Fuel light flashing. Full tank of fuel.
Results 1 to 15 of 15
    Feb 2020
    Thanked: 13
    Default Fuel light flashing. Full tank of fuel.
    So my 2018 GV developed this little quirk today.
    Tank is full and the reserve light is flashing. Obc range shows ó-
    I checked the battery and the float voltage is 12.6. I know that a dying battery will cause gremlins on these cars but what else can this be?
    Not overly impressed. Iíve only had the car for three days
    Thanked: 1378
    Default Re: Fuel light flashing. Full tank of fuel.
    The battery will normally last 5-7 years. It might not be the battery.
    Sent from my iPhone
    Feb 2020
    Thanked: 13
    I disconnected it for 30 minutes to see if that resets the light. Didnít make a difference.
    Guess we are heading back to the dealer. Three days after taking delivery.
    Jun 2016
    Randfontein
    Thanked: 1829
    Hold on. Sometimes when you leave the ignition on when you fill up it confuses the computer. I had it with my Baleno as well. Dive it for about 200km so that it re calibrates.
    Willie
    2020 Nissan NP300 2.5TDi S/C
    Feb 2020
    Thanked: 13
    It started when I left big red barn this afternoon.
    Filled up on the way back to see it it resets and it didnít.
    Doing a trip to hennops tomorrow so Iíll see if it resets.
    Thanks for the tip.
    Wilderness
    Thanked: 1134
    Dirty fuel filter/ water in the fuel?
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Feb 2020
    Thanked: 13
    I assume both if those would have an effect on the engine itself. Misfires etc and if it affects the fuel gauge it would have been intermittent.
    3rd Rock from the Sun
    Thanked: 17
    This happened to me a few years back, I filled up with my ignition on and I had to take it back to the dealer to reset software.
    Feb 2020
    Thanked: 13
    Quote Originally Posted by Big Ray View Post
    Thank you. Hope itís a simple fix like that.
    Thanked: 17
    Give the dealer a call and have a chat to the service department, they'll tell you exactly whats wrong and what they need to do to fix it.
    Let us know once you've had it seen to?
    Feb 2020
    Thanked: 13
    Will so.
    I needs to go back anyways. The sunroof has quite a loud rattle.
    Feb 2020
    Thanked: 13
    Looks like itís the battery.
    traction control light on (went off again while driving but I couldnít switch it off again)
    system check flashing on the radio
    will get the dealer to replace it since Iíve only had the car for 4 days.
  13. The Following User Says Thank You to maxxis2112 For This Useful Post:
    Feb 2020
    Thanked: 13
    Looks like this wasn't a problem mechanically but rather organically.
    Let's continue the discussion here -> https://www.4x4community.co.za/forum...sified-as-rat!
  15. #14
    Jan 2020
    Gaborone
    Wait, whats a GV?
    Matthew T Mutepfa
    Ēdonít be too serious about itís just life after allĒ
  16. #15
    Feb 2020
    Thanked: 13
    Quote Originally Posted by MatthewMutepfa View Post
    Wait, whats a GV?
    Grand Vitara
