Today I want to sort out the passenger seat that does not lock properly on the forward and rearward slide. More importantly it does not retain the backrest position memory. When the Paj is loaded this is a major issue as the backrest does not lock if the seat was moved forward and I have to unpack the luggage to get the backrest to move far enough backward to reset.
First step was to remove the seat and also the seat covers to be washed and repaired.
I found the problem quickly as to why the forward/rearward slide does not lock properly. This little plate that stands up was bend and barely touches the release spring.
So I bend it a little further away from the slide and it is locking 100% now.
The backrest took a while to figure out. Inside this mechanism is a ratchet type gear that locks in place when the Memory arm is pulled to the rear. Yes, the button is from a RH seat!
Here is the ratchet gear mechanism.
It took quite a bit of time to understand that the arm is locked onto the ratchet with the rubber boot/pad that locks onto the teeth of the ratchet. The issue is that the pad is worn away .... no I need to figure out how to replace the pad or add a new surface ... I am NOT going to strip the mechanism. Springs jumping all over the show is not my scene!
