400w dc motor
Results 1 to 19 of 19
Thread: 400w dc motor
    Nigel
    Thanked: 2330
    Default 400w dc motor
    Hope this question is in the right place.
    I need about 400w with a shaft speed of about 500rpm.
    I want to go dc because then I am not bound to the input power.(110v-220v)
    Any suggestions?
    Want to design a lightweight Timken friction tester.
    The current jig is 12,5kg. Need to scrub that weight, plenty.
    Uniglide
    +27 zero eight 2 four 95 9252
    Hillcrest, Malaysia
    Thanked: 6614
    Default Re: 400w dc motor
    Any suggestions?
    DC motors are notoriously difficult to control the speed without effecting the Power, and most run in the many thousands of RPM.
    I don't know of any DC motor that runs at anywhere near that speed without a gearbox.
    I would rethink the requirement.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Mar 2012
    Thanked: 1276
    This might sound stupid with my limited knowledge but canít you use a stepper/servo motor?
    GaryG
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
    Thanked: 553
    Thanked: 602
    Any suggestions?
    With drilling machine as cheap as they are it would be your best bet. Get a good low speed drill after it'd own gearbox that turns at about 600 r.p.m otherwise you will have low power if you use a high speed drill if you reduce the speed. You can always use a SCR/TRIAC speed control. Drill motors are universal and can be run on AC or DC.
    Makita do make a 900rpm big drill but I have no idea of the price.
    What would be wrong with AC that you want to power it from DC?
    Nov 2017
    Thanked: 214
    Try a windscreen wiper motor.
    Thanked: 553
    Quote Originally Posted by HobieDave View Post
    It runs at 24 rpm
    Nigel
    Thanked: 2330
    Countries run diff AC.
    But I will def look into the drills.
    Uniglide
    Thanked: 553
    It runs at 24 rpm
    Sorry, that should read 120 rpm
    Hillcrest, Malaysia
    Thanked: 6614
    Nearly all modern power supplies can run off virtually any freq or voltage. Somebody is probably going to need one of those to make the DC anyhow.
    ZS5KAD
    3 V8's
    Jan 2015
    Thanked: 215
    How about a Centurion D5 gate motor. The motor inside is normally 800W 12V DC.
    I have built one onto my lathe as a cross feed drill, running through a PWM speed control. Can control speed from about 5rpm to 3000rpm.
    durban
    Thanked: 1178
    Quote Originally Posted by ghouwens View Post
    You have to show us a pic of this as well.
    Jan 2015
    Thanked: 215
    https://www.homemadetools.net/forum/...nd-drill-75246
    Thanked: 602
    80W or 800W?
    Jan 2015
    Thanked: 215
    80W or 800W?
    Apologies. Went back and had a look and it is 80W. My bad!
    Hillcrest, Malaysia
    Thanked: 6614
    Yes, but isn't is geared.
    ZS5KAD
    3 V8's
    Jan 2015
    Thanked: 215
    As a gate motor, yes.
    Gaborone, Botswana
    Thanked: 1251
    18V Cordless drill ?
    Kobus
  19. The Following User Says Thank You to KobusDJ For This Useful Post:
  20. #19
    [REMOVED]
    Thanked: 278
    For such a device wouldn't you rather look at torque requirement instead of the wattage?
    and is it even physically possible without gearing to get 500RPM out of a normal motor.
    If 110V/220V AC and the weight is a problem for you where would you find a power source that can provide 400Watts ?
    Once you know the amount of torque it will be easier to find a solution. I think you should be able to find a stepper that can do what you need.
