NL Dual Battery System - Help me here Please.
Results 1 to 20 of 24
    Bethlehem
    Thanked: 4357
    Default NL Dual Battery System - Help me here Please.
    I got a NL dual battery system with the GRX that I bought 2 weeks ago, that has since crept into my heart and lovingly called "Olive" - see here.....https://www.4x4community.co.za/forum...san?highlight=
    It has a battery box (removable/portable) that is not connected now.
    If I may ask a few questions please. I', asking them one by one, with accompanying pic(s).
    The battery monitor shows 2 green dots, but there's only one battery connected now. Why is that?? Or would it light up "normally" if the battery box is also connected??
    Pic attached. The lights show GREEN, not YELLOW (pic may look yellow)
    Thanks.
    2008 Mercedes Benz CL 500........................"Bullet" (going....going...)
    2006 Mercedes Benz C 180K........................"Sussie"
    Bethlehem
    Thanked: 4357
    Default Re: NL Dual Battery System - Help me here Please.
    Then, in the engine bay, the NL Solenoid thingy does not light up at all, when the car is idling or not. Car has not idled long though, is there a specific "time relay" after which things will light up??
    Or is it, one again, because the second battery is not connected?
    Pics attached.
    Thanks a Mill, appreciate.
    Oct 2012
    Thanked: 82
    Pics attached.
    There is usually a 5 minute delay before the solenoid kicks in
  4. The Following User Says Thank You to Gothan For This Useful Post:
    Oct 2012
    Thanked: 82
    You can also hold the “on” button in for about 3 secs, that’s disables the 5 minute delay and the solenoid should then kick in immediately
  6. The Following User Says Thank You to Gothan For This Useful Post:
    Bethlehem
    Thanked: 4357
    OK....thanks so far, last Question/Request for Advise for the Day, I'll get to the rear of the Patrol later.
    This is the connections on the primary battery's terminals.
    Do they look OK, or room for improvement?? Some "spray" or solvent to just clean them up nicely?? Connections good, looking at the pics?
    Thanks again, appreciate
ID:	559521   Click image for larger version.
    Sep 2010
    Noordhoek
    Thanked: 169
    Something looks dodgy here.
    Have you checked the wiring from the solenoid to the main battery? is it connected?
    Check cable from solenoid to monitor. Very odd that both green lights are on when the 2nd battery is not connected.
    Sam
    ZS1SAM
    V5/ZS1SAM
  9. The Following User Says Thank You to SamM For This Useful Post:
  10. #7
    Okahandja, Windhoek
    Thanked: 854
    Thanks.
    Lyk my jy kan daai ding weggooi.? it should show all the lights up do the current volts of the battery. If only one battery connected it will show only one set of leds
    Johan Kriel
  11. The Following User Says Thank You to JLK For This Useful Post:
  12. #8
    Bethlehem
    Thanked: 4357
    Guys, theres another thing, please escuse me if this sound stupid...........but under the rear seat, there are a red and grey BH plug connected in a "loop" (dunno what to call it)
    Can it be that the solenoid and monitor "sees" 2 batteries??
    Sorry actually wanted to get to the rear later, but just have a peep here what I'm talking about please
  13. #9
    Bethlehem
    Thanked: 4357
    Some more
    The Red BH goes to 2 outlets in the drawer system.
  14. #10
    Bethlehem
    Thanked: 4357
    Some more, to get a better picture
  15. #11
    Bethlehem
    Thanked: 4357
    The battery box at the back has a red and grey BH input, but I have NO idea how the hell that works. Like I said, more on that later.
    Die goed maak my deurmekaar.
  16. #12
    Oct 2012
    Thanked: 82
    Gelukkig ek ken darem die battery box. Die battery box het basies sy eie solenoid in. So jy het nie n aparte een nodig om die battery box te charge nie. Jy kan basies dik kabel straight van die voorste battery ma die battery box vat. Dan plug jy dit in by die rooi BH. Dit vloei dan deur die box se solenoid. Dit het ook n 5 minute timer op.
    Die grys BH is ook input , maar bypass the solenoid in die box . Mens gebruik dit nogal as jy n solar regulator daar koppel, dan charge dit direk op die battery in die box
  17. #13
    Sep 2010
    Noordhoek
    Thanked: 169
    Going to be difficult to diagnose without being able to see how cables run ............ where do they start and where do they end etc.
    If you do not feel confident, take it to an auto electrician who knows his stuff.
    Sam
    ZS1SAM
    V5/ZS1SAM
  18. #14
    Bethlehem
    Thanked: 4357
    Gothan nee, lyk nie of daar solenoid in daai battery box is nie.
    Soos ek dit het - en ek weet NIKS van die goed nie - unplug jy daai Brad Harrison "bridges/loops", die grys BH gaan in die battery in, en jy kan net die 2 outlets bo op die battery self gebruik.
    As jy die rooi BH ook inplug by die battery wat gaan na die drawers se uotlets toe kan jy obviously dit ook gebruik.
    Sal more so bietjie kyk of die solenoid inskop, en of daai "on" knoppie op die monitor iets verander.
    THANKS
  19. #15
    Oct 2012
    Thanked: 82
    Stuur bietjie kiekkies van die battery box self
  20. #16
    Bethlehem
    Thanked: 4357
    Battery Box...…...……
    As above, it has a red and grey BH, I assume the red BH is an input from the front (solenoid), and then ONLY the 2 Hellas on the battery box are the outputs.
    Then I assume if I plug in the grey BH with the grey BH at the back, it then also powers the outlets in the drawer system.
    But will first start up the Trol and see if that solenoid kicks in...…...I just dunno if it WILL actually kick in with only one battery connected?
    Thanks anyway so far, appreciate the inputs
ID:	559569   Click image for larger version.
ID:	559570   Click image for larger version.
ID:	559571   Click image for larger version.
ID:	559572   Click image for larger version.
  21. #17
    Brackenfell
    Thanked: 258
    Pics attached.
    There is a connection on the right hand side (thick red cable), which I would presume is the battery to solenoid. Where does the "out" connect? Should there not be a red cable connected on the left side of solenoid that is fused and heads toward the aux battery?
    that seems to be missing. Might also be why both lights indicate green. Surely if connected correctly all the light should luminate for the main battery up to current level of charge.
  22. #18
    Jun 2013
    Thanked: 2631
    Post 8 and 9. Is there a fuse in that black box ?
    BMW R1200R
  23. #19
    Thanked: 421
    Petri - in short - if the second battery is not connected the monitor should only show one, and the yellow lights should only be on for the one battery - showing the strength. Again, if the second battery is not connected, the solenoid will not kick in - not matter how long you wait. I think (from what I see) that the monitor might be faulty, or the connection to it a bit dicky. Best get someone who knows to have a look at the whole installation.
    Gavin
  24. #20
    Bethlehem
    Thanked: 4357
    Quote Originally Posted by gavpike View Post
    gav - I think you're spot on, thanks.
    I got the monitor working correctly now , only one "strip" is showing. I held the "SET" knoppie for a couple secs and all things good were suddenly lighting up.
    So.…….Progress.
