Freelander 2 keyfob help
Results 1 to 15 of 15
    Mar 2019
    franklin roosevelt park
    Default Freelander 2 keyfob help
    Hi
    I have a 2009 freelander 2. The main keyfob works but recently it struggles to open the car. Locking is no problem. I usually have to press the button multiple time for it to unlock.
    The spare keyfob is dead. I got an engineering buddies to pry it open. The battery was still alive but it looks like the keyfob is dead.
    Landrover quoted 8k for a new keyfob. Is there anyone that can help with this?
    Oct 2015
    Thanked: 67
    Default Re: Freelander 2 keyfob help
    Quote Originally Posted by eboo View Post
    Hi
    Claim from insurance as.an option.
    Discovery Landrover 3 tdv6 2008
    Volvo S40 T5 2006
    Dec 2018
    Thanked: 19
    Change the battery a full charge will be better,
    Thanked: 145
    Have your engineer buddy check all the joints - ours had a loose joint that made life difficult.
    Si vis pacem, para bellum
    Mar 2019
    We changed the battery anyways. Still the same outcome
    Mar 2019
    Double checked all the joints with him as well
    Dec 2018
    Thanked: 19
    Is it a Land Rover Key or aftermarket?
    Thanked: 853
    These guys made a new one for me for my Patrol, not all that expensive, about R2k. They are in Eloff Street Extn.
    https://www.google.co.za/maps/place/....0433864?hl=en
    Then I went and had a R2k alarm fitted and made the key fob redundant, the alarm fob is then used iso the key's one!!
    Malcolm van Coller - retired but remained living in Johannesburg (love it here, can find everything you want and need here in Jhb)
    2011 Nissan Pathfinder 2,5 CDi LE Manual (Standard Traction Control plus Front Diff Locker)
    2008 Nissan Patrol 3.0 TDi GL (Packing system, 60lt water tank, std rear locker, LOKKA on front, two 105ah aux batteries on NL system, larger Cirrus intercooler, complete 76mm exhaust system)
    2003 Bushwakka Shorti (extra luggage space for customers on when on safari (with 160 H/Moon Star Gazer RTT and 100lt water tanks)
    Ex 1999 Nissan Terrano 2.7 TDi (Limited Slip Diffs Front and Rear) with Jurgens RTT for Guiding trips
    Ex 2011 Conqueror Supra II for personal camping
    Ex 1995 GQ Patrol GLX 3 speed Auto (disaster that box was!) - Lexus V8 transplant
    Ex 1984 Nissan Safari (Poelies Vehn) 2.8 Stationwagon with 5 speed conversion, rusted like it was paid to rust!
    Ex 1995 Sani 3.0 V6 Exec
    Ex 1994 Venture 2200 with lock diff (Company vehicle) that whet my appetite for overlanding.
    B-gowrie Randburg
    Thanked: 233
    Maybe try prying the battery contact out ... ?
    so the battery connects properly
    2002 Defender 130 DC HCPU. : Own the road...Any road
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8... The Greatest Rover.
    ‘1975 Series3 88 PUP... Simply Classic...
    ‘2017 Metalian Mini ... A Home from Home
    Dec 2018
    Thanked: 19
    Is it a Land Rover Key?
    Thanked: 145
    Quote Originally Posted by BushNomad View Post
    FL2 remote battery has legs which is soldered to/through the board.
    Jan 2014
    St Lucia
    Thanked: 9
    Hi I purchased a key fob housing from Amazon, it comes with a new battery. install your board, solder new battery in, all easy. Also available from e bay for a few hundred Rand!
    Thanked: 667
    Maybe phone Land Rover centurion. When I bought my Freelander 2 the spare key was missing. I had the dealership selling the car agree to replace the spare key. I don't think they paid near that amount.
    2011 Freelander 2 SE
    Dec 2018
    Thanked: 19
    Normally if you remove the plastic battery holder (with care) and solder in a new connection. A bit finicky. If it’s not that you need a new key.
    Mar 2019
    Hi
    An update, the spare keyfob that I had was not actually for my car. Can't even believe that. I've been told that only land rover can reprogram the keyfob to my car.
    Then the main keyfob battery started acting up. Went to Solihull4wd and they changed the battery and gave me a new keyfob cover - cost about R860.
    You can source the battery yourself for about R150. Gotta factor in delivery costs, I don't have a soldering iron and not any good with one either. So the R860 has not too bad of a compromise.
    Question now is, will Land rover be able to reprogram the spare keyfob
