MDF Varnish Problem
Results 1 to 20 of 20
    Gaborone, Botswana
    Thanked: 1203
    Default MDF Varnish Problem
    Over the years I have varnished plenty of MDF board. Using from the cheap house brand varnish to Dulux Int/Ext varnish. Never had a problem.
    I now have this small desk tops I'm doing. I do the first layer and then let it dry/cure for a few days. The thin second layer then goes on. It is enough to give a decent gloss finish.
    I now experience this "wrinkles" on the surface. It is as if it was applied too thick and then it dries on the outside while still not cured below.
    What is happening here?
    EDIT: This was Fired Earth Velvet Wood from BW. The previous batch was done with Dulux Interior/Exterior Timbavarnish. The Dulux had worse results.
    Kobus
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    Default Re: MDF Varnish Problem
    Are the two layers from different layers? Perhaps incompatible solvents in the mix?
    Gaborone, Botswana
    Thanked: 1203
    The 2 layers are always te same brand.
    Kobus
    Langebaan
    Thanked: 45
    MDF is very porous, but not consistently the same. I cannot really see the wrinkles, the darker spots may be denser, did not soak in as much as the surrounding material, more varnish (thicker) on top. Sand level and keep recoating with thin layers until all builds a thin glossy layer on top.
    M2cw
    Thanked: 522
    Maybe the first coat had not cured properly, and the solvent in the second coat has softened the first coat again?
    Fibreglass gelcoat do exactly that when you apply a second coat if the first has not cured properly.
  6. The Following User Says Thank You to faniedup For This Useful Post:
    Mar 2012
    Thanked: 1207
    Canít see nicely but is it not that the mdf board is actually creating the wrinkles because itís porous and absorbing the moisture more in that area.
    Donít know if that makes sense. Maybe itís my eyes playing tricks on me.
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
    Friemersheim, Southern Cape
    Thanked: 3253
    I have found MDF boards with 'harder'/more dense sections where absorption is different to other areas.
    Moisture also problematic but don't think in Gaborone an issue
    Tshwanetoria
    Thanked: 799
    Is that the first or the second coat? The board is not darkened, so it looks like the first coat?
    If it is the first coat, then maybe something incompatible (such as silicon) was spilt on it?
    Did the wrinkled areas cured or are they still soft?
    Debbin
    Thanked: 59
    When say varnish, is it actual varnish, the turps based old school oily stuff, or some type of more modern Alkyd or Nitrocellulose based paint?
    if itís old style turps based oil varnish, over coating shouldnít be a issue if the 1st coat is properly dry, sometimes 2 days.
    with a NC based product you should be able to overcoat after just a few hours
    Alkyd based paints donít like to be overcoated and will almost definitely wrinkle
    also keep in mind that not all mdf is the same, some boards have more oil in it.
    some appear pink, some yellow, I think the pink is local, the yellow import.
    try with a nitrocellulose product. Plascon has Ss015 sealer which works well, then overcoat with a nitrocellulose gloss clear
    Gaborone, Botswana
    Thanked: 1203
    It is a week after the second coat.
    This "wrinkles" only appeared a few days after the second coat was applied.
    Kobus
    Gaborone, Botswana
    Thanked: 1203
    Quote Originally Posted by RvanZ View Post
    It is the old school stuff. I mentioned the products in the first post.
    Kobus
    Nov 2011
    Thanked: 985
    What happened here-I'm fairly certain-is...
    The first coat penetrated into the MDF, and had a long time ( several days, you say) to dry.
    It dried with a few 'furred' patches/nibs, which did not allow varnish to form a full and complete 'seal' of the surface.
    On second coat, some of the varnish/solvent drew into the MDF at these areas -and the solvent migrated under the first coat adjacent to the incomplete seal, and allowed the first coat to soften and expand again and thus to form the wrinkling -I'm thinking!
    Some paints specify maximum overcoating times, as well as minimum, for this reason.
    - Charles Bukowski
    Gaborone, Botswana
    Thanked: 1203
    Quote Originally Posted by Patrick L View Post
    Sounds possible BUT .... I have done literally hundreds of this over the last few years. Always using the same 2 coat method. Nothing has changed. It is the first time this happened.
    What is the chance that the MDF is to blame?
    Kobus
  15. #14
    Nov 2011
    Thanked: 985
    I agree! it's the MDF to blame! -horrid stuff, really, in all respects of working with it, until finally finished and coated.
    It could be the cheap import MDF nowadays is not pressed as firmly and densely as before.
    Same with chipboard-
    when PG Bison were around, one could get premium quality chip/mdf/ ply/ osb at good price -nowadays it is mostly imported inferior stuff.
    Happy sanding!
    - Charles Bukowski
  16. #15
    Tshwanetoria
    Thanked: 799
    How wide spread is the problem, only a few localized spots, or all over the board?
    Both side or only one side?
    Any chance that the board was contaminated after the first coat? From rat's pee to silicon spray and anything in between? Children in the vicinity that could have done that?
    Sorry for the many questions, but this is a strange phenomena that I have never encountered in my many years of doing the same. Unless consecutive thick coats are applied without observing the during times. But you first coat is hardly noticeable, so that is highly unlikely.
  17. #16
    Thanked: 262
    It is the wax used when manufacturing the MDF board. You get special undercoats for MDF.
    Technipaint: Elvolac make a good undercoat for MDF.
    I spray a lot of Mdf
    IT stops the edges absorbing spray paint as well.
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
  18. #17
    Gaborone, Botswana
    Thanked: 1203
    Not really wide spread. The desk tops are 650 x 500. The bad area in the first image is one of +- 120 x 80. 4 out of 36 boards have one bad area.
    The bottom only get one coat. See pic. The top side was like this before the second coat.
    No rats or children . I'm the only one around. Only some dust I get rid of with compressed air before I apply the second coat.
    Kobus
  19. #18
    Tshwanetoria
    Thanked: 799
    Hallo Kobus. I am a bit stumped, so I will be giving my best shot. I forgive me if I do not express myself as best as I should, in the Inglish tale
    The random appearance as well as the geometry of the faults, makes me think that it is something that happened to the MDF before you received it - in other word some form of "contamination"
    Here I tend to agree with RobbieF that it could be the wax (lubricant) used during manufacture. Either a fault during the process where some was "spilled" by the machine, or insufficient sanding at the end of the process which is inter alia meant to remove such "spillages" (not all processes sand afterwards)
    Either way, when you applied the first coat, that coat was prevented from penetrating/bonding without you noticing is, due to the contamination.
    When you applied the second coat, that coat lifted the first coat and when it dried, it shrinked the first coat, hence that wrinkled appearance. The same effect you get when painting a newspaper. I think a final test for this theory would be to scratch off the problem varnish with your finger nail to see if there was any bonding of the first coat with the MDF.
    Have you sanded the MDF properly before applying the first coat? That would have removed any waxes, which by its nature, do not really penetrate. Speaking for myself, I wouldn't have done that, since MDF is mostly pretty smooth, and I would rather do that between coats.
    PS. Apart from the fact that I have some experience, none of books on the subject gives any other explanation than the ones mentioned earlier (layers too thick/insufficient curing time/ incompatible solvents/ surface contamination) Hence my fascination with your problem.
    Keep as posted!
  20. #19
    Dec 2014
    Thanked: 1918
    Those mark look like smudges where something has rubbed against the board, either at the factory or at the retailer.
    Could have been something as innocent as chip fat off the worker's hands from lunch or a dirty glove etc.
    I have seen similar effects from painting metal that was contaminated with off-cut rags from the rag trade that were silicon treated in the cutting room.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  21. The Following User Says Thank You to JohnnoK For This Useful Post:
  22. #20
    Thanked: 1153
    I am not an MDF user, but stumbled into this and thought some of you guys may find this Yank's painting of MDF interesting.
    https://www.youtube.com/watch?v=2BYdxSTgOkM
    Hier is 'n ander benadering:
    https://www.youtube.com/watch?v=YRPHjUt6Hww
