksburg
    Thanked: 36
    Thanks. Any idea what the Solar at bottom then does ? Do you think it is fed from a controller or direct panels.
  15. #12
    Thanked: 127
    I see bepmarine.com is the supplier. Perhaps contact them for a manual?
    ORRA Callsign: X130
  16. #13
    Sep 2019
    Thanked: 312
    On my last trip to the kgalagadi, my solar connecter to the battery shorted and basically fried my battery. For about 2 week I still managed to run my fridge via the controller and the solar panel whilst battery was still connected. The battery would be close to dead each morning but the system still managed to run the fridge
    2006 Discovery 3 TDV6.
    2003 Jeep Cherokee 2.4 - Surprisingly capable
    1996 Suzuki Samurai - work in progress
  17. The Following 2 Users Say Thank You to Philip72 For This Useful Post:
  18. #14
    Dec 2006
    Thanked: 113
    Anybody know of a solution to OP's question if the fridge/freezer has a built in battery protector.
    I presume the safety feature will then become your enemy
  19. #15
    Thanked: 658
    Quote Originally Posted by Sebastiaan View Post
    The fridge should see the voltage coming from the solar panels, not that of the battery.
    Nico Swart
    ZS6NJS
  20. #16
    Aug 2016
    Thanked: 107
    Technically speaking you are quite expert enough. This is the best comment on this thread.
    You can listen to this man !
  21. The Following User Says Thank You to Pieter de Waal For This Useful Post:
  22. #17
    Thanked: 104
    Sorry, I should have come back with additional info.
    First of all, the National Luna fridge/freezer does have battery protection built in. Secondly we use a 130 watt solar panel, but can add an additional 180 watt loose standing panel.
  23. #18
    Feb 2013
    CT
    Thanked: 107
    Keep using the battery as a capacitor to smooth out any voltage fluctuations and enjoy your camping during daytime and nighttime switch the fridge off..Don't run the fridge direct from the solar panel...
    VW TDI
    Dries de Kock
  24. The Following 2 Users Say Thank You to kadafi For This Useful Post:
  25. #19
    Sep 2018
    Thanked: 99
    Quote Originally Posted by kadafi View Post
    This is the best advice - the voltage from the panels will fluctuate with angle of sun, cloud cover etc. Can't be good for your fridge.
  26. #20
    Oct 2017
    Port Edward
    I have a 100W solar panel that shows MAXIMUM SERIES FUSE 10A. My charge controller is 20A. This will be plugged into my NL power boxes grey plug. Will this be ok?
