Inverter Battery - Fuse, Circuit Breaker?
Results 1 to 20 of 35
    Harties
    Thanked: 498
    Default Inverter Battery - Fuse, Circuit Breaker?
    In talking to so-called solar system installers, many are installing AC circuit breakers as protection for the inverter batteries.
    Their utterances:
    - "we've installed them everywhere and have never had a problem [sic]"
    - "they work equally as well on DC as they do on AC"
    - "we don't use fuses because you don't want to be left in the dark when a fuse blows and you don't have a spare [sic]"
    Scary.
    Does anyone know where to get DC circuit breakers rated around 125A?
    I still prefer fuses though. Any preferred brand/type and availability, again around 125A.
    If you make a noise or need music in the bush or on the beach, you’re missing the point.
    King Williams Town
    Thanked: 966
    Default Re: Inverter Battery - Fuse, Circuit Breaker?
    It's going to set you back a few thousand Rands but the electrical whole sales will have eg North and Robertson, Voltex etc.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Harties
    Thanked: 498
    What's that for?
    King Williams Town
    Thanked: 966
    Quote Originally Posted by PRA View Post
    What's that for?
    125Amp, sorry a few hundred rand if single phase AC breaker
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
    Friemersheim, Southern Cape
    Thanked: 2330
    I bought Victron 125A fuse the other day.
    Can't help with breaker.
    Harties
    Thanked: 498
    Apologies - I'm not sure I understand.
    Are you saying that an AC breaker should be installed as an inverter battery protection device?
    Harties
    Thanked: 498
    Thanks.
    Wow - the fuse cost a lot more than the holder.
    Thanked: 2330
    Thanks.
    You get cheaper fuses.
    But since all Victron, stuck to what I trust
    Nov 2017
    Thanked: 192
    For your own protection you have to fuse the dc setup. I prefer the self extinguishing fuses but they are difficult to source and are expensive. R450 vs R75 for an anl type fuse.
    Use dc breakers for dc - I would not trust an ac breaker to do a disconnect when I really need it or to last. Dc and ac operate totally different, the internal parts are made out of different materials and sizes of contacts to cope with the loads. If there is a fault the ac breaker welds closed and/or melts so you will not be able to switch it off.
    Ballpark figure is about R250 for a dc breaker. Try any solar shop. The installers propably use the cheapest ac breakers which cost R45 - there's your reason.
  10. The Following User Says Thank You to HobieDave For This Useful Post:
    PRA
    Aug 2019
    Kimberley / Edenvale
    Thanked: 63
    I paid R850 for a 80A DC Circuit breaker last year ( Local electrical shop)
    Im sure one of the electrical gurus will chip in but the reason why a DC breaker is so much more expensive than an equivalent AC breaker is because with AC you have a 100 zero volt crossings every second. With DC this never happens, so to extinguish the arc that is created by the current when the contacts open under a fault conditions requires some extra components.
    I prefer DC breakers above Fuses, because the end user doesn't always have the necessary skill or knowledge to change the fuse, to to replace a blown fuse with the correct rating. Whereas with a breaker, anyone can flip a breaker back up.
    2am on a Saturday morning the blown fuse is quickly replaced with a piece of copper wire
    Thanked: 408
    Somewhere someone is talking BS in order to get the price low as DC stuff are expensive.
    Easy if you have solar panels to test say a 5A AC breaker and see if it trips.
    I have done so and can say the ancient Fuchs breakers work just as well on AC as DC. A Samite just won't trip close to the current it should.
    You can get a 125A fuse for R250 or pay up to R1100.
    Aug 2019
    Thanked: 63
    This is terrible advice ekkekan. No one is BS anyone, DC breakers are more expensive for a very good reason. The trip curve might still be valid but the contacts will fuse together on an AC breaker the day you really need them to open.
    DON`T USE AC BREAKERS IN DC APPLICATIONS
  14. The Following 3 Users Say Thank You to Tiaan Pot For This Useful Post:
  15. #13
    Apr 2016
    Thanked: 55
    Ja. DC comes at a price.
    But I'm amazed that you are tripping your battery circuit..
    What amperage are you talking?
    If you fit an appropriate fuse it should only blow with a catastrophic failure in the inverter..
  16. #14
    Harties
    Thanked: 498
    When a fuse blows there's a problem.
    You don't simply 'put in another fuse' - you find the problem first.
    If you don't the replacement fuse will also blow.
    Using an AC circuit breaker in a DC application is irresponsible and negligent.
    There's a reason why they manufacture DC circuit breakers.
    If AC and DC breakers are 'simply the same' why do they bother to manufacture DC breakers?
    See the last sentence in post #12!
  17. #15
    Hillcrest, Malaysia
    Thanked: 6210
    Oh dear.
    Looks like it is time again.
    https://www.youtube.com/watch?v=Zez2r1RPpWY
    Watch this and then please tell us again how safe your Fuchs breakers is on DC.
    A MUST WATCH FOR ANYBODY WITH DOUBTS ABOUT DC BREAKERS AND ISOLATORS/SWITCHES AND FUSES.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  18. The Following 2 Users Say Thank You to Fluffy For This Useful Post:
  19. #16
    Thanked: 408
    My be read the post. A person fitting AC breakers and saying it will work just as well on DC is BS the next person. Nowhere did I refer to the price of DC equipment being BS.
    Advice is when you pay me - all other comments are just an opinion.
  20. #17
    Thanked: 839
    Their utterances:
    Scary.
    Phone Solar Advice, they have Keto switches and 125 A DC fuses. I paid R1k for the set. They assured me they are DC fuses but I have not actually checked..
    The next question is should you be using 125 A or 80 Amp There was a huge debate with graphs etc on the powerforum but nobody was prepared to definitively say which fuse is the correct one to get...
  21. #18
    Harties
    Thanked: 498
    The next question is should you be using 125 A or 80 Amp.
    Thanks for the information.
    I'm installing a Victron MultiPlus ll GX 3kVA and the product manual recommends a battery fuse rated at 125A.
  22. #19
    Thanked: 408
    @Fluffy - I was merely pointing out that unlike the Samite the Fuchs will actually trip. Further I have a Fuchs that has tripped DC about 30 times without problems. May be it is working fine as the current is low. This is a 5A Fuchs MCB. This breaker is used in a circuit where as soon as the battery went below a certain level and the current increased it would trip to protect the charger. It is in use since 2015 LS.
    While we on MCBs on the battery side. Bear in mind you are going to have a larger volt drop over a MCB current coil than using a fuse. This might not be on all MCBs but on the Siemens DC I used.
  23. #20
    Thanked: 408
    Is this fuse on a 24V or 48V battery?
