Wheel hub lockers
Results 1 to 17 of 17
    Humansdorp
    Thanked: 21
    Default Wheel hub lockers
    Here comes a question for the knowledgeable engineer among you:
    Is it possible and if so, how difficult is to convert a standard/normal wheel-hub into a lock/unlock one?
    I love Mozambique!
    Henties
    Thanked: 747
    Default Re: Wheel hub lockers
    May I ask what vehicle and what for?
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
    Oct 2006
    Thanked: 25
    Depending on vehicle.
    Vehicles like isuzu is easy
    '86 SFA Hilux V6
    Sponsors:
    Thanked: 1022
    What do you mean by a "standard/normal" wheel-hub?
    If you mean it is a auto locking front wheel hub, it is easily
    And what do you mean by a "lock/unlock" one?
    If you mean it has to be manually locked and unlocked, it is basically the same as the one mentioned above without the auto locking hardware.
    If it is a permanent 4 wheel drive system, unfortunately the answer in most cases is likely "NO, you can't".
    Do you want to change it from auto locking (which do sometimes give problems) to manual locking?
    It is a easily done as contacting Commercial Auto Parts (https://www.commercialautoparts.co.z...SAAEgLQivD_BwE) and hear if they have a manual version for your vehicle. Ask for the make and part number, see if someone in your neck of the woods can help you. In most cases, you undo the 6 bolts holding the locking device, follow the instructions the new one came with, and fit the new one. A lot of Nissan (NP300, Hardbody, Terrano and Patrol) owners have done this... takes maybe 20 minutes per side.
    Just make sure the number of splines match, i.e., that the new locking device has the matching number of spline groves as on your old one.
    Malcolm van Coller - retired 2013 but remained in Johannesburg (maybe will look at moving south, Robertson or Wellington type of town, once the wife retires)
    2011 Nissan Pathfinder 2,5 CDi LE Manual (with front Lokka) - My Platkar...
    2008 Nissan Patrol 3.0 TDi GL with front Lokka (Use it mainly for Safari business)
    2003 Bushwakka Shorti (with 160 H/Moon Stargazer RTT and 100 lt water tanks)
    Ex 1999 Nissan Terrano 2.7 TDi
    Ex 2011 Conqueror Supra II
    Ex 1995 GQ Patrol GLX 3 speed Auto
    Ex 1984 Nissan Safari 2.8 Station wagon with 5 speed conversion,
    Ex 1995 Sani 3.0 V6 Exec
    Ex 1994 Venture 2200 with lock diff (Company vehicle).
    Henties
    Thanked: 747
    Quote Originally Posted by mvcoller View Post
    True and why would one want to do that?
    Since in a permanent 4x4 the drive shafts would still be driven, unlocking the hubs would probably result in the front drive shafts spinning and no torque going to the rear wheels, since the centre diff would send all the torque to the front.
    2012 FJ Cruiser
    Worcester
    Thanked: 1312
    Vehicle depending, it might be possible...
    My XJ for instance, has 2WD where the transfer box disconnects the front drive shaft... but the wheels still spin the axles and front prop when moving. This allows for 'always' on the fly ability to engage 4WD. I'm sure lock/unlock hubs can then be fitted.
    But, I cannot see what the real world advantage of this would be as the costs would be much more than the possible fuel saving.
    Work. It's a wealthy man's privilege, and a poor man' fate....
    André Opperman
    "Boerbok" - 98 Jeep XJ 4lit auto
    "Gloria" - 04 Ranger D/C 4lit auto
    May 2016
    Thanked: 3038
    I just love all the answers, while nobody knows what the question is!
    It sure demonstrates the members' willingness to help!
    2006 VW Touareg V10 TDi
  8. The Following User Says Thank You to 4eTouareg For This Useful Post:
    Wilderness
    Thanked: 1179
    Yes. DIY 20 minutes per wheel.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Apr 2018
    Fraserburg
    Thanked: 791
    Quote Originally Posted by 4eTouareg View Post
    That's the norm here. Even members that have no idea of a subject are willing to answer and even tell those who have been in an industry for years that they are wrong.
    2001 Isuzu Frontier 4X4 DT280 LX 2.8 Turbo Diesel (Tourer)
    2011 JMC 4X4 Double Cab 2.8 Turbo Diesel (Work Bakkie)
    1973 Land Rover Series 2A 109" Ford V6 Kanniedood, Salisbury diff, galvanised chassis etc. (Hobby and Work vehicle)
    Thanked: 1121
    As per a previous post - vehicle depending.
    My 88" S2 was manufactured with no locking wheel hubs. As it gets A-framed often, I fitted wheel hub lockers on all 4 wheels... But is is a '59 model.
    As per the preceding post: "My advise is free - the expenses start when you use it"....
    1959 SII 88"
    196? S2B FC "Over Lander" Camper
    197? RRC
    2002 Defender Td5 D/C
  12. #11
    Thanked: 439
    Locking hubs are an “after-market” option.
    Not the best idea for Series Landys.
  13. #12
    Thanked: 1121
    Yes Boss!
    1959 SII 88"
    197? RRC
  14. #13
    Langs die rivier, op n berg
    Thanked: 2977
    Ek wil baie graag freewheel hubs hê. Vir disco 2, en disco 1.
    Sal my lewe baie makliker maak. Haat dit dat voor propshafts heelpad saam hardloop.
  15. #14
    Jan 2017
    Thanked: 975
    Ek neem aan dit is op iets opgebou? Standaard is D1 en 2 permanent 4x4? Watse transfer case gebruik jy?
  16. #15
    Thanked: 2977
    Patrol op beide
  17. The Following User Says Thank You to Reenen For This Useful Post:
  18. #16
    Jan 2017
    Thanked: 975
    Patrol op beide
    Okay. En neem aan centre diff op die is nie n op die nie?
    as die D1 diff wat jy hey not die ou 10spline weergawe is, is ek seker die freewheel hub kits vir series landies sal daarop kan werk, maar as dit die 24 spline is, gaan jy sukkel om iets te kry.
  19. #17
    Thanked: 2977
    Yip.
    Part time 4x4.
    2H, 4H, 4L.
    Die disco1 nie veel oor gepla nie.
    Maar die d2 as voertuig gaan n trip met duisende km grondpad doen, en sou nice wees om te gery het sonder die klomp goed wat saam draai.
    Ek weet dit is net 8 boutjies om voor prop los te maak, maar daar gaan genoeg offroad ook tussen in wees.
    Moet seker maar net vrede mask met daai prop
