Discovery 3 Building a mechanically reliable TDv6 Engine
Results 1 to 12 of 12
    Dec 2015
    Cape TOwn
    Default Building a mechanically reliable TDv6 Engine
    Dear Fellow online community
    I come to you knowledgeable folks looking for tips & tricks evens some sorcery, on building a mechanically reliable discovery 3 TDV6 Engine
    any info will be deeply appreciated!!
    briefly, this is the 2nd time my engine kicked the bucket. First, the head gasket blow as a result of a cracked plastic thermostat housing, this was back in 2014
    in December last year, the engine seized up. since then it's been parked in a garage waiting for me to start working on it
    I am now in a position to commence work hence the reason for me asking for advice before proceeding
    thanks in advance
    Thanked: 888
    Default Re: Building a mechanically reliable TDv6 Engine
    Did the crank snap? What caused the second failure?
    2011 Freelander 2 SE
    Sep 2019
    Thanked: 342
    Most important aspect is finding the cause of the initial failure...
    2006 Discovery 3 TDV6.
    2003 Jeep Cherokee 2.4 - Surprisingly capable
    1996 Suzuki Samurai - work in progress
    Dec 2015
    Cape TOwn
    I will start stripping this weekend all that I know for sure is that the engine is sized
    Malawi
    Thanked: 1208
    Quote Originally Posted by hound View Post
    thanks in advance
    I know that many manufacturers use plastic thermostat housings but isn't that a recipe for disaster?
    Losing coolant and the consequent overheating kills a lot of engines.
    If you really want to sell an expensive SUV with a plastic thermostat housing , it better be so good nobody will ever have to complain.
    So my advice is: see if there's an aftermarket aluminium stat housing for the TDV6.
    Start with basics.
    Jan 2017
    Thanked: 975
    Unless something has changed, I was under the impression rebuild parts for these motors werenít available, and the only option was a sub assembly from LR. Has this changed? Are parts for this motor available now?
    Forest Hills, KZN
    Thanked: 813
    Different issue than the crank one I believe.
    2004 LR Discovery 2 Td5 GS - Hybrid Turbo, Intercooler, 33's, 2" Lift, V8 TC, Ashcroft CW&P 3.75 + ATB lockers. [GoldiloX]
    2003 LR Discovery 2 Td5 ES - mods list to be updated [Husky]
    2010 LR Discovery 4 V8 HSE - Lifted with IIDtool, Powered by Petrol and Running on Cooper AT3 LT (new spec) 265/65/18s [Imvubu] - SOLD
    Jan 2017
    Thanked: 975
    OP clearly stated engine is seized.... whether crank or not, itís going to need a bottom end rebuild. Pistons/Rings/bearings etc.
    if itís become possible to rebuild this motor instead of buy a sub assembly from LR, thatís good news
    Pretoria and ZŁrich/Switzerland
    Thanked: 451
    Hi All
    if it is a 5A or 6A with the originial crank only!!!, yes it can be rebuilt. LRXtreme did such a job very successfully in 2018.
    If it is a 2007 or later model, hands off a bottom rebuild. Source a factory sub only.
    If in any doubt whatsoever, that the engine does not have its original crank, then go the factory sub route.
    The above is the reason that we have kept our 5A TDV6 (2005), otherwise it would have been swopped for a V8 a very long time ago.
    George Bosch
    Distributor for:
    Ruimsig
    Thanked: 10684
    Hound, at the severe risk of showing very bad form in posting this, I dont think mechanical reliability and Tdv6 should be used in the same sentence.
    However, I wish you bon chance with your endeavor and hope you get your D back on the road as soon as possible and at the least expense.
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    Jan 2017
    Thanked: 975
    Hi All
    is there no aftermarket billet cranks etc available that are stronger/better than the original?
    Thanked: 451
    Quote Originally Posted by tashtego9 View Post
    Start with basics.
    Hi Tashtego
    yes that is available from OZ. Not cheap, but seems to be a bullet proof mod.
    https://triumphroverspares.com.au/product/water-outlet/
    George Bosch
    Distributor for:
  13. The Following User Says Thank You to hgbosch For This Useful Post:
