Voters
4. You may not vote on this poll
  • Yes, I love it!
    4 100.00%
  • Nope, its a silly idea.
    0 0%
Page 7 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 121 to 140 of 229
  1. #121
    Thanked: 17104
    Default Re: Pajero Gen 2 restoration
    PTO: an optional power port usually adjacent to the front propshaft pinion shaft. You can drive external items like winches and pumps. Mostly unused these days but a clever bloke can have a gear cut and fit a shaft with bearing.
    Jakes Louw
  2. #122
    Thanked: 566
    I never realised the gearbox has a PTO outlet. I see you can buy the bolt on unit from China and it is well rated by the AUZ guys. Vely intelesting.
  3. The Following User Says Thank You to mygoggie For This Useful Post:
  4. #123
    Thanked: 498
    Does it need a TCU?
    Nope.... was connected to a 4y motor....I’ve still got the adaptor & TC (as it came outta the Vehicle)
  5. #124
    Thanked: 17104
    Probably won't fit the Pajero then.
    Jakes Louw
  6. #125
    Thanked: 566
    Can anyone please check and let me know what direction the rear propshaft on the Gen 2 turns?
    Thanks!
    I really really need to post the hundreds twenty four onety photos I have taken so far on getting the gearbox and TC stripped.
  7. #126
    Thanked: 566
    I am making progress with finding a solution for the propshafts!
    After giving up on anyone willing to help me I met Dawie Coetzee of Coetz Parts online. After a few emails he sent me this ...
    Now I need to find someone to machine the splined sleeve yoke and fit a flange to it. I also need to make a plan to bolt/lock the sleeve onto the output shaft so that the spline in the shaft can accommodate the movement.
  8. #127
    Oct 2017
    Vereeniging
    Thanked: 173
    PLEASE don't snap change from 1st to 2nd when you're in a dice. That pencil is not gonna make it.
    Die B staan vir Beneke
  9. The Following User Says Thank You to EtienneB For This Useful Post:
  10. #128
    Thanked: 17104
    So you need a Slip Yoke Eliminator?
    How many teeth and what diameter on that output?
    Jakes Louw
  11. #129
    Thanked: 2718
  12. #130
    Thanked: 566
    No, you do not get a SYE for this gearbox. I can have the splined shaft and the sleeve bolted together with a centre bolt to create one.
    However for this I need a splined sleeve with a flange like this. This one is from a 2006 Pajero 3,2D front propshaft with a CV.
    The number of splines are 26, the OD of the sleeve is 39,7mm and the ID between splines is 29,3mm. See below.
  13. #131
    Thanked: 566
    Why not tripod CV joints?
    No idea why Marius. If you know of a brand + part number that can work, please let me know. So far only Dawie Coetzee has been willing to help me with this problem and he said for a 4x4 a double cardan is the correct way to go. He said that propshaft CVs tend to loose the protecting rubber and then the CV lasts a few minutes.
  14. #132
    Thanked: 566
    I took this in to Loftie Dysel in PE this morning and he said no issue to fix. Hard chrome the area and the turn it to size. Works out a tad more than a grinding and sleeving operation and is the correct way of fixing the issue.
    Let's see what it looks like when done.
  15. #133
    Thanked: 17104
    1 9/16" and 1 5/16" ?
    http://driveshaftparts.co.za/index.p...ry&path=20_125
    http://driveshaftparts.co.za/index.p...roduct_id=3623
    Seems to be in stock.
    Jakes Louw
  16. #134
    Thanked: 566
    Wow, thanks for this. I will get the exact dimensions as this state 39mm OD whereas I need a 39,7mm OD. The oil seal is exactly 39,7mm ID so the sleeve OD must match.
  17. #135
    Thanked: 17104
    Then look at this, should be the same as the early Paj and the Galloper were the same vehicle:
    http://driveshaftparts.co.za/index.p...roduct_id=1575
    Jakes Louw
  18. #136
    Thanked: 566
    This one is not stocked ...
  19. #137
    Thanked: 17104
    Frok
    Jakes Louw
  20. #138
    Kathu
    Thanked: 3544
    Tripod CV joints are low velocity joints. Won`t work on a prop shaft.
  21. The Following 2 Users Say Thank You to grips For This Useful Post:
  22. #139
    Thanked: 566
    Thanks for the feedback @grips. After a bit of reading it also appears that tripod joints have a much smaller functional angle of rotation.
  23. #140
    Thanked: 566
    I see a Spicer 2-3-8731X slip yoke can work if I can get the flange made up and welded to the yoke. Alternatively get the yoke to fit directly into the double cardan joint. I will ask on Monday ...
