Show your grid/rooster
Results 1 to 7 of 7
    Thanked: 82
    Default Show your grid/rooster
    Wat is ń rooster in Ingels? I want to make myself a new grid, after my previous one disappeared. It was 304 stainless expanded metal (punched) with 5mm round bar.
    I have seen the adjustable one, the one with the slots at the back that you slide in the top part according to the thickness of the chops, are they user friendly? I donÂ’t have a build in braai and take my braai when I go on holiday, so the grid will fit my braai.
    I have looked at the woven mesh with a 25mm hole, but think it migh be heavy, but will retain good heat? Please give some advice and show you rooster (not the animal). Kobus asb
  2. The Following User Says Thank You to emileheyns For This Useful Post:
    Thanked: 1003
    Default Re: Show your grid/rooster
    Quote Originally Posted by emileheyns View Post
    Emile contact FL Schmidt, they often have off cuts of varying types of stainless mesh that you can look at and buy. Bought mine there 12mm aperture and 2mm wire, welded a 12mm round bar frame to it.
    Rooster = Grid
    Thanked: 82
    Rooster = Grid
    I can get the woven mesh in town, but before I spend R500 on materiaal I am wondering if there is not an alternative?
    Apr 2018
    Fraserburg
    Thanked: 935
    304 Stainless will corrode. My 316 stainless is 24 years old this year and still in use. Never cleaned except by burning it clean. Just chucked into a black bin bag when camping to stop it dirtying anything else. I have a built in braai at home but the stainless grid is used on top of the built in grid. Easier to turn.
    Thanked: 82
    O yes, another requisite for me not to handle it witusod kid gloves: if I wwant to clean it before the braai I want to put it in the flames and burn it
    Dec 2014
    Thanked: 1918
    Rooster is Ingils.
    Afrikaans is `n hoenderhaan.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    durban
    Thanked: 1120
    304 may tarnish but i doubt it will not be up for the job. Sure 316 is better. but I doubt I would live long enough for it to make a difference.
