lighter socket
Results 1 to 4 of 4
Thread: lighter socket
    Mar 2011
    Boksburg
    Thanked: 64
    Default lighter socket
    hi all. so the bitdi also has the 2 sockets in the centre console, one on top of the dash and one in the loadbin.
    drivign long distance my family of 4 has 3 tablets and 4 cellphones active at any given time charging a combination of these.
    what are the limits on these sockets and are they all running through the same 15amp fuse?
    dare i buy an extender to extend one of the sockets to the back seat where the kids will happily max out any available charging ports (2 tablets, 2 cellphones).
    2015 Amarok BITDI D/Cab 4 Motion
    2011 Amarok TDI D/Cab 4x2 (SOLD)
    2001 Isuzu KB 320 V6 D/Cab 4x2 (SOLD)
    DISCLAIMER: I'm not an expert in the subject posted about above, i'm a member of an internet forum only and my comments, advise, suggestions and ideas should be taken from that point of view
    Thanked: 16
    Default Re: lighter socket
    Is it a 15 amp or 10 amp fuse?
    Phone or tablet charges at 2.1amp on a fast charger. 1 amp on normal charger. So you will be fine with 3-4 devices connected at once. You can easily extend the lighter socket to the rear.
    Respect the Horn
    2018 Hilux 2.8 GD6
    2012 Fortuner 2.5
    2012 Conqueror Courage
    Jan 2019
    White River
    Thanked: 16
    USB ports are only 5 volts. Current is less than 50 % on 12v supply to USB port.
    Dec 2013
    Reebok, Mossel Bay
    Thanked: 88
    According to my info:
    Fuse 43: 25A
    - Electric socket -U-
    - Cigarette lighter -U1-
    Fuse 46: 25A
    - 12V socket 2 -U18-
    - 12V socket 3 -U19-
    I assume Fuse 43 is for inside cabin, and Fuse 46 for load bin ??
    You should not have a problem.
    I attach fuse positions; so, you can pull the 25A fuse(s) out to test if it is the specific fuses.
    I have never tested.
    Herman Meyer.
    AG0017 ORRA AG38
    2014 Amarok DC 4Motion Auto ,
    2015-02-03: Bush Lapa Miskewer 394.
