Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 63
    Jul 2019
    Thanked: 30
    Default Metalian Genie Super Thread
    I could not wait to finish the electrical installation before starting this thread, so I am going to post as I make progress.
    Blue BH plug fitted as input from the solar panels.
    Fuse box and solar regulator fitted next to battery bracket. The solar regulator will be upgraded to the WRND dc-dc charger with build in MPPT when my Tow vehicle is ready for it.
Name:	Fuse Box and Regulator.jpg
    Access between trailer main body and nosecone.
Name:	Main Body Side.jpg
    Still a lot of work to do....
    * 2014 Honda CR-V I-DTEC
    * Metalian Genie
  2. The Following 4 Users Say Thank You to StephanF For This Useful Post:
    Oct 2007
    Krugersdorp
    Thanked: 123
    Default Re: Metalian Genie Super Thread
    Hi Stephan that BH plug might be a bit exposed. One stone hits that and its broken. Maybe a protection plate will help to keep it whole.
    KUBU 4X4 TRAILER RENTAL
    083 631 6995
    [email protected]
    www.kubu4x4.co.za
    Click here for the latest updates in the Commercial Section
    Jannie Engelbrecht a.k.a. Granlor
    Brackenfell
    Thanked: 562
    Quote Originally Posted by StephanF View Post
    I had one of those regulator on my system last year and it malfunctioned and resulted in Lost battery. Keep an eye on it. Backup for them(wrnd) are a bit MIA. Still waiting for a return call from him/reply after numerous messages. Dumped it and bought something different from a more reliable source with aftersales support.
    Jul 2019
    Thanked: 30
    Thanks for the heads up. Wean from WRND is a good friend of mine and I stay like 4km from him, so that sort out the after sales service for me. At a later stage I will replace the regulator with the dc-dc charger.
    * Metalian Genie
    Jul 2019
    Thanked: 30
    Quote Originally Posted by Jannie Kubu4x4 View Post
    Thanks. Will have a look at it.
    * Metalian Genie
    Jul 2019
    Thanked: 30
    Further photos of my electrical installation.
    * Metalian Genie
  8. The Following 2 Users Say Thank You to StephanF For This Useful Post:
    Thanked: 1017
    That BH is mounted behind the wheel and has protection from the mudguard - a mudflap will add to the protection.
    Jul 2019
    Thanked: 30
    Quote Originally Posted by Heinz Modricky View Post
    Yes, that was my thought as well.
    * Metalian Genie
    Jul 2019
    Thanked: 30
    Not really Metalian specific, but I built these lights for overhead lighting at the kitchen area. It will fit nicely under the fridge slide.
    * Metalian Genie
    Jul 2019
    Thanked: 30
    I did a template using carton for the area above the battery. As soon as lockdown is over it will be done using 9mm plywood.
    * Metalian Genie
  13. #11
    Jul 2019
    Thanked: 30
    I had laminate flooring left overs and decided to use it instead of waiting for the lockdown to end.
    Will add the hinges after lockdown.
    * Metalian Genie
  14. The Following User Says Thank You to StephanF For This Useful Post:
  15. #12
    Jul 2019
    Thanked: 30
    Added an aluminium frame behind the fridge for the steadies and other odd stuff.
    * Metalian Genie
  16. The Following User Says Thank You to StephanF For This Useful Post:
  17. #13
    Sep 2010
    Noordhoek
    Thanked: 326
    Really looking Stephan.
    Where did you get the track for the fridge cable?
    Sam
    ZS1SAM
    V5/ZS1SAM
    Bush Lapa Bosluis B2464
  18. #14
    Thanked: 21
    Nice work! This is what I call proper CAD work (Cardboard Aided Design)
  19. The Following User Says Thank You to gotto For This Useful Post:
  20. #15
    Jul 2019
    Thanked: 30
    Quote Originally Posted by SamM View Post
    I ordered from Wish. But knowing what I know now, will rather use Banggood.
    Edit: It is called a drag chain
    * Metalian Genie
  21. The Following User Says Thank You to StephanF For This Useful Post:
  22. #16
    RUSTENBURG
    Thanked: 8
    You can buy the energy chain from Igus in Johannesburg.
    It really works well to keep the cable out of the way of the fridge slide.
  23. #17
    Jul 2019
    Thanked: 30
    My power panel version 2. Also changed the solar regulator to WRND dc-dc and mppt charger.
    PS: Does anyone have tips on how to remove double-sided tape residue without damaging the powder coting?
    * Metalian Genie
  24. #18
    Thanked: 1017
    No thinners, acetone for a starter. Try turps or Xylene. I've seen a kind of plastic wheel that goes on to a grinder that removes stickers and therefor guess you can try mechanically rubbing it off with a a hard flexible type rubber, like try the yellow soles you get on shoes. Let us know!!
  25. The Following 2 Users Say Thank You to Heinz Modricky For This Useful Post:
  26. #19
    Mar 2012
    Thanked: 1670
    mentholated spirits?
    GaryG
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
    4.0 XJ Jeep Cherokee - Sold
  27. #20
    Jul 2019
    Thanked: 30
    I realised why the new Genies will have (at least as on option as I understand it) the driver side cupboard albeit a narrow one, when I wanted to create a slide in for solar panels. I had to make a retrofit plan. Still need to get some plywood for the top.
    Problem is now my existing camping table don't fit in the trailer anymore.
    * Metalian Genie
  28. The Following 2 Users Say Thank You to StephanF For This Useful Post:
