Voters
4. You may not vote on this poll
  • Yes, I love it!
    4 100.00%
  • Nope, its a silly idea.
    0 0%
Page 8 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 141 to 160 of 229
  1. #141
    Knysna
    Thanked: 14
    Default Re: Pajero Gen 2 restoration
    Nice work, what are the fuel consumption of the 3.0 and 3.5 V6 short wheel base pajeros?
  2. #142
    Thanked: 17104
    Quote Originally Posted by LRFan View Post
    Between 6 and 7km/L
    Jakes Louw
  3. #143
    Thanked: 566
    I get around 12 l/100km which is around 8 km/l
    In 4x4H that goes up a bit to 6-7 km/l and in 4x4L it doubles.
    Like I always say, a 4x4 does not need a odometer, it needs an hour meter as used on machinery. 400k km on a 4x4 is IMHO around 800k km with a platkar in terms of wear and tear.
  4. #144
    Thanked: 566
    I went to fetch the repaired gearbox input shaft today. I must say Loftie Deyzel of Robbie Deyzel Engineering did a great job.
    He first hard chromed it and then cut the shaft to an exact slide fit that still grips the inside of the bearing well.
    Thanks Loftie!
    It is this end in case you wondered!
  5. The Following 4 Users Say Thank You to mygoggie For This Useful Post:
  6. #145
    Oct 2006
    Walmer Heights, Port Elizabeth
    Thanked: 119
    Thanks Loftie!
    What was the cost?
    Owned
    1999 Colt Rodeo 3.0 V6 4x4-Build
    2005 Chevrolet Lumina UTE SS 5.7 V8 Auto - Build
    Sold
    1998 Pajero Gen 2 SWB 3.0 V6 4x4 - Resurrection
    1997 Ford Ranchero Outback 4.0 4x2 -
    Build
    1979 Landrover Series 3 88" Ford 3.0 V6 4x4- Build
    1980 Landrover Range Rover 3.5 V8 4x4 - Build
    1979 Landrover S2A 109" with Chev 4.1 4x4
  7. #146
    Thanked: 566
    Quote Originally Posted by Racer-X View Post
    What was the cost?
    R1500-00 which is a fair price in my books.
  8. The Following 2 Users Say Thank You to mygoggie For This Useful Post:
  9. #147
    Thanked: 566
    I have also ordered the new propshaft components from Coetzparts.
    I was checking the gearbox bearings today and one makes a horrible noise. So I went to the local SKF agent to find replacement bearings. In my opinion these bearings should run in the gearbox oil and not be sealed units only lubricated by the grease they came with. What is the correct option? Remove the inner bearing seal and keep the external seal?
  10. #148
    May 2016
    Thanked: 3601
    There was a discussion somewhere about this.
    IIRC consensus was to modify the bearing as you suggest.
    2006 VW Touareg V10 (Sold)
  11. #149
    Thanked: 566
    Thanks for the reply @4eTouareg. Would be interesting to read this discussion. It just makes sense to have all the lubrication in the world available and frequently renewed instead of being stuck in this world of abundant lubrication with your own small non-renewed tiny bit of lubrication.
  12. #150
    Nov 2011
    Langebaanweg
    Thanked: 1593
    This is what I like about you and your work, you usually go for the fix it myself than the replace/somebody else's problem route.
  13. The Following 2 Users Say Thank You to jfh For This Useful Post:
  14. #151
    Thanked: 17104
    As long as the outer seal can keep oil off your clutch, yes...........
    Jakes Louw
  15. #152
    Thanked: 566
    I like my clutch smoking hot .... :-)
  16. #153
    May 2016
    Thanked: 3601
    I searched the Internet, and the concern (on many discussions) is that steel shavings from the transmission could enter the bearing, if it is not sealed.
  17. #154
    Thanked: 566
    And then Brain told me while I was in town: "Use your common sense ..."
    Low and behold ....
  18. #155
    Thanked: 17104
    Low and behold ....
    Well then you'd only get splashed oil on that bearing, so you may as well use both seals and grease the sucker...........
    Jakes Louw
  19. #156
    Thanked: 566
    Jip, "This is the way"
  20. The Following User Says Thank You to mygoggie For This Useful Post:
  21. #157
    Thanked: 566
    Ordered and on its way way!
  22. #158
    Thanked: 566
    A box arrived today!
    The new propshaft components are here!
    The next step is to get these two parts fixed with a torqued bolt or some form of fixing device. I will go to Loftie tomorrow and have a chat with him.
    The next step then will be to machine a flange to bolt the yoke to the double cardan joint.
    Now onto finding bearings and oil seals. Anyone knows of someone coming from Spain or the UK to SA as I can get parts from www.euro4x4parts.com ?
  23. The Following User Says Thank You to mygoggie For This Useful Post:
  24. #159
    Thanked: 566
    Today I went to Loftie and discussed what must be done. The new flange must be made to more or less the same as that is on found on the rear differential.
    The flange will have to be 118mm in diameter to match with the new double cardan joint bolt holes. Let's see what he can come up with.
    While measuring the sleeve diameters we found another big issue. ... --- ...
    The bush in the transfer case is worn.
    If you know of a supplier of white metal bushes then please let me know. The sizes I am looking for is 39mm ID, 42-45mm OD and length of 40-45mm.
    I see Toyota has a part number 90999-73105 which could work if I can determine the dimensions. Maybe someone has access to this info and can let me know?
    So we keep hacking away to find a solution and fix the broken bits!
  25. #160
    Jan 2015
    Thanked: 459
    No, do NOT remove the seals from the bearings. The seals are not intended as oil seals but rather dirt seals. When I am replacing bearing in a gearbox, I normally remove the seals, wash the grease out, clip one seal back in, fill the bearing with gearbox oil and clip the other seal back in place. Much of that oil seeps out while fitting though.
    This is not an issue as oil from the gearbox will creep into the bearing to keep it lubricated, but the seals keep the small metal bits out of the bearing.
    Guy B. Vergoes Houwens
    2014 LC76 4.5 V8
  26. The Following User Says Thank You to ghouwens For This Useful Post:
