Voters
4. You may not vote on this poll
  • Yes, I love it!
    4 100.00%
  • Nope, its a silly idea.
    0 0%
Page 10 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 181 to 200 of 229
  1. #181
    Thanked: 575
    Default Re: Pajero Gen 2 restoration
    What happened? Did the Bossman fix the hole and the thread.
    Spiceman, I will see next week what is what. Been busy finding bearings and parts. Three months of searching for bearings at everyone and his brother and then Bearing Agent replies within 24h with the correct bearings in stock. How is it that nobody wants to do business Managed to find a transfer chain and engine mountings from "Die Garage" - https://diegarage.co.za/
  2. #182
    Thanked: 575
    Bearings confirmed shipped this morning! Cool!
  3. #183
    Thanked: 910
    How did the white metal casting go?
  4. #184
    durban
    Thanked: 1447
    Me too wants to know. I would have just made one from phospher bronze, not oilite.
  5. #185
    Aug 2014
    Lanseria
    Thanked: 17
    Excellent news on bearings and chain.
    Do please keep that locknut for me. Starting the job soon.
    2000 Mitsubishi Pajero SWB 3.0 V6 24v (Factory Service Manuals, Parts Catalogs)
    1978 Land Rover Series III 109 PUP (Workshop Manuals)
  6. #186
    Thanked: 575
    Will try my hand at it tomorrow. I was waiting for a steel bush casing from uncle Brian.
    Been replaying the process in my head a few times. I will take it slowly and make a video of my adventure.
  7. #187
    Thanked: 575
    Quote Originally Posted by MysteriousEngine View Post
    Will keep it and make your bush as well.
  8. The Following User Says Thank You to mygoggie For This Useful Post:
  9. #188
    Thanked: 575
    I investigated this route @plunger but phosphor bronze cannot handle 8000rpm ...
  10. #189
    Thanked: 575
    I started another thread about the white metal casting.
    You can follow it here - https://www.4x4community.co.za/forum...or-restoration
  11. #190
    Thanked: 575
    I finally, finally, finally ... Oh did I mention, FINALLY found the correct bearings for the gearbox and received them this morning.
    One Timken, one Koyo and two Nachi bearings. A bit of a mix and match but these are all quality bearings and I am not going to wait any longer.
    Next step is to find my C-clip pliers which is somewhere in the garage ... always the very last place you can possibly look is the hiding place for these missing tools ...
  12. #191
    Thanked: 910
    You must be clever and start at the last place to look for them.
  13. #192
    Thanked: 575
    Nou waarom het ek of Brain nog nooit aan dit so gedink nie ... ??
  14. #193
    Thanked: 2718
    Obvioisly it is always the last place you look. Who keeps looking after you found them?
  15. #194
    Oct 2006
    Walmer Heights, Port Elizabeth
    Thanked: 121
    Cool Re: Pajero Gen 2 restoration
    i have an inner and outer set of cir clip pliers that you are welcome to borrow.
    Yes, i have an ulterior motive:
    I have a rear shaft vibration up to 2500 rpm in my V5M31
    If you are successful i would like to copy your solution
    Owned
    1999 Colt Rodeo 3.0 V6 4x4-Build
    2005 Chevrolet Lumina UTE SS 5.7 V8 Auto - Build
    Sold
    1998 Pajero Gen 2 SWB 3.0 V6 4x4 - Resurrection
    1997 Ford Ranchero Outback 4.0 4x2 -
    Build
    1979 Landrover Series 3 88" Ford 3.0 V6 4x4- Build
    1980 Landrover Range Rover 3.5 V8 4x4 - Build
    1979 Landrover S2A 109" with Chev 4.1 4x4
  16. #195
    Thanked: 575
    The new transfer chain finally shipped this afternoon. Apparently the courier truck with the engine mountings was involved in an accident and a new set of engine mountings had to be shipped to Die Garage.
    Times are getting fewer and it seems I can get cracking at assembling the drive train.
    I have started to look at the last place and the C-clip pliers were not there. Nor at the second to last place or the third to last place. Tomorrow I will start at the first place. Do second and third and then alter between forth, forth from last, fifth, fifth from last until I find it. Hopefully in the Centre. ....
  17. #196
    Thanked: 575
    Smile Re: Pajero Gen 2 restoration
    Quote Originally Posted by Racer-X View Post
    Thanks @Racer-X, but I have those pliers. The C-clip is something else ... Will take a picture in its hiding place once revealed!
    Sounds like you are sitting with the same issues as I have. Sure, you try my solution as long as you take the mistakes with you!
  18. The Following User Says Thank You to mygoggie For This Useful Post:
  19. #197
    Thanked: 575
    And it was time to clean the garage .... spent the whole morning clearing two of the workbench tops so that I can start working on the gearbox.
    And I found my C-clip pliers. Yes, it was in the first last place I looked. It fell in behind the screwdrivers in the screwdriver rack.
    @Racer-X this is what it looks like.
    The business end is flat with dimples to allow the C-clip end to grip in these dimples.
    I then could remove the last C-clip on the last gearbox shaft. Do you spot the clip? I opened it and slid it back onto the shaft.
    The shaft removed and ready to be cleaned.
    As is the gearbox casing.
    Shaft with gears was actually not that dirty and it washed clean very quickly with some paraffin.
    Last wash with clean paraffin.
    The gearbox casing washed with paraffin and then onto brushing the outside faces with a brass cup brush.
    Pressure washed and clean of all dirt. Lots of surface rust is visible! Oh, what to do?!!
    Easy peazy, just brush some phosphoric acid on and let it stand for a while.
    The rust is almost removed. I coated it with another layer of fresh phosphoric acid to get rid of the last bit of rust.
    I will do a another post hopefully this evening with the first layer of acid primer painted onto the external surfaces.
  20. The Following User Says Thank You to mygoggie For This Useful Post:
  21. #198
    Thanked: 575
    It started raining so I moved back into the garage with the gearbox casing.
    Other side coated with phosphoric acid.
    Almost all rust is gone. Time to coat it again and let it stand for a few hours.
    Zoom ahead in our time traveling machine and here we are!
    Ready for painting with etch primer.
    All done and watching the paint dry ....
    All areas dried and looking good!
    Onto cleaning all the gasket surfaces of any etch primer.
    Next step is to mask these gasket surfaces and get the casing ready for spray painting. Taped ...
    And tape edge hammered and the surplus removed. Hammering with a ball peen hammer cuts the tape like a knife and gives a nice and clean edge.
    The next face hammered.
    And pulling away the overlay tape that we do not want.
    And the last face taped, hammered and cleaned.
    Tomorrow I will spray paint the surfaces and then onto assembling!
  22. #199
    Oct 2017
    Vereeniging
    Thanked: 173
    You are so brilliant in the detail Herman. Regtig!
    Die B staan vir Beneke
  23. #200
    May 2016
    Thanked: 3607
    Respect!!!!
    I think even Dave Kindig would be proud of you!
    2006 VW Touareg V10 (Sold)
