Connecting solar panels in series or parrallel
Results 1 to 11 of 11
    May 2007
    Welgelegen, Cape Town
    Thanked: 167
    Default Connecting solar panels in series or parrallel
    When connecting two solar panels (12v), do you connect them in series to gain more volts, or in parrallel to gain more amps..
    I overheard an dicussion, stating connect in series, so if it is overcast you will get more volts for charging...
    Kindly advise.
    Toyota D4D Legend 45
    Triton Clubcab 2x4 2.5 DID
    Bushlapa Vlooi 652
    Thanked: 172
    Default Re: Connecting solar panels in series or parrallel
    Quote Originally Posted by Kaptein Jack View Post
    Kindly advise.
    There are things you can do, and should do.
    This is something you shouldn't do.
    I wouldn't, for a 12V setup, put two (17V iirc) solar panels in series if it is overcast.
    The risk you run is if you get a little more sunshine than would give around 17V, (ie potentially around 30V on good sun) you risk providing an overvoltage to the regulator, potentially blowing it.
  3. The Following 2 Users Say Thank You to Mtber For This Useful Post:
    Aug 2017
    Durban or Centurion
    Thanked: 1231
    What is the maximum input for your charge controller - VOC and Amps.
    What is the rated VOC and Watts of your panels?
    Charging is not just a voltage game.
    If in series, and one panel has some shade on it, the entire string will be limited.
    May 2007
    Thanked: 167
    Bushlapa Vlooi 652
    Friemersheim, Southern Cape
    Thanked: 2954
    Do you want a 12V system (parallel) or a 24V system (series)?
    May 2007
    Thanked: 167
    The purpose would be to charge two aux batts connected in parrallel in my vehicle
    Bushlapa Vlooi 652
    Okahandja, Windhoek
    Thanked: 812
    With some controllers you can go series to a certain limit in volts. With overcast conditions the series connection will helps a bit that controller kick in quicker, other wise nothing to gain. Parallel have certain advantages, if one panel is in shade etc then charging is reduced due to the one and not for all panels.
    Johan Kriel
    LCs, Hilux and Echo Chobe
    Thanked: 2954
    Thus a 12V system.
    Ellisras
    Thanked: 523
    Just do the Parallel thing.....
    Thanked: 71
    Absolutely ! If you go Series then you loose the whole string of panels, if you get into partial shade situations eg under a nice tree ...
    UZJ 42 LX: Olive (Sold)
    HDJ 75 RV Troopy
    Feb 2013
    Thanked: 207
    Valid points already raised in this thread.
    Ultimately in small systems like we typically use for camping it is much of a muchness, series over parallel won't give you any real advantages.
    Yes if your controller can handle higher volts you can go series, this will result in higher charge voltages and lower current, which might also be favourable for cable sizes.
    However the problem with series wiring which is a reality in our camping aplication is shading. If you have your panels in series and one of the panels goes in to the shade, your entire solar array will basically be dragged down to that level. Where if your panels are in paralell, only that specific panel in the shade will have reduced output, the panels out in the sun will still perform well.
    For camping stay with parallel wiring in my opinion.
    I don't drink water, unless it's been through a brewery first.
    "The darkest places in hell are reserved for those who maintain neutrality in times of moral crisis." - Dante Alighieri
