Mecer Inverter and TV Psu noise
Results 1 to 3 of 3
    May 2007
    Durbanville Cape Town
    Thanked: 73
    Default Mecer Inverter and TV Psu noise
    Mate has a Mecer 1200va inverter (spec says simulated sine wave - not sure what that means vs MSW and PSW?).
    Anyways, he has an older LCD TV, and when running on inverter the TVís PSU makes a humming noise.
    Is this bad for the TV / inverter? Will something break?
    Thanked: 401
    Default Re: Mecer Inverter and TV Psu noise
    Quote Originally Posted by bees View Post
    Here is what Sinetech says ... https://sinetech.co.za/select-inverter.html
    Modified Sinewave Inverter
    The Modified sinewave inverter has limitations. These are some of the appliances that may experience problems when running off Modified Sinewave inverters:
    • Laser printers, photocopiers, magneto-optical hard drives
    • Some fluorescent lights with standard ballasts
    • Power tools employing ďsolid stateĒ power or variable speed control
    • Some battery chargers for cordless tools
    • Sometimes produces interference in some television sets
    • Digital clocks with radios
    • Sewing machines with speed/microprocessor control
    • Medical equipment such as oxygen concentrators
    Modified sinewave inverters are usually only protected by standard fuses which, under normal circumstances, are not always fast enough, therefore they are by far more vulnerable to failure.
    It is definitely advantageous to use a pure sinewave inverter as a pure sinewave inverter can basically run any type of equipment in contrast to a modified sinewave / step square wave inverter.
    Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
    I'm not opinionated ... I'm just always right.
  3. The Following 3 Users Say Thank You to the_terrible_triplett For This Useful Post:
    Hillcrest, Malaysia
    Thanked: 6455
    Yes it is bad for the TV. Older TV sets had very poorly designed power supplies.
    Also see post #2 above.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
  5. The Following User Says Thank You to Fluffy For This Useful Post:
