A little help please
Results 1 to 6 of 6
    Feb 2016
    Paarl
    Thanked: 590
    Default A little help please
    My Corsa LDV...the door runber on the passenger side keeps pulling loose when someone gets out. Tried to silicone it in place, but didn't last long.
    Any idea what 'the right stuff' to glue rubber to the metal doorframe would be?
    1996 Discovery 1 (SOLD)
    2001 Mercedes C180 (SOLD)
    2012 Nissan Xtrail 2.0 (Weekend Wagon)
    2010 Kia Sedona 2.9Crdi (Written off)
    Pretoria, Hartbeesfontein
    Thanked: 684
    Default Re: A little help please
    Quote Originally Posted by Nitebob View Post
    Contact glue?
    Robert
    '09 VW Caddy Maxi TDi
    '06 Citroen C3 1.4HDi8)
    '97 Isuzu 280 S/C plaasbakkie
    cape town
    Thanked: 154
    Can't vouch for it as a solution for door rubbers but sikaflex (moisture cure) worked well for gluing down the rubber around my windscreen - it cures harder & tougher than silicone. Silicone, being acetic cure, will corrode / rust metal.
    https://www.builders.co.za/Fasteners...00000000521108
    Jan 2015
    pretoria
    Thanked: 83
    Genkem........you put it on both surfaces, let it dry a tiny bit then put it together. It will last, sikaflex is an option....but a messy one. It sticks to you for a couple of weeks. I only use it to stick windscreens and 1/4 glasses.
    Feb 2016
    Paarl
    Thanked: 590
    Thanx guys
    Jun 2016
    Randfontein
    Thanked: 1475
    +1 for Genkem
    I have used it in my Landys window rubber and it works
    Willie
    2016 Audi A3 1.8 TFSI SE S-Tronic 3Dr
